Old 05-08-2012, 05:07 PM   #1
Ducs2Dirt OP
Not quite all there
Ducs2Dirt's Avatar
Oddometer: 168
Is this tire done for?
I rode to work this morning as usual and when I parked the bike i noticed the road left me a little gift on the back Tourance EXP. I got in close and it looked like this.
iphone unload 5812 215
I didnt have time to the check the pressure the morning, so i left it and got to work. When I got out of work and started to get ready to head home, I took a pressure reading and it didnt drop all day. I rode home and tested the pressure again and still it was at 40lbs.
So after I took off all my gear I checked out the nail and it seemed to of punctured the tire at a very steep angle. I saw the other half the nail bulging out the tread around it. So I dont "think" it went straight thru making a hole. It just just under the tread a bit, like a sliver.
So i felt brave and pulled it out and this is what it was.
iphone unload 5812 217
I tried a emulate the angle it was piercing the tire with the needle nose pliers.
So far no drop in pressure and no bubbles when I tried soapy water and sitting on the bike.
So, keep on riding or finish the hole and plug it or get a new tire on there? Its got me on fence since its was a puncture, but not all the way thru at the angle it was at. The total length of that nail was about 5/8" of an inch long...maybe 3/4" tops. Thanks
2011 1200 GSA
1995 1100 GS (sold)
2013 S 1000 RR
Ducs2Dirt is offline   Reply With Quote
Old 05-08-2012, 05:16 PM   #2
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,336
Ride it!!!
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 05-08-2012, 05:20 PM   #3
tkent02
Oddometer: 2,468
+1, Ride it.
It didn't go deep enough to hurt anything IMHO.
tkent02 is offline   Reply With Quote
Old 05-08-2012, 05:31 PM   #4
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,616
Ride it!
Only try to plug it if it is loosing air.
Flashmo is offline   Reply With Quote
Old 05-08-2012, 05:37 PM   #5
Ducs2Dirt OP
Not quite all there
Ducs2Dirt's Avatar
Oddometer: 168
Thanks guys. Ride it, it is.
So far i havent lost an ounce of air, so if its still 40lbs or so in the morning, I'm puttin on the rain gear and heading out.
Im actually kinda bummed in a way, I wanted to kill this EXP and get a plain old Tourance. I guess im stuck doing it the old fashion way.
2011 1200 GSA
1995 1100 GS (sold)
2013 S 1000 RR
Old 05-09-2012, 07:32 AM   #6
Ducs2Dirt OP
Not quite all there
Ducs2Dirt's Avatar
Oddometer: 168
Ehhhh. On second thought I'm gonna get a new tire. After letting the bike sit on the side stand all night long, it lost 2.5 lbs overnight. At 7pm last night it was 40.5psi. This morning at 7am it was 38 psi. When I get home tonight and it's at 36psi or something,I'm taking it off and bringing it in. Must be a ultra slow leak.
I might get a plain Tourance instead of another EXP. nice tire but too soft.
2011 1200 GSA
1995 1100 GS (sold)
2013 S 1000 RR
Old 05-09-2012, 09:29 AM   #7
kpt4321
kpt4321's Avatar
Oddometer: 1,674
Sure it's didn't just loose pressure due to cooling down?
I would ride that, unless it was through.
Of course, if it was through I would just plug it and ride it.
TAT 2008 / Colorado 2010
"Both the man of science and the man of action live always at the edge of mystery, surrounded by it." -Oppenheimer
2007 Monster S2R / 2006 TE610 / 1999 KDX 200 / 2000 DRZ-E
kpt4321 is offline   Reply With Quote
Old 05-09-2012, 10:42 AM   #8
Ducs2Dirt OP
Not quite all there
Ducs2Dirt's Avatar
Oddometer: 168
Good point, that completely skipped my mind. It's quite possible it lost a pound or so from the cool down. I'm hoping that's the case. As much as I want a new rear tire, throwing a 150 bucks out the window right now isn't fun.
When I get home I'll check it. If it's still at 38psi when I get home I'll leave it. If it dropped even more then I'll consider a new tire or plugging it.
2011 1200 GSA
1995 1100 GS (sold)
2013 S 1000 RR
Old 05-09-2012, 01:47 PM   #9
speedracertdi
speedracertdi's Avatar
Oddometer: 985
Ride it. Pulled a screw out at a similar angle of my boss's tire on his car the other day. It was just in the tread and never pierced all the way through.
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 05-09-2012, 02:27 PM   #10
ragtoplvr
Oddometer: 6,343
After the Joplin tornado our streets are full of this stuff. I have pulled out 2 so far that did not go thru. Not worried. I will be pissed when one does go thru, but I will plug it and ride it.
Rod
ragtoplvr is offline   Reply With Quote
Old 05-09-2012, 10:03 PM   #11
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,301
If you are concerned just dribble some soapy water on the hole and see if you get bubbles. Even a tiny leak gives noticeable bubbles.
GreaseMonkey is offline   Reply With Quote
Old 05-10-2012, 08:46 AM   #12
perterra
perterra's Avatar
Oddometer: 7,400
If it is leaking just plug it, or pull the tire and put a boot on it. (Old lingo, large patch inside the carcass)
I've ridden plugged tires for thousands of miles with no issue.
My Father was my maker. Poverty was my maker. Distrust was my maker. I have met them all my life.
IBA 22425
perterra is offline   Reply With Quote
Old 05-10-2012, 03:43 PM   #13
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,286
I'll usually lose a couple of pounds air pressure from trying to get the damn guage onto the stem when I'm trying to check it.
Like GreaseMonkey suggested, put the soapy water on it to be sure.
HapHazard is offline   Reply With Quote
Old 05-10-2012, 05:01 PM   #14
Ducs2Dirt OP
Not quite all there
Ducs2Dirt's Avatar
Oddometer: 168
^ Haha, That's what I was thinking this morning before I took off. By the time I got the gauge on and get a reading, I'm scratching my head...damn...was that 41 lbs before i let out enough air to read 40lbs.
After I filled up the rear to 42psi last night, it didnt lose an ounce of air overnight. So im chalking that 2lb loss from the warm tire. I checked the pressure this morning before I got ready and it didnt even lose a fraction of a pound overnight. Tried so soapy water last night too for he-ha's and not a bubble to seen. So, I rode today and it was fine.
Now that leave me with more money to buy more crap.
Thanks for the replies guys!
2011 1200 GSA
1995 1100 GS (sold)
2013 S 1000 RR
Times are GMT -7.   It's 11:29 PM.
