Old 05-04-2012, 02:51 PM   #16
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 6,831
I bleed mine for a long long time and it seemed fine but had same symptom. I reverse bleed it and a large bubble cme out (from slave I assume) then it worked like a champ. Might not be the same issue....
www.GravelTravel.ca Canadas Source For Overland Routes
Tales From The Bivouac Rally Print Publications
TCAT Trans Canadian Adventure Trail 15, 000 km GPS route across Canada
Deadly99 is offline   Reply With Quote
Old 05-04-2012, 02:57 PM   #17
wingysataday OP
wingysataday's Avatar
Oddometer: 583
just looked on the inside of the clutch cover and it is warn down. The basket cover must be rubbing on the inside of the clutch cover! Maybe I have to many plates installed? The last plate is to the tip of the basket. Can someone show me a pic of what the basket should like when all installed? Blessings! It still makes the noise even without the cover on it. The red plastic adjustment piece on the clutch lever is fully turned in. I really think I have to many plates?
Boise, 950 superenduro.
http://blackdogcw.com/ (exceptional products)
Over 6 million Americans have died from abortion during the war in Iraq.
wingysataday is offline   Reply With Quote
Old 05-04-2012, 03:08 PM   #18
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,108
10 steel and 11 fiber I believe
traveltoad is offline   Reply With Quote
Old 05-04-2012, 03:09 PM   #19
crazybrit
crazybrit's Avatar
Oddometer: 8,040
That's not good. Are you sure the pressure plate is torqued to spec?
I'd have thought you'd have a really hard time getting the pressure plate on if you had too many plates.
crazybrit is offline   Reply With Quote
Old 05-04-2012, 08:01 PM   #20
wingysataday OP
Oddometer: 583
is this for sure? I will count in the am. Thanks peeps!
Old 05-04-2012, 08:18 PM   #21
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,108
When the bled the clutch... did you do it from the slave up to the master?
Old 05-04-2012, 08:24 PM   #22
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,108
Per the repair manual:
The clutch disks must be even.
10 steel lamella ␣ –– may not have any recesses.
11 lining disks ␣, wear limit 2.65 mm
Old 05-05-2012, 12:19 AM   #23
sabink
Oddometer: 106
Is the booster installed correctly using the marks?
sabink is offline   Reply With Quote
Old 05-05-2012, 07:00 AM   #24
charlie264
charlie264's Avatar
Oddometer: 5,023
Originally Posted by FuTAnT View Post
Same, no probs with Mobil 1 auto oil int he KTM.
Cleaned the clutch jet?
+1 Used both, auto and bike....no probs, no clutch slip...take the clutch apart and clean plates with some scotchbright.
Old 05-05-2012, 10:19 AM   #25
wingysataday OP
Oddometer: 583
Counted all the discs and numbers are correct.
1.Why would the basket be touching the clutch cover? There is a shim and a convex washer/shim on the very inside.
2.The plates are sticking together pretty good I had to pry them apart with my fingers. Should they stick together like that?
Old 05-05-2012, 11:43 AM   #26
charlie264
charlie264's Avatar
Oddometer: 5,023
Clean oil jet.
Old 05-05-2012, 02:16 PM   #27
wingysataday OP
Oddometer: 583
I did that already as I said in my original post. (cleaning the oil jet that is)
Old 05-05-2012, 03:12 PM   #28
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,108
You have the top plates rotated one notch like in craybrit's photos?
Old 05-05-2012, 03:59 PM   #29
mdfehrmann
mdfehrmann's Avatar
Oddometer: 298
There is a thin spacer and spring, (the convex spacer) installed in the inner most basket and 1 clutch fiber that
has a larger inner diameter to accommodate that spring and spacer. Did the new clutch fibers have that one odd ball?
That might be part of the problem if a full fiber is on top of those 2 spacers. If it is a full fiber pull those 2 pieces out
and give it a try thats how I run them in my recluse, or install the one odd ball fiber you replaced with that thin spacer
and spring.
Also given where the bleeder is on the slave it's very hard to get the air out in my experience.
Yes oiled plates have resistance when trying to pick them straight off each other.
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo-
2006 KTM 950 ADV S
http://www.mdfeditions.com/
http://www.cjdesignsllc.com/
mdfehrmann is offline   Reply With Quote
Old 05-05-2012, 04:35 PM   #30
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,120
Originally Posted by crazybrit View Post
Your pressure plate does not have signs of friction with anything. There is nothing else to rub to the clutch cover. Could it have had an incident of loose pressure bolt?
There is always a reason!!
Times are GMT -7.   It's 01:56 AM.
