08-01-2012, 02:34 PM
#31 |
Local celebrity
Oddometer: 124
These images are from the Honda workshop manual here... http://www.hondaxl.it/manuali.htm (Section 10)
![]() There's a specific reference to a bearing plate in right-hand side crankcase 'behind' the main bearing. My XL doesn't have one and there doesn't seem to be one in the other photos in the manual (you can see the bearing cage, not a plate)... ![]() So, what's the story with this bearing plate? Has your XL got one? Should my XL ('85 model) have one? JimRidesThis screwed with this post 08-01-2012 at 03:18 PM |
08-01-2012, 02:39 PM
#32 |
Oddometer: 7,974
Your wrong. The plate goes on the LEFT side of the crank between the bearing and the case. What it does id shield the bearing and keeps oil in the crank area. Never seen a Honda big single without one.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
08-01-2012, 03:17 PM
#33 | |
Local celebrity
Oddometer: 124
My earlier post should have said my XL didn't have one. Now corrected.
Of course, I can see that you're right from the photos (i.e. it's a left-hand side crankcase in the picture), but the text is unambiguous (and then confused). "Install the new right crankshaft bearing and bearing plate" "Install new left crankshaft bearing into the right crankcase" (that one I was going to ignore )![]() ...plus I still haven't removed the rotor or crank from the left side crankcase yet so I can't get a good look at the left main bearing. Thanks again. I'll stop worrying about it now
08-01-2012, 03:20 PM
#34 |
Oddometer: 7,974
Carry on. Next....
08-01-2012, 07:32 PM
#35 |
Cheesehead Klompen
Oddometer: 113
Keep it up and you'll end up with a cool big ol' thumper, gobs of torque.
I bought my 83 XL600 as a $200 chassis/basket case, complete but only the crankcase in the frame. Kid I bought it from said he tore it down because of a bent valve, and then quit the project. Good enough challenge for me! I replaced the bent valve, freshened up the cylinder, new rings, bolted it all back together and it fired on the 5th kick, no decomp lever. I had a cheapo running thumper for less than $300. Did some trail riding and got some dirt on it. But, when climbing a hill in 2nd gear, I found my error in using the original cam chain. See, I thought the cam chain installed real easy, but simply went ahead with it. Yup, worn cam chain skipped teeth under load and the piston wacked the intake valves. Bent them both. So I torn it down, replaced the cam chain, chain guides, intake valves, few other parts. Again, bolted up, and it fired again after a few kicks. Been good ever since, just a bugger to start sometimes as it is a big single. I need to get the decomp lever/cam working again. Since I have since bought a 2004 DRZ400E (electric start) my plan is to turn the XL600 into a retro-motard/street-tracker. I still like the bike. But if I were you I'd replace the cam chain and guides before putting it back together. One thing about the big ol Honda singles is they tend to use up cam chains.
When life throws you a curve,.....lean into it! |
08-02-2012, 01:51 PM
#36 |
Local celebrity
Oddometer: 124
Thanks Andy. A cam chain and guides are on the shopping list
![]() Meanwhile, back at the ranch... ...the tear down continues. This is roughly where I'd got to; 'cases still together but ready to split, rotor still attached. ![]() ![]() From there it was easy enough to split the 'cases... ![]() ![]() Hmmn, Hermatite Orange ...pull out some bearings, clean the cases up a little... ![]() ![]() ...and start ordering new bearings and seals. ![]() Gearbox bearings and seal, clutch side ![]() Mainshaft bearing and seal For UK info, the bearings and seals came from Simply Bearings in Leigh (do a Google search). These were ordered using their online service but didn't list the right sizes for the main and balance shaft bearings, I'll give 'em a call. |
08-02-2012, 01:56 PM
#37 |
Oddometer: 7,974
The main and balancer bearings may be Honda specific.
08-02-2012, 02:29 PM
#38 |
Oddometer: 414
Has that been apart before? Was there no center case gasket? It looks like high temp red silicone sealant on the center cases. I wonder why anyone would risk using that stuff. Hondabond HT is great stuff, it works well enough for Honda at the factory, but I thought they only applied it to the cam cover. I don't apply it in a bead then slap the cases together...that just leaves those big globs behind like in the pictures. I apply a thin bead as uniform as possible then go back and dab my index finger on the bead all the way around the case so there is a nice uniform "textured" appearance to the sealant when I'm done. When you put the cases together you get a nice thin amount of sealant squishing out like it comes from the factory...no blobs squishing inside or outside the cases. Excess sealant inside the case can break loose and get into oil passages and starve the internals of oil flow...gotta be careful with sealant..
Tech23
CRF 150/230/ Supermoto Conversion 2004 Suzuki DR 650SM 2000 Harley Davidson FXDWG |
08-02-2012, 02:32 PM
#39 |
Local celebrity
Oddometer: 124
I reckon so Steve. The main bearings are still listed as available but the balance-shaft bearings aren't. I'll find 'em though
08-02-2012, 02:38 PM
#40 | |
Local celebrity
Oddometer: 124
This was the clutch cover. He'd obviously used a tube of the orange stuff on the crankcases and only had black stuff left! ![]() A full gasket set was delivered today! JimRidesThis screwed with this post 08-04-2012 at 02:05 PM |
08-02-2012, 03:28 PM
#41 |
Oddometer: 7,974
Balancer Bearings
From a Honda parts fich. The balancer bearings
BEARING, RADIAL BALL (16X44X13) (TOYO) Ask your bearing supplier for a bearing by these dimensions and you should be good to go.
08-11-2012, 01:45 PM
#42 |
Support all riders
Oddometer: 294
Bump
"The reward is in the doing of it" "If you don't go when you to want to go, when you do go you'll find you've gone" BM 08 Wildfire 150 Scoot "The Virus" The Virus's RR http://advrider.com/forums/showthread.php?t=826703 87 XL600R "The Cracken" deceased till further notice |
08-25-2012, 01:04 PM
#43 |
Local celebrity
Oddometer: 124
Other priorities have eaten up money and, crucially, time, so the mains bearings, balance-shaft bearings and cam-chain will all have to wait 'til next month.
I've not been entirely idle though. I've finally removed the rotor and crankshaft and got round to fixing a couple of minor case issues. ![]() A snapped drive chain caused both of these... firstly, a crack that would leak oil, near the generator wire outlet in the generator casing ![]() and a broken stud boss (top of the sprocket cover) ![]() Thought I'd try this stuff to make the repairs, I'll let you know if it's up to the job ![]() The finish is a bit rough and ready and more time with the wet and dry would have resulted an invisible repair. As you can see, after a good clean up, I decided to paint on a satin finish. I've really made a rod for my own back as I'll have to do all the other cases now too. Still, as it's brush painted, it's not going to look like it's out of a showroom Next thing on the to do list is to clear up my workspace so I can progress the top end - cleaning, inspection, valve grinding, and so forth. JimRidesThis screwed with this post 08-25-2012 at 02:15 PM |
08-25-2012, 09:02 PM
#44 |
Oddometer: 160
Steve is right about Honda specific, the left side main non-genuine bearing to the same dimensions as the 6308 Honda bearing may have a smaller diameter relief radius and will not seat right up against the crank cheek which would make it tight when the cases are assembled.
I ordered it and when it turned up the bearing guy highlighted it so I checked the crank radius and he was right but there may be different dimensions on other brands. I ordered the Honda bearing which only cost $20 more and got here quicker, it was for my XR600 but I imagine the crank specs match for bearings. I had to get genuine balancer bearings as well because they could not match them in the time frame I had to get to the ADV OCR rally but 2012 XRL bearings might be the same part. Ken
Ken 94' & 00' XR600 02 & 06 XR650L Kenno screwed with this post 08-25-2012 at 10:00 PM |
08-25-2012, 10:54 PM
#45 |
Support all riders
Oddometer: 294
Same project different garage
I working right along beside you, probly at a slower pace though
over in the main XL thread.Pete
