Old 09-30-2012, 10:06 PM   #31
HappyRiding
Grumpy
HappyRiding's Avatar
Oddometer: 3,263
Wade, you should be nicer to the next front end. Good luck with the rebuild.
"Hey I've never seen the sun come up in the west!?!" - Fozzie Bear
HappyRiding is offline   Reply With Quote
Old 11-13-2012, 11:41 AM   #32
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,193
Ya took too long and Bimota came out with whatcher building!
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 11-13-2012, 11:44 AM   #33
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,553
Oh help me Rhonda that is stupidly delicious
Want so bad it hurts, I don't even want to know how much it costs.
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 11-13-2012, 11:48 AM   #34
Gummee!
Gummee!'s Avatar
Oddometer: 28,193
I haven't seen too much about it, but I did see 1100cc
M
Old 11-13-2012, 12:44 PM   #35
Wadester OP
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,976
M
Ain't you got anything better to do than taunt me with yet another unaffordable Bimota - and this one is (sadly) pure vaporware.
Bimota DBX-1100
En Espanol: http://www.masmoto.net/novedades/201...mota-dbx-1100/
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 11-13-2012, 02:13 PM   #36
jerdog53
Crop Dusting Everywhere
jerdog53's Avatar
Oddometer: 5,048
13 Hyperstrada 09 696 Monster
"Shorter of breath and one day closer to death"
jerdog53 is offline   Reply With Quote
Old 11-13-2012, 11:01 PM   #37
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,559
I was waiting for a thread like this.
I got a 2005 Ducati ST3 that had been in a garage fire for really cheap.
This year, I decided to do a build like yours for the DirtBag Challenge. I got all the suspension work done, but couldn't make it run due to EFI CPU issues... it's one of the red key/black key models. I'll replace it with a MicroSquirt.
Anyway, looking forward to your build.
Suck, Squeeze, Bang, Blow
New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better!
Roadracer_Al is offline   Reply With Quote
Old 11-14-2012, 07:10 AM   #38
Wadester OP
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,976
I'd like to see what you've got done so far - parts choices, etc. For the EFI issues - have you heard of DucatiDiag? An inexpensive enthusiast written full-access bit of software:
http://www.ducati.ms/forums/92-hyper...-hm-owner.html
http://ducatidiag.xooit.com/index.php
Don't know if it would help you out - if you've got the red/black keys, this will let you read/erase error codes and completely reprogram your EFI. Also supposed to let you recalibrate your speedo, remove O2 sensors and turn off immobilizer/remove stock instruments.
Old 11-14-2012, 08:00 PM   #39
Roadracer_Al
Oddometer: 1,559
Thanks for the link - I'm pretty interested in trying out the MicroSquirt, but I may try the diagnostic before pulling the trigger on the MS. Both the red and black keys have had some heat damage, which may have ruined the RFID chip.
I got a CRF 450 roller cheap. Swapping the steering head was dead easy: turned up some cups for the bearings, and a 3/8" thick spacer between the top triple and the steering head. Bolted up like a champ. A better and easier, but more costly solution would have been to buy tapered roller bearings in the correct size.
The rear was quite a bit more work.... and I have a penchant for understatement.
I started with the ST3 swingarm and removed all the stock shock mounting hardware, leaving only the main cross brace. I then sectioned it aft of the cross brace and added 2.5" to accomodate a DR650 wheel with an 18" rim laced to it. I chose the DR rim because it has factory cush drive.
I then sectioned the SA in front of the cross brace and added 1.25" there in order to accomodate the shock and linkage from the CRF.
I did all this cutting and welding basically as a one-time-use for the DBC -- I have plans to create a new SA from scratch using 3" x 1" tubing. There is a ***big*** problem with adding travel to the ST3 SA: the SA pivot pinch bolt interferes with the sprocket. The pinch bolt will have to be changed.
The lower shock linkage mount required a bit of tinkering, too. I plan to make a removable cradle which will have an outboard bearing for the swingarm, footpeg/shifter/brake mounts, and possibly split dirt-bike style radiator mounts. The doohickey with the zig-zag is a removable frame section. I've made 2 so far, and need 4.
Here's a photo gallery of the progress to date:
http://alanzina.zenfolio.com/p965200943
Old 11-14-2012, 08:14 PM   #40
Wadester OP
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,976
Might as well show a few:
Alan Lapp and Zina Deretsky: DirtCati &emdash;
To post these, get the embed code from your site - then click the A/A thing in the upper right of the reply window - then paste in the embed code. Voila.
Old 11-15-2012, 11:07 PM   #41
Roadracer_Al
Oddometer: 1,559
Thanks for that. I didn't want to hijack the OP's thread.
Old 01-06-2013, 07:27 PM   #42
Wadester OP
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,976
I finally got my butt in the shop and peeled back some wiring harness to get the old frame free - also had to pull the injector set:
Can you tell which frame is which?
Now, I need to put the "new" frame and wiring harness back on - and start mounting the front forks.
Old 01-07-2013, 08:06 PM   #43
Ted.audia
Oddometer: 6
fantastic progress and glad you are back working in the shop! Keep us posted on how things are going
I need to take inspiration from you on my own monster conversion/money pit
cheers
Licentia Vel Nex
00 Aprilia RS50; 05 BMW r1200gs; 03 Ducati M800adv; 02 Ducati 998
Ted.audia is offline   Reply With Quote
Old 03-01-2013, 01:22 PM   #44
jbcaddy
Oddometer: 1,209
How much trouble is it in NM to change the frame? titled as a different bike? or changed numbers on registration?
What are ya doin' with the old frame? I have yet another project looming and could use some bits off it
jbcaddy is offline   Reply With Quote
Old 03-01-2013, 07:39 PM   #45
Wadester OP
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,976
I was patient/lucky enough to get a frame with title, so it's just another bike to the DMV.
What devious plans ya got for a bent Duc frame? Or maybe it's "what bits?"
Times are GMT -7.   It's 05:48 PM.
