04-28-2012, 11:29 AM
#16 |
1:1.618
Oddometer: 4,795
I too stopped lubing modern X-ring chains. I clean occasionally with a dry teflon spray from Lowes. IMHO sticky lube attracts foreign matter, causing premature wear. There is no way a spray lube can pass by the x-rings to the roller pins.
I must work, millions of losers are depending my taxes for a check. |
04-28-2012, 11:55 AM
#17 |
Oddometer: 1,670
back to chain lube issue
True but there's a surface between the outer part of the roller and the body pin that's not protected by the x-ring or (o-ring), but I do agree that this will not exacerbate the sprocket wear only reduce efficiency. Also I'm not convinced that the x-rings are so good that you'd take the risk of water getting in, whereas a good lube that's not too sticky might help stop rusting. It is an opinion issue and subjective to many factors including the lube quality.
My 950KTM makes me feel like a little kid again......because it's so tall! |
04-28-2012, 12:42 PM
#18 | |
Not in the clique :)
Oddometer: 274
I'll take Heaven for the climate - Hell for the company. |
04-28-2012, 12:51 PM
#19 |
Oddometer: 252
I use 80W-90 gear oil and a paint brush to lube the chain occasionally after a ride. No rust and it keeps me happy.
04-28-2012, 01:11 PM
#20 | |
ow, my balls!
Oddometer: 4,603
+1 This is exactly what I do. Change the front with each oil change, swap out the rear and chain every fourth time, about every 15,000 miles. Its a bit of over kill, but I dont like broken chains, kind of hard on the engine case. ![]() I dont use chain lube with the DID ZVMX X-ring chain either. I wipe the dirt off the chain with a diesel soaked cloth every couple of days, thats about it. IMO, with modern x-ring chains, lube does more harm than good.
Riding the Americas: No Fumar Español - Terminado. ![]() _____________________________________________ crashmaster screwed with this post 04-28-2012 at 01:17 PM |
04-28-2012, 02:52 PM
#21 | |
Oddometer: 270
04-28-2012, 03:53 PM
#22 |
Oddometer: 2,129
Some interesting thoughts on non-lubing the chain! I think I have started buying into the theory!
04-28-2012, 04:41 PM
#23 |
Oddometer: 371
Scottoiler
Buy a scottoiler best thing I ever did chain is always perfectly oiled and people are going 30k miles before replacing the drive components
04-28-2012, 09:30 PM
#24 |
Oddometer: 158
I have tried both ways. With little to no lubing, my last DID X ring lasted only a little over 10k miles. That was with new sprockets at the same time. With lubing constantly I got much closer to 20k miles with the stock chain. So in my experience no lube cut my chain life nearly in half.
04-29-2012, 01:20 AM
#25 |
ow, my balls!
Oddometer: 4,603
Well, with no lube I get at least 15K miles, but I change out the front sprocket every oil change and I think that is the key. With the amount of off road riding I do, I would change the chain out anyway at that point. So, ymmv I guess.
Riding the Americas: No Fumar Español - Terminado. ![]() _____________________________________________ |
04-29-2012, 01:27 AM
#26 |
Oddometer: 2,129
Probably we could 'save' a bit on front sprockets if we reverse them once before throwing them away...
04-29-2012, 05:34 AM
#27 | |
Oddometer: 53
I measured the links very accurately. They were getting towards at the spec limit that Triumph puts in thier service manual. Actually had a long way to go to get to where the ownners manual stated they should be. For me, and my uses I think I did the right thing changing the set, but it would have been smarter for me to have changed the front sprocket about 6k miles ago, then run the chain for a bit longer. Well, that's my opinion of the moment anyway. I have seen people change their chain when it first starts getting noisy, and I have seen people run their chains until the chain breaks, skips over the teeth or some of the links won't bend. So, when someone says their chain lasted 2 million miles, you don't know what they did and the data is mostly useless. Funny though, how the old tried and true method of pulling the chain at the rear sprocket works about as good as anything........... BUT, I would add that it is also important to check the chain at different points, and inspect each link for damage as the majority of the chain can be in great shape, and one link be ready to go due to a lost o-ring or something. (I assume you do that) I saw one chain like that. |
04-29-2012, 05:54 AM
#28 | |
Oddometer: 2,129
To be honest, I never go to the lengths of inspecting every link individually, but then again, I never totally neglect my chains and always buy the safe best. For me 'safe best' is golden series DID X-ring at the manufacturer's specified width. No thin chain conversions for me. The 'pull the chain' check I do throughout the length of the chain, when I go past half my expected mileage and every time I lube the chain I put the bike on the center stand and turn the wheel to see if there is an obvious kink somewhere. |
04-29-2012, 06:14 AM
#29 |
Mine goes to 11
Oddometer: 1,551
Amazing how results differ. i've been using good d.i.d. Erv3 chains and only get about 10k kms. My rear 45 is petty much toast by then
Too but the front looks mint. this year i've switched to 17/47 as it will provide less tooth repeats on the rear. Like geek says riding style has the most to do with it. Sent from my XT910 using Tapatalk 2
The more side roads you stop to explore, the less likely that life will pass you by. ~Robert Brault. 2004 KTM 950 S GO!!!!(Blacked out),03 Beta Rev3, 1973 Rokon Trailbreaker 2x2 mk3 auto, 1999 Intruder 1500, 05 Ruckus, 90 DRBIG 800, 79 GS850My last location and updates-Ride Reports |
04-29-2012, 06:20 AM
#30 | |
Oddometer: 2,129
