08-08-2012, 01:45 PM
#211 |
RN
Oddometer: 717
Concrete pad for what???
08-08-2012, 02:09 PM
#212 |
Oddometer: 2,859
concrete pad
concrete pad in front of the garage, ac compressor and pad under the 12 x 16 deck
BMWMOA 82741 75 R90S ,83 R100RT (Baron) , 88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS w/hack,05 K1200S (Gandalf) |
08-08-2012, 09:07 PM
#213 |
Oddometer: 2,859
Wed, evening after beach volleyball
A little after 9PM and it's dark outside.
Here it is with the lights on. Very impressing with the reflective ceiling foil. Almost too bright. taken infront of the garage door ![]() ![]() the glare is amazing.. high output 54 watt bulbs ![]() reflective foil ![]() drywall is here
08-09-2012, 02:00 AM
#214 |
Oddometer: 2,203
whats with the foil?Is the insulation pushed hard up under the sheets of ply?Why is there foil in the main garage area but not in the upstairs area behing?
I guess the tiles will be laid on some timber battens with some sort of paper or felt under the tiles?Really interesting to see how different construction can be in different parts of the world
aka BMWST?
08-09-2012, 07:26 AM
#215 | |
Oddometer: 2,859
foil
the foil is holding nakes batts of insulation. There are wires pulled tight to keep the insulation close to the sheathing. The upstairs is getting dry walled so foil is not needed. Building in the Southwest is totally different. I built home on the east coast the codes and how they build is totally different then here.
08-09-2012, 08:49 PM
#216 |
Oddometer: 2,859
dry wall up
Carpenter crew here to day. Finished the walls for the office and bathroom.
Drywall is up and will mud in the morning. Tiles were loaded on the roof this morning. ![]() ![]() ![]() Lower office being framed out. Place to use as a clean room to take small parts apart ![]() ![]() drywall is up on the walls ![]() guest / music room is dry walled. ![]() really is a big room
08-10-2012, 10:55 AM
#217 |
Oddometer: 2,859
Friday
Met with the GC this morning. Decided that the little office should have a window (2x3) so off to Lowes, called the carpenter and he will be here at 1 to install ..as the dry wallers are finishing up.
Pics later
08-10-2012, 07:02 PM
#218 |
Oddometer: 29
Ya me too, in it for he long haul, been watching this for some time, it's amazing what you have to go through to build this garage. I would give my left %^!@ to build something like that, keep the posts coming it is cool to watch and see the progression. Hope that you go until you actually have it finished and using it for whatever. I have a small shop with a Direct Lift Motorcycle lift and make the best out what I have, I would probably be lost in something like that, HMM! let me have the chance and I'll tell ya.
Anyways just enjoying the view.
Bob See my Blog http://vader1701.blogspot.com/ Also my YouTube channel LordDarthVader1701 |
08-10-2012, 08:28 PM
#219 |
Oddometer: 2,859
thanks for the flowers
We finished the dry wall and talked about trimming out the upstairs
in some areas. The tile will be next and hvac is getting it together for next week. The window we put in is just a small window so I could look out and let additional light in. I will do just fine. We also decided to use motion detectors to turn on the lights at each door. We have them all over out house now and we are kinda of spoil. Walk in and the lights turn on. Helps at night going to the john. ![]() door way into the office. It will be a single light glass full length. Found the door on craigslist for $30. ![]() Stairway to the upstairs. The office will serve several purpose. With the door close the fumes from the garage would smell up the place. The office will serve as my clean room and it will be air condition. ![]() small window just installed. We can even open it.
08-11-2012, 06:56 PM
#220 |
Oddometer: 2,859
Sat. Watch the perfect dust storm
BMWMOA 82741 75 R90S ,83 R100RT (Baron) , 88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS w/hack,05 K1200S (Gandalf) walkingbear screwed with this post 08-11-2012 at 07:54 PM |
08-13-2012, 07:16 PM
#221 |
Oddometer: 2,859
Monday
Nothing is happening.. because LOWE's dropped the ball.
Windows won't get here until Sept. I told them they need to make it right with a $500 gift certificate. Painter is coming on Thurs to give me an est. Concrete now has all the plans and will get a bid out next week. Looks like the build is coming out to $100 sq ft. Hate cost over runs.
08-15-2012, 11:27 AM
#222 |
new orange flavor
Oddometer: 1,058
So, housewarming party Octoberish????
-John
An Elefant never forgets. 2012 Baja 1000 www.Raceforthewounded.com Help us race the 1000, and double the value of your KLR by buying a t- shirt |
08-15-2012, 06:03 PM
#223 |
Oddometer: 2,859
house warming
Well, open garage .. will invite all who wants to travel. Working on finishing. Might have to do the TECH day in 2013. Running out of time this year.
08-16-2012, 10:23 AM
#224 |
Unreasonable
Oddometer: 2,230
Walkingbear...
I'm sure you're my long lost Father. Can I come home now? ![]() I promise I'll keep the Garage clean this time so you don't have to send me to Canada. I promise I'll be good....
TransLab a Go Go 2011 Nova Scotia Fresh Air Inspectors Investigate the Cabot Trail "Second star to the left and straight on till morning” ― James T. Kirk |
08-16-2012, 10:34 AM
#225 | |
Oddometer: 2,859
father...
You can stay for 3 days.. just like everyone else.
