Old 03-15-2014, 03:00 AM   #1396
indypup
indypup's Avatar
Oddometer: 3,741
I managed to get the plug out. There's no hole in the plug itself so I cleaned it and the plug hole in the stator cover. I put blue loctite on it and tightened it down pretty good. I'll see if it leaks tomorrow.
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 03-15-2014, 12:54 PM   #1397
LU-E
Oddometer: 10
T Removal
Originally Posted by Rider1 View Post
I bought mine from Blais racing services, link: http://blaisracingservices.com/
It doesn't remove the T.
I don't understand why someone would want to?
Unless your bike is different than mine, the T is integral to the cooling system.
Does anyone have "real life" experience or data that shows removing the thermostat is a bad thing? I ask because I've read a lot of peoples opinions on this, but have yet to see anyone post any personal negative experience regarding thermostat removal.
My issue comes after installing an Acerbis tank, my thermostat housing hits both my tank and my radiator, eventually it will destroy my radiator.
I'm not trying to start a "thermostat war" here, I would just like to see if anyone has actually removed their t-stat and has had a negative effect.
LU-E screwed with this post 03-15-2014 at 03:59 PM
LU-E is offline   Reply With Quote
Old 03-15-2014, 09:36 PM   #1398
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 201
As u know from above I've removed my bike's Tstat and I have a direct, in the radiator hose, real time temp readout that I can monitor while riding. If I'm cruisin' say 30 mph or greater I see the temp run around 160 degrees F. This is with an OAT around 80 degrees as it was today. When running slow of course the temp bumps the limit I have set on the controller for the fan and the fan kicks ON. With the fan running the temp stays around 220 but can go up (I've seen 240) if you're really working the engine and slow speed.......we do have a little bit of sand here in the desert.
So.....bottom line....I don't see any downside to having no Tstat for the weather and conditions I ride in anyways. The factory Tstat is a 158 degree unit.
Dave
Husqvarna FE250...Street Legal
Rider1 is online now   Reply With Quote
Old 03-16-2014, 03:36 AM   #1399
thetable
thetable's Avatar
Oddometer: 1,425
Dave, did you have a temp gauge in before you removed the tstat? I know on some race cars, we'd actually see higher temps without a thermostat.
thetable is offline   Reply With Quote
Old 03-16-2014, 06:57 AM   #1400
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 201
Yes I did and haven't noticed any differences to tell ya the truth......but I've only got about 500 total miles on the bike.....about 400 with Tstat.
I plan on riding a moderate amount here in the next couple/three months before the heat arrives and of course will be monitoring water temps and will report anything unusual.
Here's the unit that I use from TrailTech: http://www.trailtech.net/digital-gau...rature/722-eh5
And here's a really cool option to replace the thermostat and has a built in temp probe.....but don't know if it would fit with aftermarket gas tank like my Acerbis 3.0 gallon: http://www.trailtech.net/thermostat-...its-ktm-models
Dave
Old 03-16-2014, 07:25 AM   #1401
scudrunner82
human whoopy cushion
scudrunner82's Avatar
Oddometer: 2,160
I don't see how removing the thermostat in a place like Nevada would be a problem. However in places that actually see cold temperatures I would think the engine would never get up to temp which is not good either. A couple weeks ago I was riding on the frozen trails and it was 7 degrees F. Even WITH a T-stat it took a while to get some heat in the radiators.
JMHO of course.
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is online now   Reply With Quote
Old 03-16-2014, 08:45 PM   #1402
LU-E
Oddometer: 10
JMHO of course.
Keeping the thermostat in makes sense to me if I was riding in 7 degree weather, a majority of my riding is in Utah, Arizona, Nevada, and California, where I don't do a lot of riding with weather below freezing. I think I will buy a temp gauge like the one Rider1 uses to at least monitor my temps.
Thanks for the replies.
Louie
2014 KTM 350EXC-F (My first orange bike)
Old 03-16-2014, 09:38 PM   #1403
scudrunner82
Oddometer: 2,160
That sounds like a smart plan
Old 03-16-2014, 11:58 PM   #1404
dionbilt
energetic beginner
dionbilt's Avatar
Oddometer: 256
We drag race, and you dont need a thermostat for a race engine. But one thing on those motors, if the water flows too fast it cant transfer the heat properly. So we knock the center out to slow the water down. I would guess this might be the same concept for a bike. We also put a water wetter product in the radiator to help break the water tension, since we only run strait water.
dionbilt is offline   Reply With Quote
Old 03-19-2014, 02:49 PM   #1405
jeffjones
"offroad shit"
jeffjones's Avatar
Oddometer: 158
anybody looking for a good deal on a steering stabilizer? I bought a new scotts setup, but before I mounted it I mounted up this GPR v3 setup I just took off a 06 300 xc and go figure it fit good and worked properly mounted up (only thing I was unsure of was the frame tower pin mount really)
http://www.ebay.com/itm/321355200670...witem=&vxp=mtr
Blah
jeffjones is offline   Reply With Quote
Old 03-19-2014, 09:01 PM   #1406
Crab bait
Oddometer: 249
I took my 350 xcfw out for a 2 hour mudfest today. 3000 feet of elevation gain with a lot of roots, rocks and deep drainage ruts. What a great bike!
Crab bait is offline   Reply With Quote
Old 03-23-2014, 09:16 PM   #1407
bendbiker
Oddometer: 2
globletrottin rack
Originally Posted by Nice_Rumble View Post
Did you sell Globetrottin rack and will you share your thoughts about it? I need a rack for the multiday adventures with my week old 2014 350EXC!!!
bendbiker is offline   Reply With Quote
Old 03-23-2014, 09:55 PM   #1408
JonU
Oddometer: 822
After 80 hours I finally had to replace the Headlight bulb. The hi beam went out at around 50 hours and the low beam went out tonight as I was headed down the street to the barracks tonight. It has been replaced with one of the Sicass Racing bulbs and I'll see how long it lasts in comparison.
JonU is offline   Reply With Quote
Old 03-23-2014, 10:15 PM   #1409
indypup
indypup's Avatar
Oddometer: 3,741
Old 03-24-2014, 10:52 AM   #1410
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,241
Headed out on an "overnighter" this past weekend......5.3 gallons, camping gear, and no particular destination......
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Times are GMT -7.   It's 09:59 PM.
