Old 04-26-2012, 03:07 PM   #1
JimRidesThis OP
Local celebrity
JimRidesThis's Avatar
Oddometer: 273
Talking Yet another XL600 project...
About a month ago someone made me an offer...
“You look like an idiot. Would you like to swap your nice 1980 XT250 for a dead 1985 Honda XL600R ‘project’ bike with unknown history?”
I know, I know, that doesn't sound like much of a deal, but being a closet fan of big singles I committed the cardinal sin of trading my road-legal runner for a non-runner with the irresistible added attraction of ‘some bits missing’.
Somewhere in there and a small box of bits is an XL600R. Honest!
And so that honeymoon period of garage time with a new bike project began. That time when you really get to know what you've bought into. Usually this consists of finding all sorts issues that you didn't spot when you actually inspected the thing. "How come I didn't spot the oil dripping out of drain plug because the thread's stripped ?", "Is that a 6" nail stuck in the front tyre?" that sort of thing. Well, so far it seems that karma has something slightly different in mind for me and the XL.
As I said, this XL is a totally unknown quantity. As I haven't heard it running, the first task is to get it fired-up before spending any money on it. Unusually, for this to happen, the engine has got to come out of the frame first! This is because karma obviously wasn't on the side of 'a previous owner', who at some point decided to cut a 6 inch section out of the frame tube, presumably to get around the problem of a seized top engine mount. There were tell-tale traces of engine oil everywhere; possibly because karma hadn't finished with our man yet, and didn't tip him off that the tube he was cutting held oil!
Ooops
The top engine mounts didn't come with the bike, so before welding a new piece of tube in I needed to know how and where these fit. A transatlantic message or two later and Advrider inmate, Brucifer, very kindly measured his XL frame giving me the measurements I required (he also had the idea of making a thread out of this rebuild - so if you're already bored, take it up with him!)
Happily, the rest of the bike doesn't seem so bad. The tyres are hardly worn. The wiring loom is in very good shape with just a couple of flag connectors to replace. Most of the fasteners are original and not chewed up, though two helicoils are needed on 6 mm stud holes in the cam cover. The first of the missing, but essential, parts - the bracket that holds the coil and CDI unit under the tank and the top engine mounts - have arrived from breakers in Germany and France via Ebay. I've selected some likely looking steel tube to repair the frame and my MIG welder is warmed up and ready.
So, everything is set, you're welcome to come along for the ride, but it might take a while...
JimRidesThis screwed with this post 05-01-2012 at 12:43 PM
JimRidesThis is offline   Reply With Quote
Old 04-26-2012, 03:27 PM   #2
kubiak
Oddometer: 4,829
im in!
Old 04-26-2012, 08:04 PM   #3
brucifer
brucifer's Avatar
Oddometer: 2,427
Hey, HEY! Now were talkin'!
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 04-26-2012, 08:59 PM   #4
Tech23
Tech23's Avatar
Oddometer: 476
Awesome...a home made total loss lubrication system. IMO it would have worked better is the PO would have shoved (yes that's a mechanical term used in many shop manuals) a section of rubber hose over each end of the cut frame tube...removed one intake and one exhaust tappet cap and routed the hoses into the tappet cap holes letting the oil dump into the engine rather than lubricating the top of the rocker box. I give him an A for effort though, oil that recirculates ends up with contaminants from the combustion process,not to mention metal particles from the usual wear and tear of metal to metal part contact....brilliant I say. Oil tanks, sealed crankcases, and motor mounts are all over rated anyway.
Tech23
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 is offline   Reply With Quote
Old 05-01-2012, 12:34 PM   #5
JimRidesThis OP
Local celebrity
Oddometer: 273
Question Procrastination is the thief of time...
I'm considering my next move regarding the frame repair.
One thing I do know is that my current welding skills are not going to produce a good oil-tight job. Do I practice my welding until I'm 'good enough' or farm the job out to someone competent? Of course, I'm going to go down the practice-my-welding route. Anyway, the guy I got the bike from says he has a spare XR frame (of a similar year he says) that I can have. It'll probably turn out to be for something completely different and, for some reason, I'd like to keep the standard frame if possible. But I could use the XR frame to 'test' the engine while I improve my welding skills. The XR frame should arrive next weekend
In the meantime, to get in some garage time, I took the engine out of the frame and got it onto the work bench.
I was hoping that a brief look under the covers would suggest an engine strip wasn't necessary and, generally, it didn't look too bad inside. A brief peering, prodding and measuring session around the clutch, crank, cam-chain, cam bearings, etc and everything seemed OK. The oil residue was fairly clean (like new oil) and there were no metal fragments, flakes, grit or collections of grunge in the places where you might possibly expect to find such things.
I wanted a first look at the radial valve layout too so I lifted the rocker cover too. The cam and rockers all seem in reasonable shape (these are uncleaned parts, straight off the bike) with fairly minimal scoring or wear evident.
Silicone-gasket overkill on the clutch and generator cases. However, I've not recovered any bits of silicone from the oil filter or strainers.
Finding this is a bit worrying. The broken bit is the automatic decompresser cam thing that's operated by the kick-start, that's the kick-start needle bearing below it in the picture. So far I haven't found any chunks of it inside the engine so perhaps it's an 'old injury' that was never fixed? As a precaution I'll strip the oil pump to make sure it's clear of any debris and flush the engine out as best I can. I suppose I should strip the engine, split the cases and make sure there's no metal debris in there, but I'm tempted just to put it back together and take the chance. False economy?
In the meantime, back to the frame...
JimRidesThis screwed with this post 05-01-2012 at 02:47 PM
Old 05-01-2012, 05:46 PM   #6
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
You're a brave soul...
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 05-01-2012, 06:49 PM   #7
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,081
Originally Posted by cyclewizard View Post
you're a brave soul...
+1
Carter Pewterschmidt is offline   Reply With Quote
Old 05-01-2012, 07:51 PM   #8
INTMD8
Oddometer: 124
Probably more than I would take on (but it's not too hard to find a decent XL600r project around here).
I wish you best of luck!
I haven't done any looking but would a replacement frame be cheap enough to make fixing your current one not worth it?
And good to see you posting CW. Hope you didn't forget about me, I've logged in every day for the past year hoping to see a PM from you
86 xl600r.
INTMD8 is offline   Reply With Quote
Old 05-01-2012, 08:23 PM   #9
kennythetiger
Kennythetiger
kennythetiger's Avatar
Oddometer: 53
Decompression CAM
You'll wanna fix that, they are a real pain to start without it. Make sure that you orient it properly before you re-install the cover, they can snap pretty easily if you tighten them down when oriented the wrong way. Make sure the spring on the cam chain adjuster is good. I've got the motor out of mine for the 3rd time before I figured it out.
kennythetiger is offline   Reply With Quote
Old 05-01-2012, 08:42 PM   #10
notarat
notarat's Avatar
Oddometer: 333
Thumb
Subscribed!
notarat is offline   Reply With Quote
Old 05-01-2012, 08:54 PM   #11
stiggs13
stiggs13's Avatar
Oddometer: 203
stiggs13 is offline   Reply With Quote
Old 05-01-2012, 09:26 PM   #12
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
Yeah, I'm not so sure about that 250 to 600 swap based upon your description either
At least I now don't feel so bad about missing some items during my pre-purchase inspection of my 84 XR500
That frame should prove interesting to fix. If the other frame you get is from an 83-84 XR500, then I think there might be a better chance of the top engine mounts matching the XL6. But you will tell us all about it I'm sure
Another thought, did the frame get cut because someone wanted to remove the valve cover without removing the entire engine? That job can be done on newer XRs, but the XL6 and my XR5s don't have enough clearance between the cover and the frame member to remove the valve cover with the other engine mount bolts still attached. Although I agree that the seized mount is the more likely explanation. I may have a pair of upper engine mounts from an XL6 in my spares box. Let me know if that is something you would want, but I suppose you will make your own set to match your repairs.
You should double check that right side cam bearing. The shield/seal on one side of the bearing should be facing the right side next to the oil cup/chamber. That bearing looks to be installed backwards, or worse its the wrong bearing.
I updated my 84 oiling system to more modern components. Its a straight swap and I you can read about our discussions regarding the dry sump RFVC oiling system on this thread:
http://www.advrider.com/forums/showthread.php?t=552341
Ghost_Mutant is offline   Reply With Quote
Old 05-03-2012, 12:07 PM   #13
JimRidesThis OP
Local celebrity
Oddometer: 273
Question
Thanks for the heads-up on that bearing, I would have missed that completely. Turns out it's the wrong one i.e. no shield. Typical! Presumably that means that at some point the camshaft might not have been properly charged with oil, etc. I'm going to have to replace that bearing with the correct type so as the cam's coming out I might as well take the head off too and clean up the valve faces and so on.
Any hints on removing the cam chain tensioner?
Interesting and useful stuff, thanks again :-)
I wonder if that's what happened to it?
JimRidesThis...
1985 XL600R "Tamworth"
1992 TDM850 "Ivy"
1995 R1100GS "Herr Flick"
JimRidesThis screwed with this post 05-03-2012 at 02:48 PM
Old 05-07-2012, 01:02 PM   #14
JimRidesThis OP
Local celebrity
Oddometer: 273
Frame progress...
At the end of the first post in this thread I'd just come across this unorthodox engineering solution...
I also mentioned that the guy I got the bike from had offered me an XR frame he had as a spare. I was secretly hoping this might be a straight swap-in . Well, I'm not sure what year or even size XR the frame was but there was no chance of it being an easy swap, it was from a totally different era. However, I did spot a likely looking piece of tube with mount holes already welded in that I could repair my own frame with. In terms of welding, these 'cross tubes' were always going to be the hardest part of the job for me to get oil tight.
That's as close as you want to get to my shoddy welding! Even from this distance you can see why I was eager to save myself four more-awkward welds.
The mounting holes on the inset tube are 10mm closer together than the original XL head mounts so I'll have to make some new ones, but some progress has been made.
Back to the engine...
JimRidesThis...
1992 TDM850 "Ivy"
Old 05-07-2012, 06:07 PM   #15
brucifer
brucifer's Avatar
Oddometer: 2,427
Looking good, Jim. Don't worry too much about your welds---the tank will cover them. Just giving you a bad time.
Times are GMT -7.   It's 01:41 AM.
