Old 11-14-2012, 11:33 AM   #1
bess227 OP
Oddometer: 59
HELP me out of the fog!!!
My morning commute is averaging 34 degrees, couple 29 degree mornings........I am toasty, but my visor on my MSR full face dual sport helmet fogs in a hurry. I try to keep it clean, but at times it is almost dangerous.
Besides dropping the coin for a pinlock.........any cheap (i ride a KLR) fixes for the visor?? Does Cat Crap really work?
Thanks up front for the info.
bess227 is offline   Reply With Quote
Old 11-14-2012, 11:56 AM   #2
James Adams
Yankee
James Adams's Avatar
Oddometer: 4,429
Pinlock shields are worth it--they simply work. They aren't cheap, but it's a one-time cost (per shield) and takes just seconds to install.
All of my street helmets are Pinlock-equipped and I recommend it to everyone looking for a permenant anti-fog solution. Anything else is just temporary at best.
James Adams is offline   Reply With Quote
Old 11-14-2012, 11:59 AM   #3
MikeJansen
Lost
MikeJansen's Avatar
Oddometer: 79
NikWax Visor Proof is a great hydrophobic coating for anti fog and anti rain. It is also the only product that is water and not alcohol based. Plexus is also a fantastic product for the misting but as it is solvent based might invalidate your visor warranty.
I have also had great results using a cloth that I got at a ski shop made by Scott that is for glasses and goggles but I lost it about 2 years ago and have not found a replacement on this side of the pond.
I also wear glasses at all times so in the city (below 50mph) I ride with the visor cracked just a bit.
Other than that? Try a scuba shop for anti fog products. Also spit worked on my snorkeling equipment when I was a kid. . .
"A good traveler has no fixed plans and is not intent on arriving." - Lao Tzu
MikeJansen is offline   Reply With Quote
Old 11-14-2012, 12:11 PM   #4
motorat
nOOb
motorat's Avatar
Oddometer: 537
if you want a really cheap solution then put a drop of dawn dish soap on the inside of the visor.
wipe it all around and then wipe it off...don't use water you want to leave a light film but do wipe it all off
so you can see clearly. down side is that you will probubly have to do this every other ride.
or get a fog city....less than pin loc but scratches very easily.
Joe
08 Vstrom 650 abs
motorat is offline   Reply With Quote
Old 11-14-2012, 12:31 PM   #5
Too_Tall
The Belgian
Too_Tall's Avatar
Oddometer: 400
Another +1 for the pinlock. This is not something to save money on, your vision is VERY important in a car and even MORE important on a bike. While some methods do work, a pinlock takes no time in the morning, and it's not that expensive.
Yamaha XT1200Z Super Ténére
Too_Tall is offline   Reply With Quote
Old 11-14-2012, 12:32 PM   #6
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 3,859
Scott Anti-Fog Cleaner: http://snowcitymi.com/catalog/index....roducts_id=138 (Google for more sites)
Crack the visor a bit. You aren't in a pressure suit and won't go hypoxic.
Crack the wallet and buy a Pinlock. Is a few bucks worth your life?
--Bill
'73 R60/5 Toaster
Old 11-14-2012, 12:38 PM   #7
74C5
74C5's Avatar
Oddometer: 759
Foggy Respro Mask. Works very well. It keeps your breath off of the inner side of the shield.
R1200RT (R1100RT gone)
KLR650
Don't be the guy who needs to pee on the fence to figure out that it's electrified.
74C5 is offline   Reply With Quote
Old 11-14-2012, 12:55 PM   #8
Conedodger
Wanna Ride
Conedodger's Avatar
Oddometer: 119
Love my pinlock. Talked a buddy into one earlier this month. He says it is the best money he's spent on riding gear.
Conedodger is offline   Reply With Quote
Old 11-14-2012, 01:03 PM   #9
daveinva
Oddometer: 414
What I would like to know is why no (?) helmet manufacturers make a factory double-paned visor.
I love the Pinlock as much as the next guy, but it seems to me that offering an entire visor double-paned would be a more elegant and robust solution (I find the the Pinlock shields end up getting warped out of shape and loosen over time, allowing crud and eventually fog to form underneath them. They're cheap enough to replace, but again, a proper double-pane visor would solve the problem permanently, no?).
daveinva is offline   Reply With Quote
Old 11-14-2012, 01:06 PM   #10
PT Rider
Oddometer: 485
...Rub bar soap or any surfactant dry or very slightly moist on the inside, buff off.
...Use any of the commercial no fog products. I've used several, and they almost work.
...Pinlock or a similar product
...Deflect your breath away from the shield.
...Improve the ventilation up & past the inside of the shield.
...Wear a helmet that has a dual pane snowmobile shield available if you have one
...Buy a snowmobile helmet with a dual pane shield
...Buy a snowmobile helmet with an electric heated dual pane shield, essential for freezing rain.
It's not what you look at that matters, it's what you see.
Henry David Thoreau
PT Rider is offline   Reply With Quote
Old 11-14-2012, 01:49 PM   #11
FlySniper
Bleh...
FlySniper's Avatar
Oddometer: 1,594
This is what I do.
Front and back of my eyeglasses and inside of my visor. Lasts for a week or so ... works great.
I apply a very thin coat of detergent, let it dry to a haze and buff until clear with an old t-shirt.
A feeling of having made the same mistake before: Deja Foobar.
"Think about how stupid the average person is. Now, realise that half of them are dumber than that." - George Carlin
FlySniper is offline   Reply With Quote
Old 11-14-2012, 01:56 PM   #12
PeterW
Oddometer: 1,974
3M stainless steel polish (Spray can, non-abrasive) works like Dawn, but lasts quite a bit longer.
Pete
PeterW is offline   Reply With Quote
Old 11-14-2012, 01:57 PM   #13
orangebear
orangebear's Avatar
Oddometer: 705
just get a pinlock takes mins to fit and works well. or keep the visor open a bit to keep air flow in and it will not fog up plus open the vents to.
bmw r100gs i ride it all year round
bmw r100/7 sold
bmw r1oo/7 sold
road legal stomp pitbike sold
orangebear is offline   Reply With Quote
Old 11-14-2012, 01:58 PM   #14
James Adams
Yankee
Oddometer: 4,429
HJC does.
I have one on my coldest-weather helmet and it works great. It's heated and has extra venting so it does a good job keeping my nose warm and glasses clear, too.
Old 11-14-2012, 02:02 PM   #15
orangebear
orangebear's Avatar
Oddometer: 705
Originally Posted by James Adams View Post
HJC does.
i hope shoei sell one as i would buy it.
its a shame hjc sell nice visors like that. after my one and only hjc lid had a visor that would open at speed and leak in the rain i have never gone near a hjc again.
bmw r100/7 sold
bmw r1oo/7 sold
Times are GMT -7.   It's 11:08 PM.
