Old 04-26-2012, 03:33 PM   #16
MikeFromMT
Past Tense
Oddometer: 3,994
First you'll need to kill that Beaver or you'll just be wasting your time.
Depending on the size of the dam chainsaws, ropes, chains will do just as good of a job. Not quite as fun as blowing it up though. If it's a big assed dam you'll need some serious bang, I've seen them 15 feet high and 20 feet thick at the base and 100+ feet long, another was about 1000 feet long and 3 feet tall, I've ridden across several.
You're required to post the video.
Tommy, what you ridin' there?
Uh... Roll top desk!
Do I look like a man with a plan?
MikeFromMT is offline   Reply With Quote
Old 04-26-2012, 03:44 PM   #17
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,256
The dam is on the upstream side of a road which has a culvert running through it. The dam is completely inaccessible; the upstream side is underwater, the downstream side is the road, the dam of mud and sticks completely blocks the culvert. Chainsaw is a complete waste of time.
Killing the beavers will not be required. I had something of my own creation in place for years and was completely effective until two years of extreme drought left the pipes high and dry. They subsequently collapsed and somehow disappeared.
http://www.clemson.edu/psapublishing/pages/afw/afw1.pdf
Physics, gravity, and law enforcement are the only things that prevent me from operating at my full potential
Fe Man screwed with this post 04-26-2012 at 03:49 PM
Fe Man is offline   Reply With Quote
Old 04-26-2012, 03:45 PM   #18
Smithy
Avoiding the Skid-Demon
Smithy's Avatar
Oddometer: 8,093
They sell a bulk order, you mix it and put it into your own container. I don't see why packing a couple wrapping-paper tubes full wouldn't work, and if you originate the blast at one end, it will propagate to the other, forcing energy downward. If you put another charge at the bottom, say a zip-lock full, and set the tube on top of that, you might get good results. I'd be tempted to use a ziplock of smokeless propellant, but again, have no idea of the legality of that.
Don't try this at home, check your local laws, etc etc ad nauseum.
Proprietor of The Tidewater Forge Hot iron is my passion. Fire is my mistress. Let's dance.
35 Years of Scouting Blog for Bushcrafting and Boy Scouting experiences.
Smithy is offline   Reply With Quote
Old 04-26-2012, 03:49 PM   #19
green hell
yawning or snarling
green hell's Avatar
Oddometer: 19,948
yeah, we tore out a dam in canada one year so we could get our boats through the channel. came back about 14 hours later and the damn dam was bigger than the day before.
before the tear out:
the next day:
it's a good thing we were leaving a boat on the other side.
there was another dam further up that raised the water level almost three feet and created a huge wetland.
lookin' for a place to happen;
makin' stops along the way - the tragically hip
needless dickery
green hell is offline   Reply With Quote
Old 04-26-2012, 03:53 PM   #20
Grreatdog
Grreatdog's Avatar
Oddometer: 11,129
The best beaver dam I ever saw was perfectly round. They built the dam around a storm water pond overflow and their lodge in that new zombie proof concrete box and pipe. The devious little bastards flooded a just planted forest mitigation area around the storm water pond and ate themselves a couple of hundred tasty new saplings before anybody noticed. They pretty much wiped out every new store bought tree on two or three acres. The developer was not amused.
525EXC, 640 Enduro, XT200
Grreatdog is offline   Reply With Quote
Old 04-26-2012, 03:56 PM   #21
troidus
Oddometer: 14,403
It sounds like you don't mind the dam, and just want to reduce the amount of impounded water. Can you use a horizontal boring machine and run through the dam through the culvert from the dry side of the road and run some PVC through the borehole? It might be faster, easier, and safer than blasting, and might last longer.
troidus is online now   Reply With Quote
Old 04-26-2012, 04:28 PM   #22
flyinfuzz
2 Quarts low
flyinfuzz's Avatar
Oddometer: 1,867
ADVMAX to the smoking unstable phone please
Cotton says : This is as screwed up as a rope with 3 ends
flyinfuzz is offline   Reply With Quote
Old 04-26-2012, 04:33 PM   #23
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,256
dude; horizontal boring machine....
Maybe I could just get the Air Force to drop a laser guided missile on the upstream side of the dam; or may the US Army Corp of Engineers could come in an install a set locks...If I was going to acquire a horizontal boring machine, I'd just rent a track hoe and un-fuck the mess in one scoop!
I'm talking about a couple of hundred dollars worth of destruction so I don't have to get in that filthy fucking water up to my nutsack and dig it out myself, not a highway building project.
Boom!
Install new pond levelers, aka drain
Beavers go the fuck away because there isn't enough water for them to get their beaver jollies!
Problem solved.
Old 04-26-2012, 05:12 PM   #24
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,622
A battery activated model rocket ignitor will ignite whatever you want it to, if you rig it properly...
Tannerite sounds much more fun (and maybe more legal than a large pile of gunpowder) and is readily available at Sportsman's Warehouse.
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 04-26-2012, 05:40 PM   #25
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,625
I actually have certifications in Explosives Engineering and did two years of blasting cap research with the host of the Discovery Channel's short-lived show The Detonators.. but, I got nothin'.
Take a video of whatever you end up doing!
crazydrummerdude is offline   Reply With Quote
Old 04-26-2012, 05:56 PM   #26
AKjeff
AKjeff's Avatar
Oddometer: 5,182
Originally Posted by hutch451 View Post
Hold my beer and whatch this!
Someone had to say it
"We can choose to know better or choose to be bitter." OldRoadToad
AKjeff is offline   Reply With Quote
Old 04-26-2012, 05:57 PM   #27
straightrod
Oddometer: 1,311
I am, still laughing over the horizontal boring idea.
straightrod is offline   Reply With Quote
Old 04-26-2012, 06:17 PM   #28
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,699
We had an infestation, state wildlife folks have a guy on contract. This was a dammed up spring, dam was maybe 100ft long, guy cuts a hole in their dam and puts out a killer trap. I think he got a dozen, then tore out the dam. It was flooding a big patch of woods, drowning trees, and high water blocking entrance to a farm field.
My point being, if they are creating a nuisance, maybe the state will take care of it as they did for us.
katbeanz is offline   Reply With Quote
Old 04-26-2012, 06:59 PM   #29
Chuck289
Air cooled
Chuck289's Avatar
Oddometer: 2,262
You got pics of the dam in question?
-Charles
"This is an environment of welcoming, and you should just get the hell out of here" - Michael Scott
Chuck289 is offline   Reply With Quote
Old 04-26-2012, 07:13 PM   #30
ysr612
ysr612's Avatar
Oddometer: 10,068
that is one cool toy
ysr612 is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 11:44 PM.
