Thread Tools | Search this Thread | Rate Thread | Display Modes |
05-10-2012, 04:35 PM
#1 |
Oddometer: 50
Importing tracks to google maps on droid x
Hello
I have been using gpsvisualizer.com to view tracks on google earth and google maps on my pc. What I would like to do is have these tracks show up on google maps on my phone so I can use them to navigate from my X. The bottom line is I would like to have google maps or Earth open on my phone with the gps enabled so I can see the satalitte imagery, the downloaded track, and my current location as I ride. Any chance of this happening? Thanks, Matt PS I am a teacher and live in redding so I have the summer off and their is tons or riding around here so get in touch if you are headed this was and want to ride? |
05-10-2012, 07:23 PM
#2 | |
Super Lurker
Oddometer: 1,958
Have you tried My Tracks? It uses Google Maps and can Import and Export track. I have just played with it a little.
![]() Wee Stommin along. ![]() W/ABS |
05-10-2012, 08:10 PM
#3 |
Ride hard.
Oddometer: 2,268
05-10-2012, 09:15 PM
#4 |
Oddometer: 80
It's been a while since I used GPSVisualizer; however, if memory serves me, don't they provide a way to export your track to a file on your computer? If so, you can use GPSBabel to convert the track file to a KML file. The KML output file (from GPSBabel) can then be imported into your Google "My Maps" account for viewing. I outlined the conversion process in another post. However, I do not believe you will be able to view both your current position (in Google Maps) and the saved track in Google's My Maps, at the same time. I may be wrong about this last part, so let us know if you learn otherwise.
05-11-2012, 11:23 AM
#5 |
Super Lurker
Oddometer: 1,958
It will import tracks from the SD card. From a specific folder you set up. And it is import all the files only so you have the manage the files in a particular folder. They have to be in a gpx file and when you export you can export all or selected. Then there are features i have no tried to send to google and share. Does not do a lot but looks fairly simple.
05-11-2012, 11:28 AM
#6 |
from GE, save as a KML, then go to maps.google.com and click on my places, then Create Map. Follow the instructions to create "your map"
Then on your phone, tap the layers button in the upper right corner and select my maps, then select the map. The advantage to this of course, is having the track and then you can follow the track and cache the map for future use. The distinct disadvantage is that you must have a data connection to load the track each time. My tracks doesn't cache the tiles. DualSportMaps does however. the app is spendy compared to the others, but the features are all there. There is a thread in the vendors aisle. |
05-11-2012, 05:40 PM
#7 |
Super Lurker
Oddometer: 1,958
I went for a bicycle ride this evening and left My Tracks running on my Bionic. After 45 minutes it ask to shut off My Tracks to save the battery but does not shut off. Then I was able to share the track in Google Maps.
05-11-2012, 07:44 PM
#8 |
Lost in Georgia
Oddometer: 559
I do this.
Use OSMand. It will use Google maps, or a dozen other map types. Place the GPX file with your tracks on the android in the OSMand folder. I the app, just open the file. Your tracks are now on your Android. I have also used EveryTrail. Import the tracks, points and/or photos to the Everytrail web site. They view the trails on the Android app. |
05-12-2012, 06:29 PM
#9 |
Oddometer: 50
Thank you guys
I went on a ride today and used my tracks to record it. The I was able to view it in google maps (on pmy pc). Then I logged in on my phone and there it was. I havent checked if the same map will show my location at the same time. I will try the other techniques too. I really appreciate the feedback. PS: If i am using maps and I ride out of range will the track still show up without the map? So I can still follow it? Thanks, Matt |
05-12-2012, 06:35 PM
#10 |
Oddometer: 50
Heres my track from the day. Quick 40 miles...25 dirt. Beautiful.
05-12-2012, 07:18 PM
#11 | |
Super Lurker
Oddometer: 1,958
It was Back Country Navigator Pro. I thinks maps were extra.
![]() Wee Stommin along. ![]() W/ABS biker128pedal screwed with this post 05-12-2012 at 07:25 PM |
