03-05-2013, 03:55 PM
#241 | |
Oddometer: 37
I have a (Ca Plated ) 2013 Husaberg FE 350 with 13/52 gearing and mine will do 85+ mph. I also come in at a trim 300lbs.
2013 Husaberg FE 350 Ca plated |
03-05-2013, 04:25 PM
#242 | ||
Oddometer: 175
03-05-2013, 04:55 PM
#243 |
Resident
Oddometer: 78
Going to be checking the valves for he first time. Have many of you had to adjust the valves on the first check? Also going to install the dirt tricks tensioner at the same time. Thanks.
2013 KTM 350 EXC-F |
03-05-2013, 06:34 PM
#244 | |
Oddometer: 4
This thread has been very helpful and informative.
03-05-2013, 07:26 PM
#245 |
Oddometer: 190
how many hours on the bike? the dt tensioner cant be installed until 20 hours
"These things are like intellectual viruses loose in the theater of discourse, and you can’t really argue with these people, because they don’t understand the rules of argument," also noting that "the howling tide of unreason beats against pure fact with incredible fury." Terence Mckenna 2006 Ducati Multistrada620, 2013 KTM 350 exc-f |
03-06-2013, 06:01 AM
#246 |
Resident
Oddometer: 78
3 hours on the motor. Whats the reason the tensioner cannot be installed until 20 hrs?
03-06-2013, 07:10 AM
#247 |
Oddometer: 471
I would guess that installing a manual chain adjuster is not recommended "right away" is to let the chain have it's initial stretch. The stock hydraulic adjuster will take up the little bit of slack as it occurs, but a manual adjuster will not.
Edit - I see that the DT tensioner is *not* a manual tensioner. Now, I have no idea why they recommend waiting...unless it may exert too much force on the new chain?
Street bikes for the street. Dirt bikes for the dirt. Let's keep it that way. gplassm screwed with this post 03-06-2013 at 07:16 AM |
03-06-2013, 07:12 AM
#248 | |
Oddometer: 1,048
What I am trying to figure out is whether the computer mount puts the whole thing above the headlight mask, or if it has to be bent around it.
I really like Paul' stuff, but I may end up going back to a Scott's or BRP damper mount and Fastway style inner mounts for the HDB bars. Quote:
2013 KTM 350EXC-F 2007 KTM XC300 (for sale!), 2005 BMW R200GS, 1984 Kawasaki GPz 750 |
03-06-2013, 07:19 AM
#249 | |
Navigate 2 Adventure
Oddometer: 2,106
Chris Crawford (Crawford + 4 kids = Crawdaddy http://www.CrawdadOffRoadEvents.com http://www.DualSportMoto.com http://www.WhereAmIRiding.com |
03-06-2013, 07:23 AM
#250 |
Oddometer: 1,048
03-06-2013, 08:53 AM
#251 |
Resident
Oddometer: 78
Just received an email from dirt tricks saying that hours aren't critical to install the tensioner.
03-06-2013, 08:57 AM
#252 |
Oddometer: 190
According to the dt instructions the reason is their tensioner does not compress as far as the stock, so the timing chain needs to break on to give the slack necassary. Otherwise it will put too much pressure on the chain.
03-06-2013, 09:00 AM
#253 | |
Oddometer: 175
03-06-2013, 09:31 AM
#254 |
Oddometer: 2,106
That's a better setup than I'm using......the old models have the 4 indicator/tube holders mounted on the bottom of the protector as opposed to the top.....the top is way better.......mine are hard to see.....not that I ever look at'em anyway
![]() Planning on topping off the 5.3 Acerbis tank this weekend and heading out on a good/long ride.......haven't brimmed that beast of a tank before.....I'm actually looking forward to it......I want to see just how heavy the bike feels with 5.3 gallons up front.....
03-06-2013, 09:34 AM
#255 |
Resident
Oddometer: 78
Correct. He said as long as the oem tensioner (when its removed) is the same length or longer than the dirt tricks tensioner in its collapsed position, you are good go.
