05-13-2012, 10:56 PM
#31 | |
Oddometer: 735
I'm hearing you... Not so much saving money is " have to start somewhere" ....Your running 18 on the front? my Norton is only for weekend rides so has good old Dunlop TT's ( came with them).
05-14-2012, 01:39 AM
#32 | |
Oddometer: 1,133
I probably crashed due to my own fault braking too late and a bit off line. I just realised that what I said about the Bridgestones may have put a little doubt in your mind about them, and confidence in your tyres is crucial to going quick. so please ignore my previous comments. They are good, but not quite as good as the Avons. Yeah, 18" front and back.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. Bertrand Russell |
05-14-2012, 08:05 AM
#33 |
equitem casus
Oddometer: 2,634
First race...not according to plan
Well, the first race weekend is over. The bike had issues. The shifter arm was moving on the gearbox shaft. I wasn't able to shift the bike very well on Saturday, but I got through my only race that day. I came in a solid last place.
It was probably because I hadn't tightened down the set screw well enough. So, in an effort to sort that out, I tried to remove the shifter arm. It came off half way and then got stuck. It took a bit of work to get it either back on or get it off. Finally got it off the shaft.![]() I believe the banging and cranking on the shaft really fouled up the alignment inside the gearbox. Sunday morning I put back on the shifter arm nice and properly. I thought I was all set and ready to go. Set off onto the track to find I couldn't shift the bike into 3rd gear. I could only use 1st and 2nd. Bugger! I was done. I wasn't going to tear into the gearbox there at the track. I will try to find a 5 speed gearbox. I have a 4 speed one in there now. And with the 5 speed gearbox, find a newer clutch and flywheel. I was quite disappointed Sunday morning, but I got over it. I will chalk it up to experience. I was still able to learn a lot about how the event is run. I had a fun weekend all the same, although racing would have made it more fun. Next race is a one day event on 11 June. I'll return from watching the Canadian Grand Prix in Montreal the evening before and then get to the track, which is 30 miles from my home, to do my own racing. For pictures from the whole weekend, click on the photo above. It will take you to the gallery.
Think beyond yourself.~ap blog Max the Motorcycle - children's book written by Mrs. FTB SmugMug Photo Gallary |
05-14-2012, 09:43 AM
#34 |
because I can
Oddometer: 6,203
The starter might be a bit of extra weight but at least it is right wear it matters the least up toward the front and right around the pitch axis. Mass centralization works.
It's too bad Avon quit making their old street tires. They gripped much better than BT45's. Not as well as Avon race but night and day better than BT45's. At some point while you are getting better and using the throttle more and the brakes less you have to really start working with your tires. Most bias ply street tires are always "off" grip wise compared to good tires. When good tires are good, you can go WAY faster on them but good tires "go off" and when they go off they aren't any better than normal tires. You have to constantly adjust your riding to the condition of the tires especially if you can't afford to swap tires at the first signs of your tires going off. It's easy to under ride new tires and over ride old tires. Over riding old tires can be fun IF you know they are "off"! Good luck! |
05-14-2012, 10:23 AM
#35 |
Oddometer: 914
I suppose one is bound to have some issues first race. It's good you are taking it in stride and moving forward. I hope you have better luck with your next race.
I'm getting to the point where I would like to do this with my /5. It's a tough call because It's such a joy to ride in the first place. For now I'll live vicariously through people like you. |
05-14-2012, 04:07 PM
#36 |
Oddometer: 1,133
It's hard to see from the photo how that shifter thing is held onto the shaft. By a pinch bolt I guess. It looks to me that it's a fairly solid lump of alloy and may be a bit inflexible to be cruched onto the shaft by a small 6mm bolt.
I use the genuine part from BMW. It's steel and is attached by a bolt up the middle into the shaft. That's on a 5 speed . I would really look into replacing that with something made of steel.
05-14-2012, 04:32 PM
#37 | |
Mad Scientist
Oddometer: 3,005
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
05-14-2012, 04:55 PM
#38 |
Oddometer: 1,133
Can you use a 5 speed in US vintage racing?
05-14-2012, 05:16 PM
#39 |
equitem casus
Oddometer: 2,634
5 is okay
Yes. Not a problem using a 5 speed gearbox. At least for USCRA.
The problems I had were not because of the parts. If installed correctly, I think I would have had more success. Like I said, experience was gained.
05-14-2012, 05:17 PM
#40 |
equitem casus
Oddometer: 2,634
video from the weekend...
05-14-2012, 05:21 PM
#41 | |
Oddometer: 1,133
That's good. Hopefully the selection issue will be easily solved. Good luck for next time. FWIW I did a bit of racing last weekend and there were so few entries they put the three of us in with "pre Modern" which included 916 Dukes and YZF 1000s. We only got lapped once and because there were trophies down to third place, we all got one!!
05-15-2012, 02:03 AM
#42 |
enamoured
Oddometer: 2,517
That video was fantastic - I was leaning in my seat & nearly caught that guy on the outside
![]() Voltaire has finally sucumbed to pressure & has started his own racer thread. i figure if you're reading this you'll be interested. http://advrider.com/forums/showthread.php?t=790873 Padmei screwed with this post 05-15-2012 at 02:13 AM |
05-15-2012, 02:28 AM
#43 |
Oddometer: 1,133
What kind of camera did you use for the video?
I bought a cheap $60 MD80, it's really susceptible to vibration, even the BM had to much for it.
05-15-2012, 03:24 AM
#44 |
equitem casus
Oddometer: 2,634
GoPro video
The video footage was captured with a GoPro HD camera. It has pretty good stabilization. This footage was done on two bikes, but both had the camera mounted to the handlebars.
I used iMovie on an Apple MacBook Pro to edit and compile the video.
05-15-2012, 08:32 AM
#45 |
Oddometer: 77
didn't expect to hear jim croce when i pressed play
![]() nice video |
