Old 05-13-2012, 06:45 AM   #1
motoracer51 OP
Oddometer: 662
2006 suddenly stalls once warmed - idle mixture?
Bought the bike used with about 18K miles on the odo a few months ago. I noticed that once it began to get into the warmer temps the bike would stall randomly, once warm, when idling - usually on coasting to stop lights/signs. It's usually takes a few seconds on the starter to re-fire.
I'm thinking it's the idle mixture too lean? What do you guys think?
This is really bugging me as I love the bike, but this stalling is making it a pain to enjoy. I would love to take the bike on some linger trips but refuse to until I rectify this stalling.
Thanks for any help
motoracer51 is offline   Reply With Quote
Old 05-13-2012, 06:50 AM   #2
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,200
I suggest you get familiar with your carbs. May be time for some cleaning and possible float adjustments.
You could run some cleaner thru your next tank of fuel to see if that helps first.
One of the best additions I did for mine was the remote mixture screws to allow me to adjust on the road.
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger"
My2Wheels
dad2bike is offline   Reply With Quote
Old 05-13-2012, 07:00 AM   #3
motoracer51 OP
Oddometer: 662
Just curious - Is it an air or fuel mixture screw on these bikes? Hopefully I can tackle it today.
Old 05-13-2012, 07:03 AM   #4
Pete156
I love to eat!
Pete156's Avatar
Oddometer: 1,440
Make sure your idle is above 1400 RPM. (Just my $.02 worth)
530 EXCR
950 ADV S
1000 CBR
200 KDX
___________________________________
humans are the stupidest people on earth
Pete156 is offline   Reply With Quote
Old 05-13-2012, 09:31 AM   #5
motoracer51 OP
Oddometer: 662
Yeah, it's at about 1500. When I tried to increase it a bit higher, it would stop stalling, but it would then have trouble coming back down. It would stay around 2K and then settle to say 1800.
Old 05-13-2012, 12:13 PM   #6
motoracer51 OP
Oddometer: 662
Rear was 3.5 turns out, and the front was 2 turns out. Is this because the rear runs hotter, thus running leaner?
Also, what would you do - 1/4 turn richer? 1/2 turn?
Old 05-13-2012, 01:28 PM   #7
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,200
You really need to look at all your jets to understand why the PO did that. I suggest finding out what all your jets are so you know where you are to know where you need to go. ;)
Your pilot jets should be the same. Typically a 42 or a 45. The mixture screws should be about the same. I've never had them more than an 1/8 turn different.
Typical starting point for the mixture screws is 1.75 or 2 turns both.
My2Wheels
Old 05-13-2012, 07:07 PM   #8
motoracer51 OP
Oddometer: 662
Well, I took the thing apart and noticed that A. There was MASSIVE soot build up on the canisters:
Also seemed like the intake tract of the rear cylinder has a decent amount of carbon build up on it.
I ended up leaning out the mixture on the rear 3/4 turn, and on the front 1/2 turn. Started it up and brought it up to temp and it seemed to be running SWEET. I wont know 100% till I take it out for a ride sometime this week.
Old 05-14-2012, 10:30 AM   #9
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
Was the bike ever tuned for the aftermarket exhaust and/or for your elevation prior to you purchasing it?
anything greater than 2.0 IMS turns usually means that someone has been changing things. I usually run the IMS the same front/rear on these engines, however it may be necessary on some to get them to fuel correctly.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 05-15-2012, 05:55 AM   #10
motoracer51 OP
Oddometer: 662
I know that the guy that traded it into the dealer lived out here in the same valley - so the altitude should be the same. Not sure if the PO did the exhaust install, or if it was tuned by someone else.
I'm going to try to ride it some this week and see how she goes. I'd like to take it to Salt Lake City for the World Superbike races in 2 weeks.
Old 06-01-2012, 08:02 AM   #11
motoracer51 OP
Oddometer: 662
Just an update.
I finally was able to ride the bike with the new idle mixture adjustments and it still stalls out - perhaps even more so. I'm thinking I went the wrong way?
What a PITA to get to the carbs on this thing.
I know about the fuel pump issues - do any of you guys think it might be that?
Times are GMT -7.   It's 03:52 PM.
