Go Back   ADVrider > Bikes > Hacks > Hack Vendors
Old 06-02-2012, 03:03 PM   #16
JustKip
JustKip's Avatar
Oddometer: 4,672
I have a question.
I've always liked Triumph "Modern Classics" except thier fuel range. What will the tub do to the already too low (just over 100 mi) fuel range?
Is it possible to fit the classic looking tub with a large transfer tank?
JustKip is offline   Reply With Quote
Old 06-27-2012, 06:25 AM   #17
IsAnOzzie
Oddometer: 261
I have always liked the classic style of these sidecars.
If Claude makes a body like this it will be great.
Unfortunately I am in Australia so Claude's Skills are not available to me, (I did suggest he moved to Australia)
I have a chassis and want to have a crack at fabricating my own body, Aluminuim with copper rivets over a light frame.
The bike is a 2009 Kawasaki VN1700 so I think the classic style will match up well.
The Extinguished gentleman.
Do or do not. There is no try. Yoda
IsAnOzzie is offline   Reply With Quote
Old 06-28-2012, 02:48 PM   #18
claude OP
Sidecar Jockey
Oddometer: 3,908
This body will be built with TIG welded aluminum. We have not done a steel body in quite a while although we still offer them. The steel is 16gauge and the aluminum is 1/8". The aluminum seems to weight about 30% less than the steel for the same size and shape body.
Here are a few pictures of the building process:
The buck or whatever you want to call it:
The mock up made from foil finished insulation over the buck:
The process of fitting all the Pieces together. This is Kinda tedious. Notice the squared off edges around the cowling at the cockpit. This will be formed more into an arc back at the cockpit area as we proceed.
More to come.......
Claude
http://freedomsidecars.com/
claude screwed with this post 06-30-2012 at 04:21 PM
Old 06-28-2012, 03:15 PM   #19
claude OP
Sidecar Jockey
Oddometer: 3,908
Okay things are progressing. Here are pics of the TIG welded aluminum body in the rough.Our bodies are welded inside and out. The outside will be dressed up prior to actual finishing.
Welded nose. Yep it fit up just fine:
Nose with CNC Machined CSM emblem mocked up in center.
From the inside looking out. Yes we were able to round th ecorners around the front of the coickpit. This one is not destined for a glove box but one could be done easily that would have quite a lot of room.
We sat the body on another frame just to see how it may look. The actual frame for this new body design will deviate from our typical design somewhat and will have a different fender.
This bmw bike belongs to Frank DelTorre and will be getting a cargo box tub on it that is now at powdercoat.
Claude
Old 06-29-2012, 06:58 AM   #20
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,534
Looks good Claude.
06 Ural Patrol
03 R1150 GS Sport/ Friendship II
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
http://www.advrider.com/forums/showthread.php?t=592860
http://dirtydr.smugmug.com/
Proud Member of the Patrol Patrol
DirtyDR is offline   Reply With Quote
Old 06-29-2012, 01:45 PM   #21
Abenteuerfahrer
Deaf on Wheels
Abenteuerfahrer's Avatar
Oddometer: 2,303
Cool Claude....more aerodynamic and fast as a bullet.... taper the aft section; make it look like a Rockette faster... Is this how you spend your summers?: tinkering on new designs.
cheers..
Abenteuerfahrer is offline   Reply With Quote
Old 06-30-2012, 02:41 AM   #22
BeeMaa
Hack Pilot
BeeMaa's Avatar
Oddometer: 1,098
Claude,
Love the design.
Just a thought here.
What if you put a boat style (like a canoe) rear end on it?
I know it would cut down on storage, but it would look cool.
Cheers.
Eric B
'06 R12GSA/Hack & '10 R12GSA
An armed society is a polite society. Manners are good when one may have to back up his acts with his life. Robert A. Heinlein
BeeMaa is offline   Reply With Quote
Old 06-30-2012, 03:37 PM   #23
JustinP
JustinP's Avatar
Oddometer: 1,999
Coming along nicely
Can't wait to see the finished product
JustinP is online now   Reply With Quote
Old 07-05-2012, 03:29 AM   #24
Roadscum
Oddometer: 2,456
Look'n good Claude. Will that be attached to a Bonnie?
Regards, Paul
"One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Roadscum is offline   Reply With Quote
Old 07-05-2012, 05:11 AM   #25
YOUNZ
Oddometer: 324
Track
It seems a foregone conclusion, that whatever you produce, Claude, will be an outstanding design. A couple of questions, if I may. What width track are you aiming for (minimum/max)? Same as to weight? Thanks
YOUNZ is offline   Reply With Quote
Old 07-05-2012, 05:14 AM   #26
kailuasurfer
Dreamer
kailuasurfer's Avatar
Oddometer: 379
+1 on this design suggestion, Claude. I really think a more aerodynamic looking tail end would make it very special.
cheers..
kailuasurfer is offline   Reply With Quote
Old 07-17-2012, 03:36 AM   #27
Roadscum
Oddometer: 2,456
We need an update on this project!
Regards, Paul
Old 07-18-2012, 04:05 PM   #28
kshansen
kshansen
Oddometer: 198
Looking good Claude!
Might want to take a minute or two to set the time and date on the camera. It's 2012 in the rest of the world already!
Ken
kshansen is offline   Reply With Quote
Old 08-12-2012, 07:49 PM   #29
Motoblag
Replacing skill with will
Motoblag's Avatar
Oddometer: 394
Hi Claude! I dropped you an email a bit ago asking about this style of tub. Any updates?
Motoblag is offline   Reply With Quote
Old 08-13-2012, 05:31 AM   #30
claude OP
Sidecar Jockey
Oddometer: 3,908
Have a glitch with our email right now, VERY FRUSTRATING! Hopefully it will be corrected today!!!!
We are working on the sidecar chassis right now. For this model we have designed a new sidecar chassis and suspension rather than adapt the typical type chassis we use on the dual sport adventure type outfits. It has an underslung shock and a built in manual tilt adjustor. These chassis will allow less ground clearance and still maintain a decent swingarm angle. This chassis can be utilized with any of our other body designs if desired. No antiswaybar is incorporated although one can be added if desired.
Anyone want to volunteer a name for the sidecar body design? We are open for suggestions of course.
Claude
Times are GMT -7.   It's 07:48 AM.
