Old 06-20-2012, 07:43 AM   #46
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,844
I've seen city metro buses wrapped with advertising, and they seem to use a perforated wrap material to continue the graphic over the windows.
Could this perforated wrap material be used on a poly tank and prevent the bubbles altogether?
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 06-20-2012, 08:14 AM   #47
Narsisco Lopez OP
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
The perforated material has about 50% of the material removed, so yes, you reduce the chances for bubbles, but you don't prevent them 100% as there's still the opportunity for out-gassing right under the places where there's still material.
As an update, I'm seeing more bubbles here and there... seems to happen more on warmer days. I've been cutting tiny slots and pushing the vinyl back down... this definitely works, to an extent (meaning the vinyl stays on the tank where it was previously-lifted), but I can see it can turn into a regular chore while the out-gassing is active. I'm still waiting on the 3M chemists we spoke with to reply and see if they offer up any additional solutions.
I'm keeping my eye on the German LC8 forum where the gentleman just used Kreem to seal his Safari tanks, then painted them...
forum.lc8.info
Gonna keep an eye on this thread to see if he reports peeling or if the paint job remains stable. If it stays stable, I just might consider Kreeming my tanks over this winter (gonna need some projects to keep me out of trouble anyway!)
FYYFF!
http://www.youtube.com/watch?v=NtpUv4VBDhA
Bikes: 2013 BMW K1600GT
A Few Past Bikes
: 2003 Suzuki DRZ400E | 2012 BMW K13S | 2009 KTM 990 Adventure
Narsisco Lopez is offline   Reply With Quote
Old 06-20-2012, 09:57 AM   #48
Johnf3
Oddometer: 1,067
Kreem is designed for metal tanks, but it might work on plastic. You are gunna need a 55 gallon drum for Safari tanks.
Be careful if you do it. Plently of horror stories out there involving Kreem. Once it starts coming loose from the inside of the tanks, it will absolutely cause havoc with your fuel system. I'd say there are many better choices out there if you go the liquid lining route.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 06-20-2012, 10:52 AM   #49
Jerm
Soul Adventurer
Jerm's Avatar
Oddometer: 37
Very Nice, but...
...I'd have to agree that it's going to bubble up again due to the plastic surface which is not smooth if you look at it under magnification. The porous-type surface along with the fact that fuel vapor is also 'leaching' though the plastic (not noticeable, but it is) will cause the bubbles to reappear.
I'm not chiming in to discourage the idea or to be negative, I just have about 15 years in wide format printing and have been through several 'wrap' clinics over the years myself.
The application was done skillfully imo, but I think the other forces will continue to work against you.
It'd be great if the test is successful and I'm wrong because I have some cool ideas for graphics and would love to do this to mine.
Keep us posted!
Jerm is offline   Reply With Quote
Old 06-20-2012, 12:28 PM   #50
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,844
After doing quite a bit of research trying to find the best way to color an IMS (polyethylene) tank on my DRZ the consensus of plastic and paint experts, motorcycle hobbyist experimenters, and others trying to color this plastic is that there isn't anything that will make a long lasting bond to this particular material. I probably read a hundred different articles, as I kept searching for the "holy grail" for the best way to do this. Turns out the best way is to dye it during the manufacturing process.
The material is porous.
It is fuel gasses coming through.
The only way to get the material colored is to heat it to near 200 degrees while soaking in a caustic (not RIT household) dye solution, with the risk of deforming the shape.
I read of those who tried:
flame treating the plastic,
various automotive plastic primers,
sanding rough,
sanding smooth,
extreme cleaning measures,
coating the inside prior to painting with a variety of sealants,
soaking in hot tap water with dye, etc.
and each met with disappointment in the long term.
Nothing seems to stick to this stuff for long. Especially with fuel in it.
One article I read touting "success" in restoration of a Can-Am tank on a vintage bike. On the painted tank, between each use he recommended draining all fuel from the tank, filling with water, draining, and drying (very practical, huh?), else the paint will begin to separate from the tank. Some success that was.
The perforated graphics on motocross bikes seem to have the most longevity on this plastic. At least when the bubbles appear they will eventually expand out to hit a hole, collapse and re-adhere.
That is why I was asking about that type of wrap. I think it would have the best chance, but I'd prefer someone else proving the theory on an ADV.
Old 06-20-2012, 01:33 PM   #51
Narsisco Lopez OP
Addlepated
Oddometer: 2,207
Like I said above, I ain't doing shit until I see what happens to this guy's tank...
FYYFF!
A Few Past Bikes
Old 06-20-2012, 08:04 PM   #52
hattah79
hattah79's Avatar
Oddometer: 983
Only on safari tank
The bubbles Are they only showing themselves on Safari tanks that are wrapped or
Is the same problem happening on the standard KTM tanks that are wrapped
hattah79 is offline   Reply With Quote
Old 06-20-2012, 11:08 PM   #53
Xtremjeepn
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,096
Standard tank should be fine. Different material and painted.
My stock tanks are covered in clear bra and it's been fine.
06 KTM 950 Adventure(The Fainting Goat)
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn is offline   Reply With Quote
Old 06-21-2012, 05:28 AM   #54
AdventureDave
MMMMM Bundy!
AdventureDave's Avatar
Oddometer: 738
Has anyone tried making a "Bagster" style tank cover for these tanks?
http://www.bagster.com/
AdventureDave is offline   Reply With Quote
Old 06-21-2012, 09:26 AM   #55
Narsisco Lopez OP
Addlepated
Oddometer: 2,207
Interesting idea... I think someone mentioned a similar idea somewhere else in the OC section.
FYYFF!
A Few Past Bikes
Old 06-22-2012, 07:22 PM   #56
Narsisco Lopez OP
Addlepated
Oddometer: 2,207
Fail!
It is with (sorta) sad heart (and about as much humility as my motorcyclist's ego will allow) that I pronounce the full wrap experiment on my black Safari tanks... A FAIL.
Making slits in and pushing air out of the vinyl was becoming a daily chore...one which I quickly got sick of. So, I just got finished stripping the vinyl off the tanks.
For all you that are interested and gave feedback you might be interested in knowing that as I was pulling off the vinyl, I could smell gasoline VERY STRONGLY... it would waft up in my face as I was lifting the vinyl. As much as I HATE admitting I was wrong, it IS actually fuel that's venting right through the plastic. All those naysayers feel free to say, "NAH NAH NA-NA NAH!"
Anyway, I've gotta give credit to my brother's installation... his prep wasn't wasted because this stuff was STUCK DOWN HARD. The vinyl grudgingly came up and in pieces... leaving behind a LOT of adhesive. Had it not been for the bubbling, this wrap would have stuck on for an indefinite amount of time. I had to use 3M adhesive cleaner and a squeegie to remove the left-over adhesive. Cleaned up fairly-easily and then I washed the tanks with hot, soapy water and rinsed.
My brother's already planning a perforated test, but I think we'll hold off on it till after I get back from the big Alaska/Dalton Highway ride at the end of July.
In the meantime, I just couldn't let my bike look like "Geek Jr.", so...
Tossed on a couple of the left-over KTM vinyls I had from when my brother did a cut job for the alternate logo.
When bubbles appear under these, I can just pull 'em off and reapply new ones. (Nice to have a brother who can make a shitload of these from scraps!). Worst-case scenario: he can print my custom "990 Adventure" logo out of perforated vinyl and I can just lay it down on the tanks without doing a full wrap.
I'm a stubborn SOB, so am not giving up on the idea of a custom look for these tanks. But, I'm also "smaht" enough not to throw good money after bad... like I said above, I'm gonna wait to see how that German guy's painted tanks hold up with the Kreem sealer. As someone mentioned above, it would suck to have the liner/sealer come loose on the inside of the tank... talk about a freaking big mess to have to clean up!
FYYFF!
A Few Past Bikes
Old 06-22-2012, 08:38 PM   #57
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,539
Great insight...
Thanks for the full follow up. This was a valuable exercise and probably saved alot of others in ill fated work. I still feel it was incredibly gutsy on your part and am sure you'll find the perfect end goal for a tank design... so much so that others will follow in step.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer screwed with this post 06-23-2012 at 11:21 AM
DesertSurfer is offline   Reply With Quote
Old 06-22-2012, 10:25 PM   #58
liftedlimo
PNW Stump Jumper
liftedlimo's Avatar
Oddometer: 66
Thanks for the follow up.
'12 KTM 990 Adventure
'12 Yamaha Wr450F
'08 Can-Am Ds450X
'05 BMWDakar(sold)
liftedlimo is offline   Reply With Quote
Old 06-22-2012, 11:51 PM   #59
Xtremjeepn
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,096
Thumb
Better to have tried it and failed than to have quit before even starting because of the rumors that it couldn't be done
02 KTM 520 EXC
04 KTM 351 EXC
Old 12-09-2012, 11:09 AM   #60
Qwik
Adrenaline Addict
Oddometer: 6,947
I would like to try the Perf'd stuff on mine. I miss my All Black Katoom.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Times are GMT -7.   It's 04:15 PM.
