Old 04-28-2012, 02:53 PM   #1
OKC99 OP
Oddometer: 37
Remove super glue from Givi reflectors
So I did something dumb to stop what I thought was a leaking reflector panel on my givi top box. The glue turned whitish and is on both the red plastic reflector lense and a little bit of black box material it self. If I apply nail polish remover, will it just remove the glue or will it also start melting/discoloring the red plastic lense and/or black top box material?
OKC99 is offline   Reply With Quote
Old 04-28-2012, 05:29 PM   #2
OKC99 OP
Oddometer: 37
Does anyone have any advice on this matter?
Old 04-28-2012, 05:40 PM   #3
Warney
Warney's Avatar
Oddometer: 568
http://www.howtocleanstuff.net/how-t...tic-and-vinyl/
Beware using acetone, might discolor the plastic.
Warney is offline   Reply With Quote
Old 04-28-2012, 08:49 PM   #4
azabeemerboy
azabeemerboy's Avatar
Oddometer: 1,579
Glue
try nail polish remover.
Barry
azabeemerboy is offline   Reply With Quote
Old 04-28-2012, 09:31 PM   #5
fullmetalscooter
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 3,041
contain the same stuff the guy before you said might harm the plasic colour. Heat gun instead???
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Old 05-01-2012, 03:26 AM   #6
ronnath
ronnath's Avatar
Oddometer: 1,447
looks like the methods of removing it are bit risky. how about taking the redneck route and cover it with touch-up paint?
ronnath is offline   Reply With Quote
Old 05-07-2012, 08:37 AM   #7
svejkovat
svejkovat's Avatar
Oddometer: 856
Always assumed that cyanoacrylate fogging was permanent but your post got me curious. There are super glue "debonders" out there that are said to remove fogging and glue from surfaces using a cotton ball. One post claimed that WD-40 is pretty effective. I'll have to give it a try next time it's a problem. I once did a superglue repair to the temples of some glasses that had plastic lenses. The glue fogged the lenses and I believed them to be destroyed. Maybe I should have tried some sort of debonder on them.
svejkovat is offline   Reply With Quote
Old 05-07-2012, 01:32 PM   #8
Moat
Moat's Avatar
Oddometer: 120
I believe reflectors are polystyrene, and nail polish remover (acetone) will turn that to goo. The Givi boxes are probably ABS (styrene-based plastic) and acetone/toluol/MEK/lacquer thinner will probably melt that stuff, too.
Your best bet would be milder petrol solvents like kerosene, mineral spirits, or better yet WD-40 - which contains some oil that may help lift the glue residue... but any of those milder solvents will only be minimally effective at actually dissolving the glue itself... at least without some considerable elbow grease.
Another idea would be to just polish it out with polishing compound - I'd bet Simichrome or Mothers would work well. I've had good results polishing out super glue with Simichrome (guitar finish repairs).
- '01 YZF600r - sport-touring backroad bliss
- '97 KLR250 - 'ol reliable, loveable pack burro
- '12 Taotao ATM50-A1 - cheap Chinese scooter experiment (surprisingly successful... so far)
Moat is offline   Reply With Quote
Times are GMT -7.   It's 05:26 AM.
