Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 06-22-2013, 12:00 AM   #1216
rthuey
twist your wrist!!!
rthuey's Avatar
Oddometer: 2,831
on the Piaggio?!?
We're gonna go ridin!!!
rthuey is offline   Reply With Quote
Old 06-22-2013, 07:35 PM   #1217
Vulfy OP
Vulfy's Avatar
Oddometer: 574
Today's session video. Fun times.
Vulfy is offline   Reply With Quote
Old 06-22-2013, 08:04 PM   #1218
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,292
Thanks for setting up the course and letting a newb like me play. Looking forward to more of it, just not sure if I will be in the city on any weekend soon.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 06-23-2013, 04:13 AM   #1219
Jezza
A British Invasion
Jezza's Avatar
Oddometer: 1,246
Many thanks for arranging everything, I really had fun riding 4 separate courses each with their own challenges
Four Continents ridden, three to go
www.moto-gym.com
Jezza is offline   Reply With Quote
Old 06-23-2013, 11:39 AM   #1220
Vulfy OP
Vulfy's Avatar
Oddometer: 574
Glad you guys enjoyed it. We need to start doing timed trials again. Too bad Stephen wasn't there this weekend, he is very competitive, would have been a lot of fun. Next time.
Old 06-23-2013, 04:10 PM   #1221
Sckill
Sckill's Avatar
Oddometer: 247
Sorry, I was busy traveling up to VT also buying a new to me red bike.
I'll make it next time.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Current: 2012 Yamaha Super Tenere, 2007 Honda CBR600RR
Past: 2006 Honda 919, 2004 Honda 919, 2007 Honda 919, 2008 Suzuki SV650S
Sckill is offline   Reply With Quote
Old 06-23-2013, 06:43 PM   #1222
Vulfy OP
Vulfy's Avatar
Oddometer: 574
oooooooh, purdy! Which one is that?
Never mind, its 919. Looked it up.
Old 06-23-2013, 07:05 PM   #1223
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,292
Went back through some of this thread, and no I understand why Vulfy's rear brake kept boiling. Seems so unintuitive to use the rear brake versus the clutch. I want to play with that at some point. I might need to grab some cones and keep them on my bike when i travel
I put a higher compression piston into the DR yesterday and finished it this morning. The engine braking is much, much higher. I wonder how that will feel as well.
Old 06-24-2013, 09:41 AM   #1224
ohgood
ohgood's Avatar
Oddometer: 3,111
tell us more about the dr ! imy buddy swapped a 435cc into his dr350 yesterday, and its a freaking HOOT !
the rear brake does a great deal of stability control (for me). try it, you'll like it, if your gearing is too high. if gearing is low enough, engine braking works great to smooth out entries.
if you want to take cones with you, toss some dixie cups in a napsack. ;-)
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is online now   Reply With Quote
Old 06-24-2013, 11:18 AM   #1225
Robert^
Oddometer: 85
http://www.citybikerblog.com/2009/06/low-speed-trick/
More control.
Robert^ is offline   Reply With Quote
Old 06-24-2013, 11:38 AM   #1226
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,292
I use the rear brake a lot. I used to roadrace 2-strokes as well as race a 2-stroke in the woods. But as for using it versus the clutch is going to be a learned technique. I do have to say that after watching Vulfy and his boiling rear brake I think there needs to be a balance. But what do I know this was my first time trying it and I was sloppy as hell and have no idea what I am doing.
I have a semi-ratty DR I built from a junk pile. With that it has some good parts on it. I bought a DR from someone who used it on a farm and had no papers it was rough. Rusty leaking fork seals, no front fender, headlight, gauges, and side covers. A friend was selling his modded DR so we swapped some parts and cash and I got from him, forks with springs and emulators in them, rear shock with emulator and spring, Keihin FCR-MX41, and some happy-trail luggage mounts. I found a titled stolen recovery frame and put it all together, and then Ebay and on here I got the rest of the parts. Only things I bought new were a seat concepts cover, Shinko 705's and an Acerbis tank that I got for half-price through an enduro racers discount.
It smoked really bad at startup and I needed to do valve seals. While I was in there I decided to do a piston. I worked for the JE distributor so I paid less than dealer cost for one.
After Saturday's session I tore it apart, changed the valve seals, and gapped the piston rings. Sunday morning when it was cold, I put it all back together and rode it a bunch. It rides good, but not insane.
Old 06-24-2013, 01:04 PM   #1227
Robert^
Oddometer: 85
I use the rear brake a lot.... But what do I know this was my first time trying it and I was sloppy as hell and have no idea what I am doing.
I have a DR650 too and I have played around in a local parking lot. Avon Gripsters are great and you will reach the edge on the front before the rear. Regarding the brake, using it well with a heavy boot on is an acquired skill. At a certain point the DR seems to want to turn in by itself. Incidentally, a barbeque rack and bar end thingys will keep the blinkers from getting broken off if the bike falls over.
Regarding boiling brake fluid, it may have had moisture in the system. The correct silicone fluids don't appear to have the same moisture absorption or seal compatibility problems.
Old 06-24-2013, 02:13 PM   #1228
Vulfy OP
Vulfy's Avatar
Oddometer: 574
Yeah.... rear brake....
Well don't take me as an example. If you browse through this thread, especially the beginning posts, you'll see that I've had boiling issue on rear brake for quite a bit of time on my Triumph.
After a while I finally was able to ride without boiling it. It was a combination of better brake fluid and pads, better control of the bike, and augmenting rear with front brake, to take off some load.
So yes, it is definitely a skill related issue first, and equipment second.
In my own defense I must say that I'm still getting to know the SV650 so I am still a bit ham-fisted with it. Most of the time I'm reving it too high for the turns I'm negotiating, and I'm dragging the rear almost ALL the time, which I know I shouldn't be doing, thus overheating it much sooner.
I'm also really disliking front brake on this bike. It fades really quickly and just very spongy in general, plus I have to squeeze the lever almost 2/3 of the way before brakes start to bite in.
So in the end, on my part its a combination of skills and equipment. Need more time on the bike to be really comfortable on it (Gymkhana riding that is, on street its fine) and also need some minor upgrades such as better brake fluid, pads and maybe braided lines.
Rear brake is your friend in Gymkhana. Taking away power from rear wheel with the clutch is not very good, and makes bike feel limp. Rear brake tightens up the whole thing like a wound up spring, and when you do it right, it springs you out of the corner.
Old 06-25-2013, 02:02 PM   #1229
opmike
Choosing to be here.
opmike's Avatar
Oddometer: 345
I had the same brake lever pretravel issue on my SV. Assuming you've evacuated all the air from the lines, calipers, and master, what is happening is the caliper piston seals retract the pistons too far back away from the rotors once the brake lever is released. From my research, this only affects some bikes, so asking around for help online was a huge exercise in frustration for me.
On most bikes, this is usually rectified with a new set of seals and/or a thorough cleaning, but my problem returned shortly after doing this. I can only assume some calipers have tolerance issues with the grooves that the piston seals reside in or maybe a funky run of seals is to blame.
A temporary fix is to "massage" the pistons in and out a few times to "reset" the seal grab point on the pistons. I finally got fed up with mine and installed a set of calipers off a CBR with adapter brackets. ZERO problems since. I'm super anal about brake feel so I just bit the bullet on this one.
Setting aside the pretravel stuff I mentioned above, the stock SV brakes shouldn't be mushy or fade all that quickly. My lever was solid once you go through the silly take-up zone. I'd make sure all the components check out first before doing aftermarket add-ons like braided lines to chase down a problem.
"you want to fix the Pledge of Allegiance, put a disclaimer at the end: with liberty and justice for all...must be 18, void where prohibited, some restrictions may apply, not available in all states."
opmike screwed with this post 06-25-2013 at 02:08 PM
opmike is offline   Reply With Quote
Old 06-26-2013, 08:18 PM   #1230
TheWall
0 miles and counting
TheWall's Avatar
Oddometer: 163
Hey, Vulfy
If you need performance parts (brake pads, braided lines, etc.) for your SV650 give Blair at svracingparts.com/ a shout. I've bought all the brake parts I've used on my DL650 from him, and his customer service is second to none.
TheWall is offline   Reply With Quote
Times are GMT -7.   It's 06:53 PM.
