Old 05-02-2012, 07:14 PM   #1
jesionowski OP
Chicagoland Burgman
jesionowski's Avatar
Oddometer: 136
Scooter mirror common problem fix
Small scooters have very narror mirrors they make seeing behind you very hard. I built these for my Kymco Agility for about $3 a piece. All material from ebay and Ace hardware. They are aluminum and stainless fasteners. No special tool were used. Just a saw and drill press.
Ignorance is never better than knowledge
jesionowski is offline   Reply With Quote
Old 05-02-2012, 11:32 PM   #2
Hardguy
Oddometer: 68
You can get a set of mirrors extenders on ebay for $20 and they look much better in my opinion. Try "mirror extenders" search.
Hardguy is offline   Reply With Quote
Old 05-03-2012, 04:31 AM   #3
ronnath
ronnath's Avatar
Oddometer: 1,445
a practical, inexpensive solution to a common problem. way to go, jesionowski.
hit 'em with some black paint and you're good to go.
ronnath is offline   Reply With Quote
Old 05-03-2012, 08:01 AM   #4
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,834
Please post the dimensions of that bar stock. Thanks.
Also, mirror extenders can be had for less than $10. I've seen them on Amazon.com and you should have color choices, if that matters.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 05-03-2012, 08:04 AM   #5
gogogordy
gogogordy's Avatar
Oddometer: 1,925
Well...
scooters weren't built for us broad shouldered, studly types (like Im sure we ALL are...) LOL
Nice job on those!
Isn't it past your bedtime?
gogogordy is offline   Reply With Quote
Old 05-03-2012, 09:40 AM   #6
Hammerspur
Hammerspur's Avatar
Oddometer: 1,138
If yours are round you can easily get the mirrors a couple more inches outboard for better view by increasing the bend of the mirror stems closer to a 90 degree angle.
Added benefit in appearance as this negates that doofy insect antenna look too.
Hammerspur screwed with this post 05-03-2012 at 03:48 PM
Hammerspur is offline   Reply With Quote
Old 05-03-2012, 06:29 PM   #7
jesionowski OP
Chicagoland Burgman
Oddometer: 136
3/8 x 3/4 x 6" . I bought 4 -12'' pcs for $11 including shipping from ebay.
I tried looking on line for anything that would do the job. All the ones I found were about $20 and only extended things about 2" per side
So I built my own. Always way more satisfying at least for me. Form follows function in this case. Not the prettiest but it does exactly what I want it to do.
jesionowski screwed with this post 05-03-2012 at 06:36 PM Reason: spelling
Old 05-03-2012, 06:30 PM   #8
JerseyBiker
Living the life!
JerseyBiker's Avatar
Oddometer: 2,379
Great job! Always more fun to make stuff than buy it!
JerseyBiker is offline   Reply With Quote
Old 05-03-2012, 06:44 PM   #9
jesionowski OP
Chicagoland Burgman
Oddometer: 136
So i guess my BS in mechanical engineering finally paid off.
If I dont design and build something, no matter how simple or small every week or so I dont feel right.
I will take them off this weekend, grinds some nice corners on them and paint them black
Old 05-03-2012, 08:00 PM   #10
knucklehead90
knucklehead90's Avatar
Oddometer: 217
Is there any increase in vibration transmitted to the mirrors?
2008 650 Burgman Executive 'Darksided'
Cages:
1971 Karmann Ghia
2013 VW Jetta TDi Premium
knucklehead90 is offline   Reply With Quote
Old 05-04-2012, 07:54 AM   #11
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,834
Thanks.
I wondered the same thing.
Old 05-04-2012, 07:18 PM   #12
jesionowski OP
Chicagoland Burgman
Oddometer: 136
Yes, But not as bad as you would think. Still very viewable. That aluminim bar is WAY more stiff then it would seem. It tends to vibrate more at idle and less at speed.
Old 05-05-2012, 09:27 PM   #13
cbolling
Here...Hold my Beer.
cbolling's Avatar
Oddometer: 2,914
I bought these of EBay.
They work great.
2011 Kawasaki Versys
http://www.advrider.com/forums/showthread.php?t=661436
cbolling is offline   Reply With Quote
Old 05-06-2012, 01:45 PM   #14
JerseyBiker
Living the life!
Oddometer: 2,379
Oh yes! That $100K education saved you $20!
What else you made?
Old 05-06-2012, 06:17 PM   #15
jesionowski OP
Chicagoland Burgman
Oddometer: 136
What else you made?
http://www.advrider.com/forums/showt...23072&page=122 A solar panel.
Also here is it all painted and road tested. Works great. Those Ebays ones didnt kick the mirrors out far enough.
Times are GMT -7.   It's 04:29 AM.
