Old 05-09-2012, 07:17 PM   #16
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,154
It seems to me to be an ignition problem. I am new to these bikes, but is there separate cdi boxes for each cylinder? If so try switching them. Also check out the ignition pulsers make sure the one bad cylinder has not moved.
Keep at it you will figure it out.
-John
An Elefant never forgets.
www.Raceforthewounded.com
azcagiva is offline   Reply With Quote
Old 05-09-2012, 08:49 PM   #17
David37
David37's Avatar
Oddometer: 405
This is a tough one, IMO I would try checking your plug wires, plug caps, plug wire connection to coils. I also would check your battery cables, battery connections, especially your ground connection to your frame. Lastly, try checking your voltage regulator.
David37 is offline   Reply With Quote
Old 05-09-2012, 09:39 PM   #18
MJS
MJS's Avatar
Oddometer: 1,913
Time for a leak down test. You checked the intake valve with carb cleaner but what about the exhaust? The symptoms could be caused by a burned or leaky exhaust valve. Listen to the exhaust pipe, the carb (with throttle open) and the crankcase vent when you have air in the cylinder. That will give you an idea of what is leaking if you have a problem.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 05-09-2012, 10:01 PM   #19
WhereTheHellIsJames? OP
WhereTheHellIsJames?'s Avatar
Oddometer: 52
Originally Posted by GZERO View Post
Next would be compression and leak down test, because if it has spark, fuel is fine and air is fine then the problem is "the pump" meaning rings or something like that.
I think you guys are right here. I don't have a leak down tester, but maybe I can borrow one from someone. I'll ask around and see if anyone locally has one that I can use. BTW, on a bike like this, should I just run it up in the same neighborhood as I would on a car (around 100 psi)?
How many miles does this engine has?
Just a little over 12k miles.
WhereTheHellIsJames? screwed with this post 05-09-2012 at 10:06 PM
WhereTheHellIsJames? is offline   Reply With Quote
Old 05-09-2012, 10:18 PM   #20
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,151
You can do the same test on the exhaust valves as you did on your intakes, pull the exhaust pipe and pour some gasoline on the valves with the engine at TDC. Sounds fishy to me, I don't think it's the valves.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 05-13-2012, 10:36 AM   #21
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,154
Any news?
Old 05-21-2012, 03:36 PM   #22
Oddometer: 52
Sorry for the lapse in time between posts!
On Saturday I picked up a leak-down tester from one of the local shops that I used to have a working relationship with. Actually, since they were cool enough to let me use their tools, I'll give SF Moto a plug here- all the folks there are awesome. If you're in the bay area, and in market for a scooter, a used motorcycle, or aftermarket or OEM parts, give Eric, Andy, Tony or Thomas a call... they'll treat you right, and it's good to support businesses that care about supporting the motorcycling community, not just about selling bikes.
Okay, back to the matter at hand here... just moments ago, I finished the leak-down test. The results came as no surprise to me, as I've confirmed that everything above the intake valves is good, and everything below the exhaust valves is good.
This afternoon, I tore down the bike for probably the dozenth time since the issue arose. Everything went smoothly, and I hae to admit, I feel like I'm getting pretty efficient at tear-down and build-up of the 950 Adventure. A skill that admittedly, I've never really wanted. I got the crash-bars, fairings, tanks, carbs, air-box, and valve covers off. Pulled the plugs, and set the front cylinder to TDC. I bought one of those bolt-like tools with the allen end to hold the cylinder in exactly TDC a couple weeks ago, but couldn't find it... so I just lined up the dots and confirmed the lobe positions on the cams. Plugging the hose into the spark-plug hole was a cinch, and I hooked up the air to the tester. I could hear that there was a leak somewhere. Just to confirm, I pulled the header from the front of the cylinder. Yep, definitely an exhaust valve leak... a big one too.
Looking at the valves, I was surprised to see how grungy the ports and stems were. There is all sorts of hard, crusty build-up in there. It almost looks like this bike never had an air cleaner on it. I've had a look at probably a hundred or more heads, and have never seen anything like it. Looks like caked on dirt / mud / creosote. Nasty.
Anyways, problem identified. Now what? Does anyone with experience have suggestions of where to (or for that matter, where not to) take / send the heads off for rework? I'm assuming that it's appropriate standard procedure to do both heads instead of just the one that's giving issues... can anyone confirm this? Since the bike will be torn down to the point where the heads are removed, is there anything else that might as well be done at his time while the engine is this far apart? FWIW, the bike has 12.5K miles on it.
Old 05-22-2012, 05:42 AM   #23
GZERO
Fixing stuff around
GZERO's Avatar
Oddometer: 265
Since you have some kind of experience mechanically, i would suggest yourself. It's not hard, you even have a manual to guide you trough it. (it's not like you have to do much to a 10k miles head, just take the valves out, inspect them, change the oil seals on the valves, clean, graduate valves and that's pretty much it.)
If the front is like that and the rear is not i would suggest into looking at two things, the engine breather oil seal (on the rotor side of the engine) gets damaged and it will start to eat a lot of oil, especially the front cylinder (which i believe you are experiencing this) also, the breather hose (the one that goes from the right side of the engine, rotor side, to the air box) well our models have a hose and that's it, later on they changed that for a hose with a one way valve.
So, to sum up, if your front looks ugly and the rear is perfect i would bet this is your problem altough it might have something to do with a valve with too little free play.
Still, 10k miles is NOTHING to these engines, so it's pretty weird to hear all this.
GZERO is offline   Reply With Quote
Old 05-31-2012, 09:51 PM   #24
GZERO
Fixing stuff around
GZERO's Avatar
Oddometer: 265
did you fix it?
Old 06-01-2012, 09:38 AM   #25
Pointman0853
Unregistered Gun Owner
Pointman0853's Avatar
Oddometer: 1,494
Ignition
Have you tried swapping the ignition coils? They may show spark out of the cylinder, but its another thing under compression.
Using a ampmeter, check the resistance in each. I've had these go bad on other bikes...
Pointman
AMA Life Member 600475
IBA #5
CarsonMotorSports.com
Pointman0853 is offline   Reply With Quote
Old 06-01-2012, 09:44 AM   #26
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 20,766
How about exhaust seals at the header? Pull the header and see if there is a seal, or any dust remnants of a seal. May be a long shot, but I saw something sort of similar happen to a buddy's SE. Good luck!
Edit to add- whoops _ it seems like you've gotten to the bottome of the problem. You got that far, you can go the rest of the way. It's not hard. Good luck again!
unaweep is offline   Reply With Quote
Old 06-03-2012, 06:56 AM   #27
1911fan
Master of the Obvious
1911fan's Avatar
Oddometer: 3,255
did you fix it?
1911fan
Read The Patriot Post -- It's Right. It's Free.
http://patriotpost.us/subscribe/
Sometimes the light to see your way forward is provided by the bridge burning behind you.
1911fan is offline   Reply With Quote
Old 06-03-2012, 09:23 AM   #28
sledstorm1
CT RAMBLER'S MC CLUB
sledstorm1's Avatar
Oddometer: 856
Happened to my son's 250 xcf... one month of trying to figure out why it's misfiring...broken spark plug cap, arching at odd times, wet and just close enough to cylinder... ya never know
To those who understand, no explaination is necessary
Too those who don't, none is possible...
sledstorm1 is offline   Reply With Quote
Old 06-03-2012, 11:23 AM   #29
unaweep
unaweep's Avatar
Oddometer: 20,766
+1. This JUST happened to me with a BRAND new 500 EXC- I switched out the exhaust and it would back fire and stall. I spent all day trying to figure out what I could have done wrong- only .1 hours on the clock.
I was comparing the plug on that bike to another 500 EXC and my greasy hands exposed the crack in the procelain.
Old 06-05-2012, 11:34 AM   #30
2aroundtheworld
Oddometer: 39
Everyone
I am the owner of this bike...James has been extremely nice and put a lot of work on it trying to figure out the problem...
It seems like we are now down to the exhaust valve, so I'll start working on it with him as soon as possible. Despite the problem (s), I am missing the bike right now and would love to ride it again.
thanks again for everyone's input on this - we will keep you posted!
2aroundtheworld is offline   Reply With Quote
Times are GMT -7.   It's 04:00 PM.
