Old 05-16-2012, 04:01 PM   #1
decka OP
decka's Avatar
Oddometer: 70
Best inexpensive compressor?
I have searched but don't see what I'm after. Just wondering what people recommend for a good all around air compressor.
-setting motorcycle tire beads
-topping up car and bike tires
-yeah, that's about it. Not gonna use t for tools
Any popular favorites from craftsman or home depot?
decka is offline   Reply With Quote
Old 05-16-2012, 04:12 PM   #2
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,187
I have a small craftsman. It has a cast iron cylinder.--- Most small cheap compressors have a plastic piston that doesn't last very long. These are the oil less.--- I have had this compressor for 6 or 8 years and it works as good as the day i bought it. I paid $99. I have seen them on sale cheaper than that. it will pump up to 120 PSI.
rufus is offline   Reply With Quote
Old 05-16-2012, 04:48 PM   #3
decka OP
decka's Avatar
Oddometer: 70
Good to know. What's the volume on yours in gallons? My sense is that I don't need a huge tank. Just enough to pop set a tire bead and then from there it's just slow filling etc. 120 is more than enough pressure obviously.
Old 05-16-2012, 05:29 PM   #4
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,621
The storage tank volume is what will seat your tires...
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 05-16-2012, 05:30 PM   #5
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,245
Small compressor comparo here...........
http://toolmonger.com/2011/06/01/tm-...-test-part-ii/
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 05-16-2012, 05:57 PM   #6
T
stay classy
T's Avatar
Oddometer: 5,331
Yep. Don't go too small if seating tires is on your checklist...
Inconsequential Adventurer
T is offline   Reply With Quote
Old 05-16-2012, 06:11 PM   #7
KG6BWS
KG6BWS's Avatar
Oddometer: 895
Ive got a 21 gallon Harbor freight compressor. 110 volt, stand up, as long as youre not expecting to be rotating your truck tires in under a minute itll run air tools just fine. I use my 1/2" and 3/8" guns and ratchets, die grinder, drill, riveter and a few other things on it, seat moto tires, fill trailer and car/truck tires. Does all of them with varying degrees of efficiency.
Its served me very well for the last year and half or so.
KG6BWS is offline   Reply With Quote
Old 05-16-2012, 07:28 PM   #8
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,364
It's a mistake to buy too small a compressor. Air tools are where it's at.
---Albert Einstein
Old 05-16-2012, 07:50 PM   #9
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,224
Avoid "oilless" compressors and get something with a cast iron cylinder and oil-filled crankcase. Break it in according to the manual, keep the oil topped up and it will run forever.
I paid right around $100 for a little 3 gallon 2HP oil-filled unit last year. Works awesome for my minimal needs.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 05-16-2012, 07:54 PM   #10
P B G
Oddometer: 10,001
Go used.
Biggest issues are:
A: Garage Space
B: Garage Electrical Service
C: Means of transportation.
Old 05-17-2012, 12:13 AM   #11
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,195
Got a recon Porter Cable oilless150 psi pancake for $100 a few years back.
Great portable compressor for nailguns, filling tires, small garage air tools.
Don't know about seating beads, though.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 05-17-2012, 05:42 AM   #12
hugemoth
hugemoth's Avatar
Oddometer: 2,850
The small carpenter type direct drive oil type compressor I got several years ago from Harbor Freight works just fine. Think I paid about $60 for it. I've seen the same one with different names on it like Craftsman for a lot more money.
Old 05-17-2012, 06:05 AM   #13
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 3,618
I'll second Nailhead.
I've used my Porter Cable for framing & trimming, roofing, tires, the occasional air tool since 2005.
Buy a kit ( HomeDepot,etc) sell the guns & keep the compressor.
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 05-17-2012, 07:57 AM   #14
janeuner
Get Some
Oddometer: 1,406
Not sure about best, but certainly inexpensive.
'06 Suzuki Boulevard C50
'92 Suzuki GS500E (sold)
janeuner is offline   Reply With Quote
Old 05-17-2012, 08:29 AM   #15
decka OP
decka's Avatar
Oddometer: 70
Thanks, Guys!
Exactly what I was after Great input all around. I think I'm going to pay a little more for a good sized oil / steel setup that should cover me for a while.
Times are GMT -7.   It's 06:04 AM.
