Old 04-30-2012, 05:28 PM   #16
ssevy
Oddometer: 902
svensaw. I bought a wyoming saw ($$) that comes apart in a small case, and it sucks.
ssevy is offline   Reply With Quote
Old 04-30-2012, 06:28 PM   #17
OurBC
Live to Travel
OurBC's Avatar
Oddometer: 420
Originally Posted by GPS_Jon View Post
Excellent saw!
OurBC is offline   Reply With Quote
Old 04-30-2012, 07:08 PM   #18
weird1
Oddometer: 70
I carry a sawvivor http://cspoutdoors.com/trsasaw.html, and a Gransfors Bruks Mini Belt Hatchet http://www.amazon.com/Gransfors-Bruk.../dp/B004055NPI .
weird1 is offline   Reply With Quote
Old 04-30-2012, 09:25 PM   #19
rockydog
just a guy
rockydog's Avatar
Oddometer: 846
+1 on the sven saw, plus i use it to prop up the bike for lubing the chain, tire repair, etc. the hollow handle of the sven slips over the handles of a small titanium griddle, small hinged grill, and can add leverage to tools.
Two lane roads and two bit towns
Rockydog woofs the Isles, British Isles
rockydog is offline   Reply With Quote
Old 05-01-2012, 03:15 PM   #20
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,203
I also carry the Lee Valley Buck Saw. I wanted something that is light and packs up small but able to tackle good sized downed trees. The Lee Valley all packs up inside the longer metal tube just like the Sven. I chose it over the Sven because the buck saw shape gives you more depth (saw larger logs) for the same length blade compared to the A-frame Sven. Both work great and go through wood fast.
If you are a wood worker don't go the Lee Valley website unless you have a few hours to spend. They have way too many fine hand tools.
Sparrowhawk screwed with this post 05-01-2012 at 03:21 PM
Sparrowhawk is offline   Reply With Quote
Old 08-20-2012, 07:02 PM   #21
1Down-5Up
1Down-5Up's Avatar
Oddometer: 109
I mounted my 68cc Husky to the back of my bike for some serious trail clearing.
1Down-5Up is offline   Reply With Quote
Old 08-20-2012, 09:21 PM   #22
team ftb
Befuddled Adventurer
Oddometer: 1,730
Originally Posted by BigDogAdventures.com View Post
Yeh------the SVEN saw for me----------I'll never go camping again without it-------------it is much lighter----much less bulky---easier to pack-----and 10 times easier to use than an axe for making a campfire.
No negatives on the sven saw. I meant to order the shorter version for the bike----but mistakenly ordered the longer one and am glad I did. The longer stroke cuts a bigger log faster.
My opinions come from light packing on a motorcycle. I've even packed it camping on my bicycle.
Great idea FTB with the inner tube----I was working on a something to protect the sharp ends---but you did it for me------got lots of old tubes laying around the sickle shed.
BigDog
Glad it worked out well for ya.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 09-17-2012, 06:14 PM   #23
SixtyAte
Daily Dirt Commuter
SixtyAte's Avatar
Oddometer: 92
Bahco Laplander.
http://www.youtube.com/watch?v=-kjs3TW-amk
"Things ain't now as they use to was been and people don't do as they use to did then". Moore Noyes
SixtyAte is offline   Reply With Quote
Old 09-17-2012, 09:34 PM   #24
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,113
I've got the gerber gator machete which has a saw on the back side. I'd like it IF if had finer teeth!
I've found here in the rain forest that most saws teeth are too course - i.e. saws that worked great on logs in Washington or Colorado don't really work in Malaysia on the denser/harder word we have. Our biggest issue is bamboo which also works better with a saw with more teeth per inch.
Often here in a situation like the above you'll find the following week they've all dropped to 3' above the trail and there are a 100 4" diameter bamboo trees to cut.
rickypanecatyl is offline   Reply With Quote
Old 09-22-2012, 05:58 AM   #25
fjryan
Traveler
fjryan's Avatar
Oddometer: 9
If you're looking for a small saw for post ride campfire and some suds, +1 for the Sven saw.
-Joe
fjryan is offline   Reply With Quote
Old 09-22-2012, 07:08 AM   #26
1Down-5Up
1Down-5Up's Avatar
Oddometer: 109
I often use a Stanley FatMax 15"/380mm carpenters handsaw. It outperforms most handsaws I have tried. I slide it under my tailbag. It is a little heavier but worth it. I tried a Fiskars retractable 8" saw , it was useless. No set on the teeth, couldn't cut through a 2" stick!!! I returned it. They are inexpensive and no assembley. Should be at most hardware stores
http://www.stanleytools.com/default....174%3B+Handsaw
1Down-5Up screwed with this post 09-22-2012 at 07:27 AM
Times are GMT -7.   It's 06:28 AM.
