Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 03-23-2014, 07:11 AM   #6526
Ossie
Oddometer: 50
Originally Posted by Nerb View Post
I did. full throttle or nothing for the first 150km from the shop to home. My sightglass level hasnt moved in 7000km, even though the bike has been upside down several times.
Just because, mine went to about 800 miles before the first change. The first 600 miles came to quick. Never took mine past the recommended 6500 initial rpm. She saw a lot of accelerations and decelerations in that time. I now have over 5k miles and she runs like a scalded cat.
OK there was one time it saw 8 or 9. There, you happy. I sure was.
Ossie is offline   Reply With Quote
Old 03-23-2014, 04:01 PM   #6527
Audun
Audun's Avatar
Oddometer: 68
Originally Posted by Tonyvm View Post
With the Puig, I don't use earplugs when I'm not going on the highway.
Here's a pic I found that shows the difference well:
That is HUGE. This is better.
https://www.dropbox.com/sh/yrrt45cob93annx/a7a-4P9Bqy
Stock screen cut and painted. Works perfectly. No turbulence at any speed in low and high position. Aftermarket is a waste of money (I wasted mine on the KTM touring rubbish). I'm 184cm.
Please note that this is not a R screen. The R screen also has the turbulence generating spoiler at top, even though the screen is shorter.
Since the stock is useless, no harm done trying....., and I'm not a dealer trying to sell you anything.....
Audun
Audun is offline   Reply With Quote
Old 03-23-2014, 04:36 PM   #6528
robmeoff
robmeoff's Avatar
Oddometer: 105
Bolt missing? MSC?
Just picked up my new 2014 and have a couple of questions.
On the RHS under the engine it seems a bolt is missing where the crash bars boot up to the engine? Is this right? Also I read a lot about MSC but only have MTC on the menu? I'm gathering the MSC is a part of the traction control?
Also have mounted some aux lights but need a good 3 way handlebar mounted switch as I like to be able to ride with them on in either low or high beam(switchable) depending on conditions.
Anyone know of a good switch? Or plug and play harness? Has someone mounted up a dash with aux switches?
Cheers rob
robmeoff is offline   Reply With Quote
Old 03-24-2014, 03:45 PM   #6529
llamapacker
Mr. Conservative
llamapacker's Avatar
Oddometer: 1,292
I had to tap the hole for rear bash plate on RHS, think that is what you are referring to.
The MSC is software. Provides controlled stopping while in a turn and also TC.
14 KTM 1190 Adventure
14 500xc-w plated
llamapacker is offline   Reply With Quote
Old 03-24-2014, 07:50 PM   #6530
robmeoff
robmeoff's Avatar
Oddometer: 105
So is the MSC a part of the MTC in the menu or does it need to be turned on by dealer programming? I thought I read somewhere that MSC was stock on 2014 models
Old 03-25-2014, 01:33 AM   #6531
Schussboelie
Schussboelie's Avatar
Oddometer: 546
It is standard on a 2014 but it's part of the ABS and as such is turned on/off with ABS. MSC has no purpose without ABS and using ABS without MSC (when you have it) makes no sense.
2013 KTM 1190 Adventure R
2009 KTM 990 SMT
2000 Suzuki SV650
2 x 1999 Suzuki TL1000R
Schussboelie is online now   Reply With Quote
Old 03-25-2014, 04:06 AM   #6532
Tonyvm
Oddometer: 10
Audun
That is definitively better in Summer, but I prefer more protection from the cold in winter, I don't know where you're from, but here in Belgium it can be cold...
Could you describe how you did that, what tools you used and what paint?
I'm a dummy in that area... thanks!
Tonyvm is offline   Reply With Quote
Old 03-25-2014, 04:29 AM   #6533
Tonyvm
Oddometer: 10
Did anyone install the bar risers?
I'm a tall guy so I'm sure they would be better for me for offroad riding, but I don't know what the effect will be on the road in the smaller faster curves?
Old 03-25-2014, 05:21 AM   #6534
kag
Wander Lust
kag's Avatar
Oddometer: 1,635
I installed Rox 1.75 low pro risers and they helped me quite a bit
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 03-25-2014, 06:54 AM   #6535
PS-RagE
PS-RagE's Avatar
Oddometer: 616
Do you do a lot of off-road, stand-up riding? How tall are you?
Just ordered these myself.
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
2014 KTM 1190 Adventure R
PS-RagE is offline   Reply With Quote
Old 03-25-2014, 06:55 AM   #6536
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
does that puig put the airflow above your forehead level ? I like to be either above or below the turbulence
MookieBlaylock is offline   Reply With Quote
Old 03-25-2014, 09:47 AM   #6537
Audun
Audun's Avatar
Oddometer: 68
I'm in Norway and drive all year round, including today when it was about 0 deg.C.
Even if it is low it protects most of the body, but proper windstopper and insulation in the neck area is of course mandatory. Tools were simple angle cutter (not sure of english term) and black matte paint from spraybox. I only used paint on inside, so from outside it looks shiny and nice.
Added bonus is that it feels like a supermotard from the drivers seat. Somehow it seems nimbler and lighter, even though its all in the head...
Audun
Old 03-25-2014, 10:05 AM   #6538
Audun
Audun's Avatar
Oddometer: 68
So if I upgrade my 2013 I would have to take my dealers word for it that they actually managed to download it correctly? No changes to menus at all?
Not comforting, considering they fucked up just installing heated grips (all damper adjustments dissapeared from the meny).
I'm not willing to test it by handful of brake in a wet corner.....
Audun
Old 03-25-2014, 12:48 PM   #6539
Schussboelie
Oddometer: 546
If it's a true '14 MSC is installed in the factory.
2009 KTM 990 SMT
2000 Suzuki SV650
Old 03-25-2014, 12:50 PM   #6540
Schussboelie
Oddometer: 546
I'm considering swapping bikes too, '13 standard 1190 Adventure for a '14 R.
Got a pretty offer from the dealer.
2009 KTM 990 SMT
2000 Suzuki SV650
Times are GMT -7.   It's 05:17 AM.
