Old 05-04-2012, 11:44 AM   #1
wingysataday OP
wingysataday's Avatar
Oddometer: 610
Video of clutch problem HELP!
http://youtu.be/eduWLMPqcy8
I have had this clutch problem for a little while and it has become progressively worse. I replaced my slave cylinder with the updated one(which I think it was already the updated one) I even purchased the updated push rod(which was aready the upgraded one). I pulled the clutch apart and inspected it. There is plenty of oil in there. The EBC clutch only has about 1000 miles on it. I also cleaned the oil jet which was clean by the way, after 31k miles. I put fresh 5w fork oil in the clutch after flushing it and still got problems. Maybe this video will shed some light?
07' xr650l. Battery relocation w/Battery tender lithium ion, daves mod. TRADE: black clarke tank for any white tank!!! PM me.
Catholicscomehome.org
wingysataday screwed with this post 05-04-2012 at 12:20 PM
wingysataday is offline   Reply With Quote
Old 05-04-2012, 12:07 PM   #2
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,750
The noise changes when you are pulling in and releasing the lever?
traveltoad is offline   Reply With Quote
Old 05-04-2012, 12:16 PM   #3
wingysataday OP
Oddometer: 610
correct. In the video I am pulling in the clutch and releasing it a few times.
Old 05-04-2012, 12:49 PM   #4
Tosh Togo
Oddometer: 1,594
It's normal behavior for multi-plate clutches...pulling the lever in unloads the clutch plates, so the rattle changes.
Are there any real problems/symptoms to contend with?.
Tosh Togo is offline   Reply With Quote
Old 05-04-2012, 01:04 PM   #5
wingysataday OP
Oddometer: 610
Yes I can't put it into gear. When I push down on the gear shifter with the clutch full engaged it jumps forward and dies as if the clutch was not engaged at all. I have a feeling mobile 1 is a bad choice..
Old 05-04-2012, 01:21 PM   #6
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,750
How did you bleed the clutch master/slave?
Old 05-04-2012, 01:44 PM   #7
crazybrit
crazybrit's Avatar
Oddometer: 8,555
Don't want to turn this into an oil thread, but I run mobil-1 silver cap (auto) in all my ktms. Never had an issue.
I'd tend to assume issue is elsewhere.
crazybrit is offline   Reply With Quote
Old 05-04-2012, 02:14 PM   #8
FuTAnT
KTM 990ADV
FuTAnT's Avatar
Oddometer: 342
Same, no probs with Mobil 1 auto oil int he KTM.
Cleaned the clutch jet?
Cameron Corner - 6 Day Blast
FuTAnT is offline   Reply With Quote
Old 05-04-2012, 02:19 PM   #9
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,107
5w fork oil in the clutch line or in the plates?
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 05-04-2012, 02:21 PM   #10
crazybrit
crazybrit's Avatar
Oddometer: 8,555
first post: "I also cleaned the oil jet which was clean by the way, after 31k miles"
I took it to mean 5w in the clutch line, in place of mineral oil
Old 05-04-2012, 02:24 PM   #11
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,107
Wouldn't that be the issue? Cause clutch sounds fine, From his description it sounds like clutch isn't engaging (lurching when he puts it in gear and stalling). 5w fork oil to thick?
Sorry, I'm learning as well
Ball bearing in the slave missing?
Roaming Rally 2015
Old 05-04-2012, 02:26 PM   #12
crazybrit
crazybrit's Avatar
Oddometer: 8,555
Wouldn't that be the issue? Cause clutch sounds fine, just sounds like clutch isn't engaging (lurching when he puts it in gear and stalling). 5w fork oil to thick?
I think Magura mineral oil is nominally a 7 weight. If he's using 5 weight as the hydraulic fluid it'll be fine.
No need for a sorry, was an ok question
Old 05-04-2012, 02:27 PM   #13
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,107
Missing the ball bearing in slave maybe?
Roaming Rally 2015
Old 05-04-2012, 02:45 PM   #14
wingysataday OP
Oddometer: 610
Fork oil is not in the motor it is in replacement of the mineral oil which is a known failure. I bleed the hell out of the clutch. Clutch feels good. As soon as I pull in the clutch it starts clacking and does not engage?
Old 05-04-2012, 02:50 PM   #15
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,750
Did you bleed from the bottom up?
Times are GMT -7.   It's 02:46 PM.
