Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 04-25-2012, 01:40 PM   #1
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,537
Windows Version Garmin MapInstall 4.0.0 Released Officially
This new version seems to be good news for the New Generation of Garmin users, people who've got the Montana, Oregon, 62/78, eTrex 30 etc, but not so good if you're a Legacy gps user with a 60/76CSx or eTrex, etc.
HardWorkingDog received the following from a Garmin Tech about version 4.0.0 for Mac, and I assume it'll be the same for the Windows version:
"Yes, I am sorry but the newer version of MapInstall is going to be a bit of a challenge with the legacy units, such as the GPSMAP60CSx.
Mainly because the only image file the device can read is gmapsupp.img whereas the newer units can read named mapping. Whenever one sends mapping to a legacy unit it will automatically replace what is on the SD card, so the application is not going to prompt that there is a file there. "
Here's the Change Log for version 4.0.0
Changes made from version 3.15.0 to 4.0.0:
Added ability to automatically send all current map products to newer devices if possible.
Added ability to send full map products to newer devices rather than needing to select individual map tiles.
Added display of how many map tiles are selected.
Changed the map selection page to no longer list map products that are locked for the selected device.
Here's a couple of screen shots I made on my computer today. (Never mind the yellow arrow - it's there to obscure my serial number)
Download it here:
http://www8.garmin.com/support/downl...ls.jsp?id=3291
Emmbeedee screwed with this post 04-25-2012 at 08:22 PM
Old 04-26-2012, 09:51 AM   #2
BKMLWR
Wondering around...
Oddometer: 4,579
Does this program do something mapsource or basecamp can not do?
I know basecamp mac needed an install program for maps but is that true for Windows version too?
I already know any time I send a map(s) to my 60csx I'm going to wipe out what ever is there...
Sometimes I get off the bike before it has come to a complete stop....
Another Proud Small Scale Faker......
Praise You In This Storm
LifeSong
BKMLWR is offline   Reply With Quote
Old 04-26-2012, 10:17 AM   #3
Spiritwalker2222
Oddometer: 112
It's for installing maps on GPS's.
Something most people will only use once per GPS.
Spiritwalker2222 is offline   Reply With Quote
Old 04-26-2012, 10:17 AM   #4
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,537
Even BaseCamp for Windows has a separate map installer, and that's what this is. As described, this is of much more use to new gen gps owners - it'll save lots of time choosing tiles, and juggling files. If MapInstall works as it promises, it will load the maps to compatible gps units into separate files, ultimately making it easier to keep individual maps updated on the gps.
As long as you know that using the new MapInstall with your 60 will wipe out existing maps, as Mapsource would do too of course, then there's no problem.
In fact it makes a lot of sense on 60/76 units to rename the file called gmapsupp.img to a different name before loading new maps. There's no reason why the file MUST be overwritten (it's not re-using the bits, after all) and if the new maps you load don't work, or even if they're a completely different mapset for an area you may be visiting, then after that trip is over you can rename your original mapset back to gmapsupp.img to get your old maps back, or to keep multiple mapsets in the gps.
Emmbeedee screwed with this post 04-26-2012 at 10:25 AM
Old 04-26-2012, 10:19 AM   #5
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,537
Surely you jest.
If you're a gps geek you're always loading maps as you find them. I've got a bunch of OSM maps which are constantly being updated, so they need the updates applied.
In fact that's one of the advantages of OSM maps - much more frequent map updates than Garmin maps.
Old 04-26-2012, 10:28 AM   #6
BKMLWR
Wondering around...
Oddometer: 4,579
ImagetoGPX opens up a new need to change maps more often on the 60 series
LifeSong
Old 04-26-2012, 10:49 AM   #7
Spiritwalker2222
Oddometer: 112
Originally Posted by Emmbeedee View Post
Surely you jest.
I consider myself a GPS geek, but I don't think the OSM maps really have much to offer. They don't seem to have the good trails. Just some unmaintained roads. I mostly use tracks to navigate. But most of the time I'm on a dirt bike and not a dual sport.
Does this mean I lose my GPS geek status?
Old 04-26-2012, 10:52 AM   #8
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,537
It's in jeopardy, that's for sure.
Seen this?
http://trailmaps.torontogeocaching.com/node/3
Old 04-26-2012, 07:06 PM   #9
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,687
I have this same question, which I haven't seen the answer to yet. If I have a 76CSx, does this program do anything that MapSource does not do?
New desert racing frontiers
It will be Devilish !
HogWild is online now   Reply With Quote
Old 04-26-2012, 07:15 PM   #10
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,537
Not that I can tell, but then my 76CSx days are gone. It works well with my Montana, though.
Old 04-26-2012, 07:39 PM   #11
Spiritwalker2222
Oddometer: 112
I see the concept. There just isn't many trails for dirt bikes.
I played with making map overlays a few years ago, but it's so much easier to manage tracks.
But if there was a source somewhere with a lot more trails that were only for dirt bikes, well...
Spiritwalker2222 screwed with this post 04-26-2012 at 08:02 PM
Old 04-27-2012, 07:25 AM   #12
BKMLWR
Wondering around...
Oddometer: 4,579
as mentioned above, it is the map installer for basecamp. If you are still using mapsource with a 76, the program does not do much for ya...
LifeSong
Times are GMT -7.   It's 11:24 PM.
