Old 10-26-2012, 06:49 PM   #331
walkingbear OP
walkingbear's Avatar
Oddometer: 3,629
Look what showed up
My welder with cart showed up today..
I have a used Harbor Freight Mig 100 for sale. $100
Used once to weld hinges to the trailer.
http://images.harborfreight.com/manu...4999/54878.pdf
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear screwed with this post 10-26-2012 at 06:54 PM
walkingbear is offline   Reply With Quote
Old 10-27-2012, 06:18 PM   #332
walkingbear OP
Oddometer: 3,629
shelving is up
Four shelves the last one 11 ft off the ground. It is already filled.. will sort out the next few weeks.
great vise
Old 10-28-2012, 07:38 PM   #333
C-Stain
C-Stain's Avatar
Oddometer: 6,685
Jeebus... your man cave is nicer than my house.
Originally Posted by Mr_Gone View Post
C-Stain is wise.
C-Stain is offline   Reply With Quote
Old 11-01-2012, 07:35 AM   #334
walkingbear OP
Oddometer: 3,629
Final Inspection
We called for the final inspection yesterday. The plumber was out to
finished the job.
Driveway from the street will start in 10 days. The deck will start after the finishing of the block wall. Yesterday, I started building the rock wall adjacent to the steps. Damn..that is a lot of rock.
Loaded the shelve and a fully operational sink
My trusty helper was stacking up the cleaning supplies
walkingbear screwed with this post 11-01-2012 at 12:57 PM
Old 11-02-2012, 02:51 PM   #335
walkingbear OP
Oddometer: 3,629
finishing
Friday, workers here are Donald and Berry.
Task to unload the dually trailer full of tools and lift.
Finish building the stone wall (gather rock and mixing cement)
Dragging the yard with chainlink and rocks.
My art work on the stairway wall.. way kewl . One of a kind piece of art
The sliding doors worked really well. Need to make a few adjustments.
Shower door finished and ready for guest
More pics of the bathroom
Tool boxes are now unloaded and the task of putting all the tools away will take a couple of days
Old 11-02-2012, 08:37 PM   #336
Dagofast
Full giggety ahead.
Dagofast's Avatar
Oddometer: 1,789
I'd love to see a pic of the steps and the rock wall when its done. Great build so far, thanks for sharing!
Dagofast is offline   Reply With Quote
Old 11-03-2012, 08:39 PM   #337
walkingbear OP
Oddometer: 3,629
steps and rock wall
The steps and rock wall turned out great. Before pouring the steps we put in plastic sleeves so we could run low voltage wires and water lines without having to dig them out.
The footers were set and we went two rows .. to let the footer dry
before loading the rest of the wall. All the rock seen on the wall is from my property. When they were
digging and scraping the yard I told them to leave all the larger pieces. They could have left me another 20 tons and
I still would have used it.
The excavation companies charge you to take away the dirt. They clean and separate the rocks and then resell them to other
contractors. They were kinda pissy when I told them I wanted the rock in a pile in the corner of the property.
Now I have time to unload/unpack some of my treasures.
R90/6 small and big tanks and wixon bags
walkingbear screwed with this post 11-03-2012 at 09:23 PM
Old 11-06-2012, 05:30 PM   #338
walkingbear OP
Oddometer: 3,629
The long process
The hardest part of moving in is putting evening away.
Made a spread sheet and have named the shelve and bin numbers.
Each piece will be entered in the XL file so when I look for it .. I know where it is or if someone needs a piece I can see if I have one.
Old 11-06-2012, 09:30 PM   #339
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,040
[QUOTE=walkingbear;19986081]The hardest part of moving in is putting evening away.
I was really enjoying your garage build until now. How can I live without alphabetizing all my own parts now? Seriously, nice job on the build and plan.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 11-07-2012, 06:22 AM   #340
walkingbear OP
Oddometer: 3,629
[QUOTE=RecycledRS;19988318]
Thanks... like how many battery ground straps or set of bings do I need.
Now I know where they are.
Old 11-07-2012, 06:04 PM   #341
walkingbear OP
Oddometer: 3,629
Final inspection
Just received my C of O today. Past the final and now the fun work will start.
Deck coming out of the second floor. Building the tree house and a connecting bridge.
Old 11-08-2012, 01:58 PM   #342
bergermeister
housin'
bergermeister's Avatar
Oddometer: 2,087
can you give any details on the barn door hardware? did you make it or buy it? Thanks!
bergermeister is offline   Reply With Quote
Old 11-08-2012, 03:38 PM   #343
walkingbear OP
Oddometer: 3,629
barn door
There are companies that will sell the barn door sliding slides. I used rustica hardware. They were pretty easy to work with.
They will also sell you the metal rack .. but I had mine made by a welder.
3 inch stock x 3/8 inch. You can measure the room and can make one long piece rather than two pieces that you will have to put together.
I think it looks better as one and it really works well. The doors I found on CL. They came out of an office building . Heavy / fire rated doors. Good luck
Old 11-11-2012, 06:15 PM   #344
walkingbear OP
Oddometer: 3,629
Saturday Nov 17
Not a grand opening but just serving coffee ,donuts and bagels to those who want to come by.
9851 E Casitas del Rio
Scottsdale AZ 85255.
Give me an idea if you are coming over.
First pour at 7AM- last cup poured 11AM
Old 11-11-2012, 10:21 PM   #345
Texas T
Oddometer: 27
Dang! I'll be in L.A. for the RTE at Pink's Hot Dogs on Saturday. Sure would have liked to be there.
Brian & Brenda * IBA 50053 * 2002 Goldwing * 2001 Concours
Want to ride a SaddleSore 1000? Read the Archive Of Wisdom * See where I've ridden this year * AMA Champion Member * Patriot Guard Rider
"I'm a motorcyclist and motorcycling is all about riding on the TT course". Conrad Harrison at the 2012 Isle Of Man TT.
Texas T is offline   Reply With Quote
Times are GMT -7.   It's 12:07 AM.
