Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 08-31-2013, 03:45 PM   #4141
nikoktm
nikoktm's Avatar
Oddometer: 284
Unifilter fitted yesterday
nikoktm is offline   Reply With Quote
Old 08-31-2013, 03:57 PM   #4142
CanningOz
Oddometer: 63
How long did it take you to get the body work and tank off to do this? I assume you had to drain the tank? Seems strange KTM made this so hard to change, especially as their dirt bikes have air filter access so wel sorted.
CanningOz is offline   Reply With Quote
Old 09-01-2013, 06:07 AM   #4143
jj_pt
Oddometer: 46
The Unifilter filters need any kind of fuel mapping changes, like the DNA filters?
2013 KTM 1190 Adventure R.
2010 Yamaha XT660Z Ténéré (Sold).
jj_pt is offline   Reply With Quote
Old 09-01-2013, 01:37 PM   #4144
Audun
Audun's Avatar
Oddometer: 68
New features...
Suddenly i can make left turn signal by pressing the horn and i get horn when making left turn signal. Also the "back" selector switch is misbehaving. Another frustrating warranty issue to put on the list. My dealer will sure have a handfull at next service....
At least the bike keeps running :)
Audun
Audun is offline   Reply With Quote
Old 09-01-2013, 02:35 PM   #4145
nikoktm
nikoktm's Avatar
Oddometer: 284
Hi Canning,
The dealer do that. They call me the same day the unifilter arrives to do the recall service.But I think the bike will need a fuel mapping. Since I left the dealer, the revs are quite high.
Old 09-01-2013, 03:11 PM   #4146
Filterman
Oddometer: 47
Hi Canning,
The bike should not require remapping if the only change has been the air filter. We have tried to keep the air flow as close to original as possible. In regards to changing the filter yes you do have to remove the tank. You don't have to drain it as the tank has two fuel taps to turn the fuel off. It takes about 40min to change the filter. The best advice is to follow the owners manual for removing the tank so you don't remove any bolts that are not required. You can change the pre-cleaner by just removing the front fairing that houses the turn indicators.
Filterman is offline   Reply With Quote
Old 09-01-2013, 09:42 PM   #4147
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,948
So does swapping the 19" wheel on to the R model for street riding throw the abs and TC all off....
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 09-01-2013, 09:53 PM   #4148
speed_racer
speed_racer's Avatar
Oddometer: 707
I wouldn't bother, i have as much confidence throwing this into a tight turn fast as i did with a F650gs on the black top and even more off road..
13' KTM 1190 Adventure R
KLX650R
RIP - BMW F650 GS Twin
speed_racer is offline   Reply With Quote
Old 09-01-2013, 10:08 PM   #4149
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,948
As fast as a F650gs?.........sorry couldn't resist...
If I ride my Multi back to back with my SE...I really miss a real front tire....
So....is it possible?
Old 09-01-2013, 10:17 PM   #4150
speed_racer
Oddometer: 707
hehe.. the engine doesn't have that much to do with the speed u can carry into and around a corner.. just exits and straights.. where u engage warp speed
But yes it would muck up the TC.. and a maybe on ABS, as well as your speedo
KLX650R
Old 09-01-2013, 11:16 PM   #4151
speed_racer
Oddometer: 707
Originally Posted by Davy F View Post
This looks sweet!! But how long do you expect the black to last on the plastics? Ive found in the past that paint tends to crack and come off on plastic.
KLX650R
Old 09-02-2013, 01:16 AM   #4152
-GUV-
Oddometer: 244
Are you serious? painting plastic isn't something new.
What have you done with Tancakar?
-GUV- is offline   Reply With Quote
Old 09-02-2013, 07:21 AM   #4153
Katoom72
Katoom72's Avatar
Oddometer: 886
It's called preperation. Something you need to do when you spraypaint any surface. The prep depends on the surface, plastic for example needs a primer to hold well.
Scotch-brite + plasticprimer and your paint won't chip or crack.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 09-02-2013, 07:24 AM   #4154
Schussboelie
Schussboelie's Avatar
Oddometer: 613
I just used PlastiDip.
Perfect for small areas and non-destructive.
I think it is some kind of latex based or something so it is flexible.
It's fairly heat-resistant as a buddy of mine used it on his exhaust guard with no issues.
All you need is to degrease the surface area properly and spray it on.
4 or 5 coats and you're all set.
Schussboelie is offline   Reply With Quote
Old 09-02-2013, 07:32 AM   #4155
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,256
I believe there's nothing painted in that pic, if you're referring at the headlight mask I think black is the original color in the standard adventure.
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is offline   Reply With Quote
Times are GMT -7.   It's 11:44 PM.
