Old 05-05-2012, 11:08 AM   #1
Poway OP
SHED (Shit Head)
Poway's Avatar
Oddometer: 501
Did I mortally wound my motor? Previous tune up valve clearances set to tight.
Hi ADV,
Despite having JVB's DVD, 2 manuals and tons of internet info, I blew it. On previous tune up (6000 miles ago) I set my valve clearances to tight, and probably not on TDC. Mistake caught on my current tune up. At TDC (verified) I can not get minimum clearances on my both intake and exhaust, left side valves. At full extraction all 4 valve springs, have almost no clearance. Approx 1/5 the recommended. The right side of the motor is OK. Bike was running great.
Spoke to dealer about it, he said mistake is unreversable. And that things will get worse. then bad. Much better to err on the loose side than tight on valve clearance settings.
1999 GS1100
How bad did I screw up? Did I cause the beginning of the end?
Thanks in advance
Poway screwed with this post 05-05-2012 at 11:42 AM
Poway is offline   Reply With Quote
Old 05-05-2012, 11:35 AM   #2
mousitsas
mousitsas's Avatar
Oddometer: 2,948
not sure, but I think that...
tappet valves get looser with time, shim valves get tighter. Yours are tappets.
Old 05-05-2012, 11:35 AM   #3
Jim Moore
Jim Moore's Avatar
Oddometer: 14,142
Originally Posted by Poway View Post
Hi ADV,
You know you have to turn the motor 360 degress before you check the other side, right?
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 05-05-2012, 11:45 AM   #4
Beezer
Oddometer: 5,874
ya... make sure the procedure is done correctly.
if it was done improperly... are there any issues with how the bike runs?
if you are doing the procedure correctly now and there is clearance problems I would do a leak down check to see if the valves are burnt. this would only be the exhaust side. If it's cooked then time for valve work.
Beezer is offline   Reply With Quote
Old 05-05-2012, 12:06 PM   #5
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,314
As long as you had some clearance, don't worry about it. The danger is if the adjustment is so tight that the valve stays open some amount and the high temperature combustion products erode an erosion in the valve head. Too tight valves will cause starting difficulty if they're tight enough to do damage.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 05-05-2012, 12:19 PM   #6
Poway OP
SHED (Shit Head)
Poway's Avatar
Oddometer: 501
Thank You All !!!
Jim I did not rotate the engine 360. After your post, I rotated and all is well!!!
Thank you
Old 05-05-2012, 12:46 PM   #7
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,229
Sir,
That is contrary to everything I have heard and experienced.
As far as I know, the valves are harder than the cylinder head.
And they work themselves upwards, slowly but surely.
The gap above them gets smaller.
This corresponds to my 190.000 km of experience with the R-engines.
The gap gets smaller, and must be adjusted.
Can someone correct me if I am wrong, please!
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 05-05-2012, 12:47 PM   #8
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,229
Sir,
I will take the liberty of adding this to the GSpot FAQ.
If you don't mind!
[TaSK]
IBA: 33616
Old 05-05-2012, 12:53 PM   #9
tkent02
Oddometer: 2,752
You think the dealer was just trying to sell you an unneeded replacement engine?
I bet they would have sold your old engine on to the next guy that needed one.
tkent02 is online now   Reply With Quote
Old 05-05-2012, 12:53 PM   #10
Gezerbike
Hey Rocky...........
Gezerbike's Avatar
Oddometer: 3,571
Originally Posted by tagesk View Post
Sir,
[TaSK]
You are correct. And I for one always make sure mine are looser than tighter when setting them.
___________________________________________
Mike
2012 R 1200 GS RALLYE
Gezerbike is online now   Reply With Quote
Old 05-05-2012, 01:31 PM   #11
marty hill
The Energizer Bunny
marty hill's Avatar
Oddometer: 4,285
Always err on the loose side!
ride till you can't.
1200GS/black
Boxer Cup Replika/red-white-blue
Semper Paratus
marty hill is offline   Reply With Quote
Old 05-05-2012, 02:34 PM   #12
Jim Moore
Jim Moore's Avatar
Oddometer: 14,142
Thank you
Atta boy! Next time, when you get to tdc wiggle the rocker arms on both sides. One side will be loose. That's the side to start on.
Jim Moore
Jax, FL
Old 05-05-2012, 04:50 PM   #13
marty hill
The Energizer Bunny
marty hill's Avatar
Oddometer: 4,285
Great catch Jim!
1200GS/black
Semper Paratus
Old 05-05-2012, 05:39 PM   #14
bajaburro
Ancient Adventurer
bajaburro's Avatar
Oddometer: 1,570
women
loose valves,loose women,good.got that now?
ancient adventurer
bajaburro is offline   Reply With Quote
Old 05-05-2012, 09:30 PM   #15
vagueout
vagueout's Avatar
Oddometer: 1,743
Likely no harm done, a compression check to compare left to right should answer the question.
i just seek clarity
vagueout is offline   Reply With Quote
Times are GMT -7.   It's 04:39 PM.
