Old 05-16-2013, 07:03 AM   #1156
Vulfy OP
Vulfy's Avatar
Oddometer: 573
Originally Posted by shaddix View Post
I was only able to do this turning to the right however, turning to the left is for some reason more difficult. It seems like I have to lean further or lean the bike over further to get it to turn as sharply to the left as to the right.
Might be you throttle hand. Motorcycle control is not symmetrical. You might be having difficulties with the left turn, because your right/throttle hand is stretched out too much for comfortable control of the throttle. Try different positions on the bike to see what works.
I also been doing just that, practicing turns at full lock.
After the initial panic reaction to the locked control and falling bike is gone, its not all that bad. I have two issues now through.
One: is that the bike is traveling super slow, I'm nowhere near the 2 or even 3 second 360 spin. And at higher speed I can't get to the full lock.
Two: I can get to full lock on both sides and keep it there for a few rotations without too much trouble, however that initial transition TO the full lock, takes about half a rotation. In GP8 that means that I'm already leaving the turn, just as I got it to the full lock.
Turns do look quicker though, however my GP8 times are atrocious right now. "Atrocious" compared to my last season when I was in 35 range and managed a few 34 runs on my DRZ. Right now I'm clocking 38-39 seconds. I managed somehow a 35.5 run but that's it.
Vulfy is offline   Reply With Quote
Old 05-16-2013, 10:22 AM   #1157
Motogymkhanaman
Oddometer: 211
Mr Kimura spent quite a bit of time explaining this problem and offered two solutions. The first and the one that is recommended for new riders, is to make a much wider offset to the pylon and start leaning the bike way before the entry point. That way you get a lot of lean angle change out of the way before making the final transition to the optimum lean angle and full lock. The second method is to do a max roll rate capsize at the turn point, but this is very much a technique for the expert!
In the first case the key skill is using the front brake to augment the rear before the turn point. Mr Kimura says that you need to go fast between the pylons and not to take a lot of space getting the bike slowed down enough so you can go slow(ish) around the pylon.
When watching a rider do a rotation, he sees where in the turn they achieve the max bank angle, which is usually on the opposite side of the pylon from the turn point. The aim is to move this point closer and closer to the turn point so that the bike is at max bank angle for longer and the spiral entry path is shorter as a result.
Dedicated to the wonderful sport of Moto Gymkhana
Motogymkhanaman is offline   Reply With Quote
Old 05-16-2013, 11:09 AM   #1158
Motogymkhanaman
Oddometer: 211
Just thought, didn't mention how to achieve lean angle without turning the bike.
Dead easy exercise to do, simply ride in a straight line and push gently, but firmly on one of the bars. Normally you would push and release to initiate a turn, but in this case maintain the pressure on the bar whilst shifting your bodyweight to counteract the lean. You'll end up with the bike leaned one way with your upper body leaned the other way. All being well, you'll end up maintaining a straight course.
This is a fun exercise as you will wobble all over the place until you work out how much lean out you need relative to the amount of pressure on the bars.
In Gymkhana we only need the very slightest of pressure to give us enough lean for our needs, but this exercise is a great one for all you track-day riders to practice as it sets up the perfect cornering body position for your size and weight. The difference between the two is that track-day riders release the pressure on the bars to turn the bike in the direction they are leaning, whilst gymkhana riders apply the brakes to capsize the bike in the other direction.
Give it a try, it's loads of fun.
Old 05-16-2013, 02:56 PM   #1159
Vulfy OP
Vulfy's Avatar
Oddometer: 573
I'm a bit confused by all of this to be honest.
So lets say I lean the bike to the left. To do that, I would have to push on the left handle bar. To counter the lean and the turn, I would move my body to the right side of the bike, and hang off (counter lean) to the right.
So for a track turn, I would release the pressure on the left handlebar, so that the bike leans to the right where my body is, and go into a right side turn.
For Gymkhana, applying the brakes, would counter the momentum of the bike and capsize it to the left???
Are there any clips from you guys, or maybe Japanese riders that would illustrate this for Gymkhana?
Track illustration would be great too, as I've been trying to scrape my knee for the past few weeks now, without any result. That's of course outside of Gymkhana discussion, but still.
Old 05-17-2013, 12:34 AM   #1160
Motogymkhanaman
Oddometer: 211
The effect is very subtle and is very difficult to see in video so the best way to learn it is practice it!
If you want to get your knee down on the track however, a gross input and counterbalancing body position will set you up perfectly for that knee-down moment!
Old 05-19-2013, 01:32 PM   #1161
Vulfy OP
Vulfy's Avatar
Oddometer: 573
Well I wussed out of today's session. Big kudos to Stephen and Jesse for actually making it to the spot and setting up the course.
I get to watch silly youtube videos today. :) Here is one.
Old 05-19-2013, 01:45 PM   #1162
Sckill
Sckill's Avatar
Oddometer: 242
Videos from today's session:
Current: 2012 Yamaha Super Tenere, 2007 Honda CBR600RR
Past: 2006 Honda 919, 2004 Honda 919, 2007 Honda 919, 2008 Suzuki SV650S
Sckill is online now   Reply With Quote
Old 05-19-2013, 04:34 PM   #1163
pizzaman383
Oddometer: 90
Cool Camera Work
What kind of camera captured that video?
PizzaMan
Black 2004 Triumph Tiger
Author: Passionate About Pizza: Making Great Homemade Pizza
www.passionateaboutpizzabook.com
pizzaman383 is offline   Reply With Quote
Old 05-19-2013, 08:11 PM   #1164
borisattva
Oddometer: 2
great job guys!
nice to see another KTM in the mix. hopefully i can make the next session.
borisattva is offline   Reply With Quote
Old 05-19-2013, 08:19 PM   #1165
wiseblood
Hall Monitor
wiseblood's Avatar
Oddometer: 13,270
Originally Posted by borisattva View Post
great job guys!
That would be me.
Nothing like video evidence to see how slow you are.
"Hard Work Often Pays Off After Time, but Laziness Always Pays Off Now."
Big Apple Tag-o-Rama Maps: Click Here!
wiseblood is offline   Reply With Quote
Old 05-19-2013, 08:22 PM   #1166
Vulfy OP
Vulfy's Avatar
Oddometer: 573
Most probably a go pro connected to a balanced pole on top of his helmet with a 360 degree pivot. I would like to see his set up myself. Go pro is not super heavy but it, its counter balance as well as the pole and mounting hardware would make it a "once per day" set up. Just too heavy to have it on your head for prolonged period of time. Still very cool setup.
Old 05-19-2013, 08:44 PM   #1167
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,944
https://www.facebook.com/RotoRmount
http://www.rotormount.com/RotoR/home.html
Hurricane Bob is offline   Reply With Quote
Old 05-22-2013, 12:50 PM   #1168
Motogymkhanaman
Oddometer: 211
A little video from our friends in Poland advertising an upcoming event.
The Moto Gymkhana series in Poland was originally set up by Honda, but this year they are only doing one event so the riders decided to strike out and run their own series as well. Just shows that once you start Moto Gymkhana you can never stop!
Old 05-22-2013, 01:08 PM   #1169
Vulfy OP
Vulfy's Avatar
Oddometer: 573
Moto Gymkhana with an attitude, I like it
on organizing their own events.
I'm subscribed to the guy in black leathers, on YouTube. Guy definitely knows how to ride!
Old 05-25-2013, 06:57 PM   #1170
ohgood
ohgood's Avatar
Oddometer: 2,996
Rear 17" will be her Monday, can't wait to spin up some sticky tires!
Looks like well be doing some night time gymkhana events this summer, lighted cones and cool night rides. Sweet!
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Times are GMT -7.   It's 08:13 PM.
