Old 05-09-2012, 07:57 PM   #1
DiabloADV OP
Semi-Occasional
Oddometer: 2,336
R90/6 Texas Dirtbike rebuild
So I picked up this dirtbike. Will be doing a frame-off refresh, and change the styling a bit more toward scrambler. Figured I'd start a thread so I can ask all my questions and give progress reports in one spot. The bike starts and I rode it 20 miles home, but it's really rough. Won't idle and the exhaust pressure between the two sides was WAAAAAY different. It needs some love. Previous owner got it running after it was sitting for 5 years, but that's all he did.
Folks will want to see the rear end modifications. Extended swingarm, custom shock mounts and subframe. Cable-activated brake from custom brake lever.
Front is XR600 forks with CR500 hub. Nice fork brace down low.
I pulled the top end today and it's a sticky gooey mess. Wet carbon everywhere. Sealant half clogging up the stud holes. I'll take the heads, cylinders and pistons to somebody that knows more than me to have them assessed for next step. But...good news is no valve recession and the conrods seem perfect.
Anyhoo...more as it happens....
Rick
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 05-09-2012, 08:49 PM   #2
DiabloADV OP
Semi-Occasional
Oddometer: 2,336
Both exhaust nuts were frozen in an earlier time. Pushed on the wrench, used heat, etc...until the fins bent. Cut a slot, broke 'em loose and moving on to my spare set.
Old 05-09-2012, 10:04 PM   #3
DiabloADV OP
Semi-Occasional
Oddometer: 2,336
Some strangeness...
Pistons measure 93.3mm. Cylinders 93.7mm.
Book says R90/6 is 90mm. 100's pistons are 93.96mm (or bigger for overbores...).
So...what the heck do I have here...?
Any help....?
Old 05-10-2012, 07:25 AM   #4
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,583
Originally Posted by DiabloADV View Post
Some strangeness...
Any help....?
You had a 0.2mm gap all the way around? That seems high to me ... Both cylinders?
Not to be a jerk ... but are you sure you're reading your caliper right? If it is correct, then it's a WAY overbore on an R90 ... but I'll bet that it's a R100.set though.
Just tryin to help ...
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 05-10-2012, 09:15 AM   #5
DiabloADV OP
Semi-Occasional
Oddometer: 2,336
My caliper is accurate to withing +/- 0.1mm. Not good enough for machine work, but good enough to know these aren't stock R90/6 cylinders and pistons. Measuring at the middle ring, I get 93.4 on the piston. The bore is 93.7 in several spots. That's too much gap...
The rings all have end gaps in spec. Seems that if the bore was too big, the end gaps would be wider. Piston sides and skirts show no wear other than very slight marks up/down. The original machining marks are still on the piston sides.
But -- these pistons/bores are too big to be 90/6 overbores, and too small to match any of the 100 specs. I'm gonna have to take them in to a machine shop for proper measurement. The piston/bore gap should be ~0.04, not 0.15.
Off to see Ted with these in hand.
OK, EDIT...
Here's pics of the markings on the cyl and piston:
I scrubbed a bit on the top of the piston...
That would be the spec for an R100 piston. I must not be getting a good measurement. Will have them checked out.
DiabloADV screwed with this post 05-10-2012 at 09:38 AM
Old 05-10-2012, 10:17 AM   #6
Beater
Beater's Avatar
Oddometer: 3,583
There you go ... an R100 set. Yeah, I'd get those calipers checked out ... or better yet, buy a new set ... they can be pretty cheap these days. I actually have my grandfathers set ... it's a 'slide rule' type ... I can get 0.001 accuracy (with enough practice )
Those the iron bores? Might want to think about a set of Nikasil's ... Should be plug and play, and you'll never have this probelm again.
Old 05-10-2012, 11:32 AM   #7
DiabloADV OP
Semi-Occasional
Oddometer: 2,336
Those are cheap, right? Coupla bucks a pair...
Old 05-10-2012, 12:35 PM   #8
Beater
Beater's Avatar
Oddometer: 3,583
Something like that
Post something in the Airhead Flea and see what heppens ... I had a real kind inmate send me his after he went big on a Seibenrock setup. You never know what might happen.
This place is cool like that.
Old 05-10-2012, 05:30 PM   #9
DiabloADV OP
Semi-Occasional
Oddometer: 2,336
Took 'em down to an engine shop for proper measurement. The guy measures at the wide spot of the skirt (perpendicular to the pin). He used mics and then feelers for the final test.
I've got the bare minimum of clearance -- 0.03mm on each side of the skirt.
My end gaps of the rings are at their outside limit, so I'll replace those.
Now...on to the heads!!!
Old 05-10-2012, 11:41 PM   #10
Kai Ju
Kai Ju's Avatar
Oddometer: 1,910
"Measuring at the middle ring, I get 93.4 on the piston. The bore is 93.7 in several spots. "
Measuring at the ring lands is why you got the measurements you did.
If you put a straight edge up against the piston you'll see how far the ring land area is recessed from the rest of the skirt.
Pistons are at their smallest at the ring lands.
Your machinist picked the right spot.
Kai Ju is offline   Reply With Quote
Old 05-11-2012, 07:38 AM   #11
DiabloADV OP
Semi-Occasional
Oddometer: 2,336
I'm learning new stuff all the time!
Old 05-11-2012, 05:34 PM   #12
DiabloADV OP
Semi-Occasional
Oddometer: 2,336
It's nice to be expecting the worst and opening it up and finding this. Unretouched!
Old 05-28-2012, 08:30 PM   #13
DiabloADV OP
Semi-Occasional
Oddometer: 2,336
Getting farther along in the teardown (got sidetracked solving a bad cylinder problem). Anyhoo...here's the head tube setup.
The steer tube is ~25.8mm (+/- 0.2mm) at the upper and lower bearing. Isn't the stock airhead bearing 28mm ID...? My micrometer isn't perfect, but it's not that far off.
Any thoughts on what's been done here?
EDIT: I found the specs for an XR600 bearing -- 26mm, top and bottom. So, that's what I have here. Rather than an airhead steer tube pressed into the triple, I have a stock XR600 triple, with the head tube on my frame having been modified to fit. Good to know, should I ever need to replace the triples or the bearings...
DiabloADV screwed with this post 05-29-2012 at 07:02 AM
Old 05-28-2012, 09:17 PM   #14
DiabloADV OP
Semi-Occasional
Oddometer: 2,336
This is the wiring nest. Before I pull this apart, am I correct in observing that this is the regular wiring board, etc., just in this box instead of a headlight shell? If so, I should be able to reconnect it all with a std wiring diagram...?
Old 06-09-2012, 12:51 PM   #15
DiabloADV OP
Semi-Occasional
Oddometer: 2,336
Got the driveshaft apart. Here's a look at how the lengthening was done. It's about 3".
Times are GMT -7.   It's 01:47 AM.
