Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 12-06-2013, 12:24 AM   #5446
Toors
Toors's Avatar
Oddometer: 120
Originally Posted by Fuat Domanic View Post
Answering my own question:
Yes there is a side stand recall for 2013 1190's!!!
Ktm says after many complaints of replaced side stand springs,
they are going to change the side stand itself and provide a new side stand for all 2013 1190s, covered by warranty...
2014s will come with a new sidestand...
have already received mine - about 4mm shorter than the original
Toors is offline   Reply With Quote
Old 12-06-2013, 01:47 AM   #5447
OrangeV
OrangeV's Avatar
Oddometer: 647
MSC explained -
75 V perky peak power from around 5000rpm and loves to be worked through the gears.
When you hit that sweet spot, it is simply electrifying. Stoner
A smile is a curve that sets allot of things straight..
OrangeV is offline   Reply With Quote
Old 12-06-2013, 02:01 AM   #5448
Jensdccom
Oddometer: 59
Originally Posted by OrangeV View Post
I like this feature but somehow I do not want to test this myself :)
Jensdccom is offline   Reply With Quote
Old 12-06-2013, 03:16 AM   #5449
Bigem
Bigem's Avatar
Oddometer: 2,560
Thumbs down
It needs to be shorter, I shit myself every time I put mine on the sidestand on anything that is not dead flat!
I will have to chase this recall, the dealer I bought mine from is fucking hopeless!!
"I'm a thousand miles from nowhere,
Time don't matter to me,
Cause I'm a thousand miles from nowhere,
And there's no place I'd rather be!!
Bigem is offline   Reply With Quote
Old 12-06-2013, 05:29 AM   #5450
Womble_CH
dribbling baboon
Womble_CH's Avatar
Oddometer: 312
4mm or 4cm ? 4mm would rather be factory tolerance, so no change at all. 4cm would make a big difference.
Womble_CH is offline   Reply With Quote
Old 12-06-2013, 06:52 AM   #5451
KMC1
There is no spoon.
Oddometer: 2,562
Wow. That's pretty poor body positioning in those MSC tests.
I think you should post that video into the dragon fail thread and watch all the Johnny Racer Boys lose their minds.....
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em
An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
KMC1 is offline   Reply With Quote
Old 12-06-2013, 08:02 AM   #5452
Audun
Audun's Avatar
Oddometer: 68
Wiring diagram
Anyone got one to share for the 1190?
Audun is offline   Reply With Quote
Old 12-06-2013, 11:31 AM   #5453
nikoktm
nikoktm's Avatar
Oddometer: 284
Where do you bought it?...
nikoktm is offline   Reply With Quote
Old 12-06-2013, 12:34 PM   #5454
paturoa
paturoa's Avatar
Oddometer: 259
Have a look at post #5314. The full set of wiring diagrams are at the end of the repair manual
paturoa is offline   Reply With Quote
Old 12-06-2013, 01:13 PM   #5455
umitc
umitc's Avatar
Oddometer: 346
If it's 4 mm shorter and standing wider than the previous, it would be better. I have received the telephone call about that recall, today in the afternoon. I will never buy the first ever editions in my future motorcycle life. :-)))
umitc is offline   Reply With Quote
Old 12-06-2013, 02:52 PM   #5456
Jensdccom
Oddometer: 59
I downloaded them from a link a few pages ago. I don't understand them though. I'm no hero at electronics neither but I do want to change some wires. A well, I have friends with more knowledge :p
Old 12-07-2013, 12:38 AM   #5457
Corsica101
Corsica101's Avatar
Oddometer: 426
Was called in to have mine done as well but turns out it was already done when I bought the bike in Germany, springs still had to be changed but they ran out of springs here in Spain!!!
Why don't they change the bloody air box! Had to get the unifilter on the last moment before my trip. Seriously!
Corsica101 is offline   Reply With Quote
Old 12-07-2013, 12:46 AM   #5458
Corsica101
Corsica101's Avatar
Oddometer: 426
See this airbox conversion - apparently it works well:
http://www.wilddog.za.net/forum/inde...opic=131440.40
The other thing that has been bugging me is the air intakes. I have seen some air filter damage. At risk of having to replace the intake tubes, I made a "test" mod.
Removing all the plastics to get here is a bit of a mission, but I was most of the way there fitting the GPS, so I just continued into the maze....
I basically just blocked off the intakes in the front where the perforated cover that is visible from outside slides in.
Then drilled two holes in the area covered by the tank.
Once assembled, none of the holes are visible, and nicely covered behind the plastics and tank where direct water cannot get to it.
Will need to find some water crossings to test. Not simple in the FS at present....
The expedition continues....
IMO this is not such a good idea. The tubes are there to force air into them. When the tank is on its a tight space and the airflow is reduced quite a bit I think.
Old 12-07-2013, 01:16 AM   #5459
Dearnla
Dearnla's Avatar
Oddometer: 166
Whatever you do, DON'T CUT THE RED WIRE !!
KTM1190 ADV
Honda VFR1200FD
Honda CB900F2
Dearnla is offline   Reply With Quote
Old 12-07-2013, 03:14 AM   #5460
Audun
Audun's Avatar
Oddometer: 68
Can't open the repair manual. Only front page appears.
Maybe an Apple vs Skydrive problem?
Audun
Times are GMT -7.   It's 07:09 PM.
