Old 07-07-2013, 06:43 PM   #1246
Vulfy OP
Vulfy's Avatar
Oddometer: 571
I've had a few people asking where I'm getting the cones for our courses.
Bellow is the link to e-bay seller who has them in different colors. You specify which color you want at the checkout with a "note to seller". They also do 25/25 split of two colors if you want.
Please note, that I'm not affiliated with the seller, and I'm just sharing where I get my cones.
Also note, that these cones are not the official cones that are used in Japanese, UK and Alabama events. However they are proven to be excellent cones for our NYC purposes by being cheap, portable in large quantities, durable (been run over multiple times without cracking), and wind proof, so that they don't fly off or move with gusts of wind.
http://www.ebay.com/itm/350598833414...84.m1423.l2649
Vulfy is offline   Reply With Quote
Old 07-08-2013, 03:43 PM   #1247
Rango
Phaneropter
Rango's Avatar
Oddometer: 1,200
Thanks. Great find.
Cheap as chips too
Moriunt omnes pauci vivunt
Rango is offline   Reply With Quote
Old 07-09-2013, 08:35 AM   #1248
Vulfy OP
Vulfy's Avatar
Oddometer: 571
Just a quick update on the front brakes of SV650. Changed out brake fluid, that didn't do anything. Travel was still excessive and with hard braking was pinching my fingers on the throttle.
Dug into the interwebs and found out that its a pretty common occurrence on the bikes, and not only on SV650.
Seems the cause of that is either a bad seal inside master cylinder, or in my case just a grimy piston that is sticking in the caliper.
Removed front calipers from the forks and squeezed brake lever to see what was going on. One piston in each caliper was sticking and not moving out fully.
Drained the system, removed pistons, cleaned everything out, lubed pistons and seals with brake grease, refilled and re-bled the system.
Now front brake is nice and firm, and engages at proper distance from the handle bar.
Old 07-10-2013, 10:04 AM   #1249
Vulfy OP
Vulfy's Avatar
Oddometer: 571
Session this Saturday 07.13.
8am - 1pm
PM me if you plan on going, and I will send you the location and details.
Alternatively, if you are on Facebook, join our group that has schedule and all the details.
https://www.facebook.com/groups/motogymkhananyc/
Vulfy screwed with this post 07-10-2013 at 10:05 AM Reason: Wrong date.
Old 07-10-2013, 07:28 PM   #1250
Vulfy OP
Vulfy's Avatar
Oddometer: 571
07.10 Trykhana GP practice.
34 seconds and less = Gymkhana God
35 seconds = Master
36-37 = Good
38-39 = Young Grasshopper
40-44 = You can do better
45-54 = Need more practice
55 and up Enjoying the cruise
Vulfy screwed with this post 07-10-2013 at 10:20 PM
Old 07-10-2013, 10:20 PM   #1251
Vulfy OP
Vulfy's Avatar
Oddometer: 571
This is incredibly fast!
Old 07-11-2013, 07:13 AM   #1252
Harvey Krumpet
Oddometer: 908
That is off the scale.
Notice the size of the rear sprocket on the green bike?
And the hip flexibility of the blue rider....
Harvey Krumpet is offline   Reply With Quote
Old 07-11-2013, 08:19 AM   #1253
ohgood
ohgood's Avatar
Oddometer: 2,903
I missed the dimensions and pattern for the trykhana (or is it gp trykhana ?) you posted a video of.
looks like no " 8 " is involved, but a left right left for each corner ? is there a gate ?
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 07-11-2013, 08:24 AM   #1254
Vulfy OP
Vulfy's Avatar
Oddometer: 571
ohgood: here is the diagram for Trykhana with all the dimensions. It is a sort of a figure 8.
http://caramel.xsrv.jp/hgc/trycahna.html
Harvey: yeah I wonder if there is some sort of formula or calculation to figure out the rear sprocket size.
Old 07-11-2013, 09:12 AM   #1255
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,268
The top guys likely carry an assortment and look to max revs in first gear on fastest part of course. If I come Saturday I want to try a smaller front sprocket, I run larger than stock for sustained high speed, but will go down one smaller than stock to play.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 07-11-2013, 09:23 AM   #1256
Vulfy OP
Vulfy's Avatar
Oddometer: 571
You think its matched to the max revs at the fastest stretches?
I always assumed it was for the hardest torque to accelerate as much as possible out of the corners. I've seen some of the guys do a wheelie out of a corner.
Wouldn't larger rear sprocket drop your RPMs?
I'm still very hazy on the whole concept of how sprocket size affects top speed, torque and acceleration.
Old 07-11-2013, 09:39 AM   #1257
Sckill
Sckill's Avatar
Oddometer: 235
Using a smaller front sprocket or larger rear sprocket results in 3 things:
1. Higher engine RPM needed to maintain a given rear wheel speed
2. Higher torque / acceleration
3. Lower top speed
It all comes down to the ratio of the front to rear sprockets.
Current: 2012 Yamaha Super Tenere, 2007 Honda CBR600RR
Past: 2006 Honda 919, 2004 Honda 919, 2007 Honda 919, 2008 Suzuki SV650S
Sckill is offline   Reply With Quote
Old 07-11-2013, 03:33 PM   #1258
Harvey Krumpet
Oddometer: 908
Some bikes have quite a big gap between 1st and 2nd, I should imagine for gymkhana this could be irksome, over revving in 1st or under revving after the up shift. Lowering the gearing would give more flexibility in 2nd & fewer gear changes.
I've geared down pretty much every bike I've owned. For some reason the open road speed limit does not match the engines happy place. On the TDM with standard gearing 100kmh in top was about 3700 rpm, just under that happy place & lacking responsiveness when i opened the throttle. One tooth less on the front & it sits at 4000rpm but has significantly more torque available when i roll on or for hills & strong head winds. Makes the bike nicer (& lazier) to ride.
Old 07-13-2013, 11:56 AM   #1259
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
Cool2
Originally Posted by Vulfy View Post
........I'm still very hazy on the whole concept of how sprocket size affects top speed, torque and acceleration.
Imagine that your transmission has only one gear combination with which you have to live.
Sprockets are nothing but levers.
That lever attached to the output shaft (front sprocket) can do with the twisting force coming from that shaft (output torque) only what levers do: to apply a tangential force at its free end (tension on the chain), more if the lever is short (few teeth), less if the lever is long (more teeth). For the same reason, that chain will move slower in the first case and faster in the second case. As transmitted power = force x speed, it remains the same for either case.
The lever attached to the rear wheel (rear sprocket) can do with the tangential force at its free end (tension on the chain) only what levers do: to apply a twisting force to that rear tire (wheel torque), which becomes a rearward pushing force at the contact patch. That force will be less if the lever is short (few teeth) and more if the lever is long (more teeth). For the same reason, the bike will move faster in the first case and slower in the second case. As transmitted power = force x speed, it remains the same for either case.
For brilliant acceleration, you want big force at that contact patch (a = F / m).
That twisting force coming from the transmission shaft (output torque) reaches its peak value only for the range of rpms' at which the manufacturer of the bike claims that maximum torque is achieved by the engine.
The right combination of sprockets should put your engine in that sweet spot for the power demanding part of the particular Gymkhana exercise.
lnewqban is offline   Reply With Quote
Old 07-13-2013, 02:07 PM   #1260
Mazaev
Mazaev's Avatar
Oddometer: 218
Finally made it out today. Tons of fun, and surprised how exhausting it gets. Boots all scuffed from scraping (and kicking cones) .
Some pics:
Mazaev is offline   Reply With Quote
Times are GMT -7.   It's 12:07 PM.
