09-28-2012, 04:13 PM
#496 | |
0 miles and counting
Oddometer: 156
ROFL -- that puts you about 35 seconds ahead of me! |
09-28-2012, 04:16 PM
#497 | |
Oddometer: 714
5 seconds......... I'm 17 secs.Should not even be posting really...
09-29-2012, 04:38 AM
#498 |
Oddometer: 138
Braking techniques in Moto Gymkhana.
As most of us soon realise, the use of the brakes is way different to the methods we use either on the road or on the track. We use the brakes not only to control the speed as usual, but also to control the amount of driving force available. By now it should have become clear that when the bars are at full lock during a turn, we can no longer steer the bike in the conventional way. To overcome this problem we must be able to steer the bike by regulating the amount of power reaching the rear wheel. If we add power, centripetal force tends to pick the bike up (recover) and if we remove power, the bike tends to bank over more (capsize). At the speeds we are rotating at, the margin for error is quite small and a moments hesitation with the throttle opening could have us on our ear. To overcome this problem, our Japanese friends determined that the best way of regulating the amount of power (driving force) reaching the rear wheel was to keep the throttle open and moderate the engine revs by applying the brakes. They then calculated an optimum amount of driving force that would be sufficient to have maximum steering whilst carrying the bike round the rotation as quickly as possible. Imagine that your throttle instead of being a nice analogue control had a series of detents numbered zero to ten. Zero would be closed throttle and ten would be wide open. Same thing for the brakes, zero is no pedal/lever pressure and ten is maximum pedal/lever pressure. The optimum difference between the amount of throttle and the amount of brakes using this scale is two units. We can obtain two units difference in a number of ways, two of throttle and zero of brakes gives us two, but with the problems of hesitation, three of throttle and one of brake is getting better and four of throttle and two of brake is better still. For new riders the recommendation is to have as large a throttle setting and as much lever pressure as possible so long as there are two units being delivered to the rear wheel. Sadly we don't have a series of handy detents on the throttle or brakes, so we have to work these out for ourselves. Added complications arise when we realise that the power available from the rear brake is much less than that available for the front brake. When teaching new riders the various techniques the Japanese start them out by using the rear brake only until they have got the hang of keeping the throttle open while they do so. The rear brake will very soon fade and the brake fluid start to boil if we rely on the rear brake only so we must bring in the front brake at some point. The top tip is to initially use the front brake to augment the rear so that as we add a little front we can remove a little rear. When using the front brake it is good advice to initially use only the middle finger on the lever otherwise it's all to easy to apply too much pressure on the lever and lock the front wheel! As can be imagined, these crucial techniques take some learning and require a lot of practice to master, but as most of the fun in Moto Gymkhana is in the learning, getting the techniques right is a very rewarding experience.
Dedicated to the wonderful sport of Moto Gymkhana |
09-29-2012, 05:50 AM
#499 |
Oddometer: 306
![]() PLEASE publish that motogymkhana manual already! |
09-29-2012, 06:21 AM
#500 |
Thread Ninja
Oddometer: 1,155
it sounds so technical to get good times,
09-29-2012, 10:40 AM
#501 |
Oddometer: 156
09-29-2012, 02:46 PM
#502 |
Oddometer: 714
I started riding in the muck & a hangover from that was to ride with the front brake covered. I've only broken this (bad) habit in recent months. Now I have to start doing it again.
09-30-2012, 03:25 AM
#503 |
Thread Ninja
Oddometer: 1,155
todays practice, the external view, dont laugh,but feed back welcome
i got the witches hats out today set up a gp8, not sure how far appart 10 meters maybe, and an off set cone weave, as well as a narrow few gates http://youtu.be/Hk1WeDXrDgY external view http://youtu.be/FmdjxoFO8pI internal view Storm Shadow screwed with this post 09-30-2012 at 06:08 AM |
09-30-2012, 11:52 AM
#504 |
Oddometer: 306
" So Vulfy, hows your bike ? ", you might ask.
" Are you enjoying it? ", you might ask. " How are those lap times? ", you might ask. In return, I would ask "What bike?" "Oh you know, the DRZ", you might reply. "Oh the DRZ that got STOLEN two weeks after I got it? That DRZ?" ![]() FUCKERS! So I'm back on my Triumph, and a couple of grand lighter bank account. Live and learn... 1. Insure FULLY, not just liability. 2. Chain to something, especially lighter bikes, and do not rely solely on brake locks. 3. Cover, and chain the cover so its not easily lifted. 4. Don't assume that a beater, older bike will not pose as an interest to the thieves. I'm still selling my Triumph, and there is a good chance that I will be bike-less for some time, until I can recover and pool funds to cover for the stolen DRZ. A bit of an annoyance, but nothing I can't get over. Season might be cut short this year, but I'll be saving whole winter, and will come back in force, come the spring time. Of course, Triumph is not sold yet, so I'll make the best of it, while it is still here. |
09-30-2012, 12:09 PM
#505 |
Well... here was my first attempt at a timed GP8. I continued for a while after this recorded run, but the highway gearing (16t CS sprocket) was requiring way too much clutch useage. Additional disclaimer** this is my wife's DRZ, not the bike I'm used to riding every day, but I figured it would be more fun than my big yellow pig of a DR.
![]() Enjoy, and feel free to offer critique, advice, mockery, etc... And a little about the video setup... I had my P&S camera set up off to the side on video mode, and I had my ContourGPS camera mounted to the right fork tube below the front fender. Synced and combined the two together in Sony Vegas 10. |
09-30-2012, 12:19 PM
#506 |
Oddometer: 138
That would be a decent time apart from the fact you did SIX rotations of the figure 8 when it should only be five, I worked your time out to have been a very creditable 45 seconds had you finished when you should have.
09-30-2012, 12:22 PM
#507 |
Oddometer: 138
Vulfy, sorry to hear about the loss of the DRZ to the lowlife thieving scum. Perhaps it's natures way of telling you that the mighty Triumph is still a force to be reckoned with!
09-30-2012, 02:23 PM
#508 | |
Oddometer: 714
I must admit too having difficulty counting too. My G/F & i had a debate as to what constitutes 5 turns, as she says you can have 4 1/2 or 5 1/2. ,I've got a feeling it's about 45 secs when you really have to start committing in the turn to get better times, the threshold as it were. |
09-30-2012, 03:31 PM
#509 | |
Oddometer: 156
09-30-2012, 05:32 PM
#510 | |
Thread Ninja
Oddometer: 1,155
