Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-12-2013, 07:54 AM   #3511
Tancakar
Tancakar's Avatar
Oddometer: 370
Originally Posted by Moronic View Post
I've seen a couple of dyno results quoted in Euro magazine articles.
IIRC they got 132-134hp at the wheel, which was about the same as the Multistrada 1200 made for them.
Factory dynos are different then any dyno machine. Specially new dynos sometimes reads 10 to 15% down or wrong.so if they say this is a true resault I will be sad cause the bike sold with 150 hp not 134hp 145hp at rear wheel seems ok but at crank isn't very good.and this v twins needs some miles on them for full performance.
Tancakar is offline   Reply With Quote
Old 06-12-2013, 09:09 AM   #3512
wpbarlow
Oddometer: 11,510
That's in the range of acceptable loss for a production engine from 150hp at the crank - which is where most, if not all, manufacturers take their readings.
wpbarlow is offline   Reply With Quote
Old 06-12-2013, 09:59 AM   #3513
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,754
+ 1. About what you'd expect.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline   Reply With Quote
Old 06-12-2013, 10:27 AM   #3514
Audun
Audun's Avatar
Oddometer: 68
From Norwegian Bike mag:
BMW: 116.2 hp/7900 rpm
Ducati: 135.1 hp/9300 rpm
KTM: 141.1 hp/9200 rpm
Triumph: 127.6 hp/8600 rpm
The KTM has good torque from 4000 rpm, then leaves the rest in the dust from 6000 rpm. Could have shown some curves, but some people may make fuss about copyrights.
I guess we will se lots of variable results from bike to bike depending on tolerances and run in. Bad run in would easy loose you a lot of ponies...
Audun
Audun is offline   Reply With Quote
Old 06-12-2013, 10:46 AM   #3515
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,754
2013 KTM Adventure 1190
I have always heard 7% loss for chain, 10% for shaft so all those numbers sound plausible to me. Different dynos, different days.
Old 06-12-2013, 11:02 AM   #3516
Audun
Audun's Avatar
Oddometer: 68
Audun
These are all from comparision test, ie same dyno, same day..
Old 06-12-2013, 11:36 AM   #3517
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,345
Audun
130ish is what I would have expected.
I'm a bit surprised by the KTM numbers. 141hp at the wheel from 150 at the crank is a lot, sounds almost as "transmission gains"
Jaime
KTM 1190 Adv R
Jaimoto is online now   Reply With Quote
Old 06-12-2013, 01:06 PM   #3518
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,754
While not directed to me, I was speaking of the differences between the 134 test run and the 141 test run. Not the relative differences between the machines in the Norwegian tests. But, even same dyno same day is not the same. For example, morning air is not the same as afternoon air.
Old 06-12-2013, 02:12 PM   #3519
Tancakar
Tancakar's Avatar
Oddometer: 370
150 hp is quite normal i guess at the crank. but it should lost that much till it goes to wheel :)
Old 06-12-2013, 02:44 PM   #3520
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,345
Since HP at the crank can't be measured we have to rely on the figures at the wheel; what I meant was that 141hp at the wheel it's quite impressive, specially if you compare it with the 135hp from the Multistrada if you take into account that both bikes are rated at the same HP at the crank.
Don't know how many HP are lost in the KTM transmission but looking at the 141 figure, it can't be that much. That, or it makes more than 150 at the crank.
Anyway, we are talking about the most powerful DS bike out there so you guys can't complain
Jaime
KTM 1190 Adv R
Old 06-12-2013, 03:19 PM   #3521
pebble35
pebble35's Avatar
Oddometer: 1,582
I get 30 mpg in city wit two up and panniers. I think it's too high. But I am just waiting to pass 1000 miles to see how it's going .
That does sound high - our demo bike (which is probably being ridden 'enthusiastically' by customers) has averaged 48mpg (uk) over the last 600 miles
Might be worth having a chat with your dealer
Sent from my iPad using Tapatalk HD
Proud to be supporting Pyndon
www.lyndonposkittracing.com
www.bikersjersey.com for all your KTM parts
A 2,400 KM ride around Egypt by Scooter - ride report here
pebble35 is offline   Reply With Quote
Old 06-12-2013, 03:23 PM   #3522
rompe
Oddometer: 61
Originally Posted by AdvIvan View Post
My 1190Adv is a bit jerky at revs ranging 1500-3000; lots of "humps and bumps" from the engine at about 2000 rpm. How are yours? Not even the dealer knows if this is normal or not. Grrr. Otherwise the bike is awe--some!!
It's normal. This engine doesn't like to run under 3000rpm.
Enviado desde mi Optimus 2X usando Tapatalk 2
My other toy has tits . . .
rompe is offline   Reply With Quote
Old 06-12-2013, 10:07 PM   #3523
okeanis1234
Oddometer: 122
Originally Posted by okeanis1234 View Post
I have the bike for about a month now.i have an one and only issue:when the "low fuel" message is on,the automatic light doesn't turn on even though it is night!!!!when i refill the tank the light is "on" again!has anybody the same problem....?
Anybody with the same problem?
okeanis1234 is offline   Reply With Quote
Old 06-12-2013, 10:29 PM   #3524
Audun
Audun's Avatar
Oddometer: 68
I will check mine as soon as possible!
Audun
Old 06-13-2013, 03:16 AM   #3525
Tancakar
Tancakar's Avatar
Oddometer: 370
I think it might be running too lean but I took it to the dealer for 600 miles service and they say everything is ok. I talk them about this but they said I ride it too harsh ? I don't exceed 6000 rpm really :) so I don't know how can it be possible I am thinking if it is some thing to do with the on board computer.
Times are GMT -7.   It's 03:35 AM.
