Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 01-26-2014, 04:12 PM   #6331
Todd-Squad
See Ya, Bye.
Todd-Squad's Avatar
Oddometer: 774
Originally Posted by grizzlyj View Post
Kind of a voltage question.
Having left my bike for too long I turned it on yesterday and the dash display said 11.9v. OK needs charging.
I also have a little voltmeter on the end of a cigarette lighter plug type of thing, so out of curiosity I plugged that into the accessory socket. 12.5v.
Is the acc socket feed stabilised in some way?
If it is, and I charge the battery through the socket as some folks here have, presumably the smart charger, seeing 12.5v, will give it a gentle trickle charge rather than the slightly bigger oooomph 11.9 (or whatever) might require?
Any thoughts? The little socket meter gives sensible readings in other vehicles so that seems ok.
If it were me, I'd just pull the seat and check the actual battery voltage with a multi meter. Then you will know for sure if the dash readout is correct, or if your cig-adapter-voltage-thingy is correct.
A ride you say? When and Where?
My Favorite Pics
Todd-Squad screwed with this post 01-26-2014 at 05:31 PM
Todd-Squad is offline   Reply With Quote
Old 01-26-2014, 11:33 PM   #6332
Tjeu
Oddometer: 143
Originally Posted by Thagua View Post
Cheers,
Roberto
Happy parts!!!
Tjeu is offline   Reply With Quote
Old 01-27-2014, 12:24 AM   #6333
hagenp
hagenp's Avatar
Oddometer: 18
My dash always shows +/- 0,5 Volt less compared to a cheap multimeter measured at the battery terminals...
hagenp is offline   Reply With Quote
Old 01-27-2014, 03:23 AM   #6334
Bundu
Bundu's Avatar
Oddometer: 685
you should take both readings with the ignition ON and then voltages should be the same
Bundu is offline   Reply With Quote
Old 01-27-2014, 12:07 PM   #6335
grizzlyj
Oddometer: 38
Rechecked with a voltmeter.
Ignition off gives 12.5 at the acc socket with the cheapo plug meter, and 12.5v with the proper meter at the battery terminals.
Ignition on only (no start), both the above dropped to 12.1, dash shows 11.8.
Ignition off again, both meters creep back up.
So dash meter is a bit off on my bike :)
grizzlyj is offline   Reply With Quote
Old 01-27-2014, 01:26 PM   #6336
Todd-Squad
See Ya, Bye.
Todd-Squad's Avatar
Oddometer: 774
That is good to know. It would be nice if the dash was spot on, however I'd rather have it read lower than actual than higher than actual.
My Favorite Pics
Old 01-27-2014, 04:47 PM   #6337
BigMan73
Binary Adventurer
BigMan73's Avatar
Oddometer: 350
Stability Programming Takes Bosch ABS to the Next Level
http://www.motorcyclistonline.com/fe...ock_mc_garage/
Tiger 800 XCx in White - Ain't she pretty?
SOLD: 2011 V-Strom 650A White Pearl. (Photo by: Lilolita. RIP dear friend )
Suzuki V-Strom (Stromtrooper) Wiki
BigMan73 is online now   Reply With Quote
Old 01-27-2014, 09:47 PM   #6338
youngblood
Oddometer: 357
The stability of this bike on any surface is absolutely amazing.
Sent from my Nexus 7 using Tapatalk
2014 KTM Adv 1190R
2007 KTM Adv 990S Dakar 7k miles FOR SALE
2005 KTM 525 SX Supermoto/Rally
2002 KTM LC4 Supermoto (old GumbyDave-mobile)
youngblood is offline   Reply With Quote
Old 01-27-2014, 11:55 PM   #6339
paturoa
paturoa's Avatar
Oddometer: 260
This is a software upgrade that is over and above the existing 2013 ABS and Traction Control. It lets you grab a whole handfull of front brakes mid corner without a lowside skid / crash. With the standard 2013 ABS, grabbing a bunch of front brake mid corner will result in tears.
paturoa is offline   Reply With Quote
Old 01-28-2014, 12:08 AM   #6340
AdvIvan
Rock on!
AdvIvan's Avatar
Oddometer: 104
It is not only software. You will need to install an aditional sensor with cabelling etc. There's more info somewhere in this forum - if you can find it :)
AdvIvan is offline   Reply With Quote
Old 01-28-2014, 12:27 AM   #6341
Davy F
Pro Goolie Fiddler
Davy F's Avatar
Oddometer: 279
Wrong. It is a software instal only.
Good luck exploring the infinate abbyss !
Davy F is offline   Reply With Quote
Old 01-28-2014, 02:40 AM   #6342
Dearnla
Dearnla's Avatar
Oddometer: 167
Having mine upgraded Thursday. I'll ask them what's involved, but I suspect the SW download will take the time. As any fule kno when upgrading their Apple or MS software.....
KTM1190 ADV
Honda VFR1200FD
Honda CB900F2
Dearnla is offline   Reply With Quote
Old 01-28-2014, 02:49 AM   #6343
okeanis1234
Oddometer: 122
Let us know if it is a software update only...
okeanis1234 is offline   Reply With Quote
Old 01-28-2014, 04:09 AM   #6344
mobileman
West Lothian
Oddometer: 35
It is just software, all the hardware is already there. The tilt sensor, which is the bit everyone seems to think needs to be added, is already there to support the lean sensitive traction control.
It is one of the reasons the traction control is so effective, it will let you slide a bit more when the bike is upright, and ups the safety levels when you are banked over. The MSC just takes all that hardware and adds clever software to make the braking safer.
This bike was always built with this in mind, its just the MSC wasnt fully ready and tested when the bike launched.
My dealer says the software upload is at least an hour
mobileman is offline   Reply With Quote
Old 01-28-2014, 07:41 AM   #6345
Davy F
Pro Goolie Fiddler
Davy F's Avatar
Oddometer: 279
My dealer says to allow 90/100 minutes for the download. Apparently, it has to interface back to KTM headquarters directly into their own server thingy. Don't know if that is true for you U.S. Guys.
Times are GMT -7.   It's 09:11 AM.
