05-15-2012, 08:22 PM
#16 |
Oddometer: 14
Put a whiteline rear swaybar on the Camry. Best $170 I've ever spent on a car. Does it make it a Corvette? No. But it goes from "this is boring" to "hey I can dig this"
05-17-2012, 06:35 AM
#17 | |
Oddometer: 1,665
What is the "design" of the head that results in sludge?
TAT 2008 / Colorado 2010 "Both the man of science and the man of action live always at the edge of mystery, surrounded by it." -Oppenheimer 2007 Monster S2R / 2006 TE610 / 1999 KDX 200 / 2000 DRZ-E |
05-17-2012, 06:43 AM
#18 |
Nerdly Adventurer
Oddometer: 1,037
Poor oil return flow due to small oil return passages. It allows the oil to overheat because the oil stays too long in the hottest part of the engine creating sludge that compounds the problem.
Individuality is best expressed individually; you are conforming in your non-conformity. |
05-17-2012, 08:27 AM
#19 |
Oddometer: 1,665
Oil return flow has to be the same as oil feed flow, otherwise eventually all your oil would be in the head and the pan would go dry. The rate at which oil is going up to the head has to be the same as the rate at which oil is going back to the pan.
Camrys are water cooled, right? What part of the engine is so super hot that it turns the oil to sludge? Why doesn't this happen in air/oil cooled motorcycles and cars, where the oil temps are way hotter? Just as importantly, what is the actual mechanism by which heat turns oil into sludge?
05-17-2012, 09:06 AM
#20 | |
Oddometer: 14
I don't really see what we need to explain, personally. Google it, it's well known amongst the Toyota community of the sludge. Toyota even sorta acknowledged it, then reversed their opinion... or something. I don't know full detail, but a quick search finds this -
http://www.toyotanation.com/forum/8-...t-journal.html Quote:
05-17-2012, 10:00 AM
#21 |
Oddometer: 7,200
Duh. I once serviced a low-mileage (48k, IMS) late-70s Camaro that was smoking and leaking. Popped the rocker covers off and the lower drainback holes were completely clogged and the uppers weren't much better. The whole upper end was coated in 1/4" of thick goo, even the rocker arms. The top of the engine was flooded with oil, because more was going up than could return, overwhelming the valve stem seals and the rocker cover gaskets, and may have been getting sucked into the PCV system. I had to wash out the whole engine.
05-17-2012, 10:03 AM
#22 |
Oddometer: 7,200
Are you aware that engine oil is composed of polymers of different lengths? The shorter ones can either cook off or can link with other ones to create longer chains, which don't flow as well. Sludge is a mix of long-chain polymers and contaminants, created by combustion byproducts and heat. Some engines and oils are more susceptible to sludging than are others.
05-18-2012, 05:41 AM
#23 |
Oddometer: 1,665
Never mind! :)
TAT 2008 / Colorado 2010 "Both the man of science and the man of action live always at the edge of mystery, surrounded by it." -Oppenheimer 2007 Monster S2R / 2006 TE610 / 1999 KDX 200 / 2000 DRZ-E kpt4321 screwed with this post 05-18-2012 at 07:57 AM |
| Thread Tools | |
