Old 11-05-2012, 04:01 PM   #1
levain OP
STILL Jim Williams
levain's Avatar
Oddometer: 5,985
External hard drive for Macbook Air
Whats the best one? Around 500gb. The reviews make it sound like none of them work with the Air. I just want one that will work with little drama
Click Here!
2012 Triumph Tiger 800 XC
1971 Lambretta DL
levain is offline   Reply With Quote
Old 11-05-2012, 04:16 PM   #2
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 1,755
Take yer pick. Any USB hard drive will work fine. Where are you seeing reports of problems?
You will need to reformat it with Disk Utility before use, but that takes maybe 30 seconds.
My favorite source for Mac bits, Other World Computing:
http://macsales.com
I don't see the point of paying more for a Thunderbolt drive.
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR650 - Turd II, The ReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer screwed with this post 11-05-2012 at 04:21 PM
bwringer is offline   Reply With Quote
Old 11-06-2012, 02:19 PM   #3
syntec4
syntec4's Avatar
Oddometer: 874
I have a WD 'Mybook' 1Tb. Works fine with my 13" 2011 Air. As others said I had format it first time but it was easy even for me. It was cheap from Costco.
My Smugmug
syntec4 is offline   Reply With Quote
Old 11-06-2012, 03:21 PM   #4
bergermeister
housin'
bergermeister's Avatar
Oddometer: 1,639
I'd go with a usb 3.0 drive
bergermeister is offline   Reply With Quote
Old 11-07-2012, 01:42 PM   #5
Doc.Snyder
Doc.Snyder's Avatar
Oddometer: 2,012
Iomega has a nice USB 3.0 SSD. Like it a lot. Fast as hell. Use it to run Win 8 to go.
Never stop exploring
Doc.Snyder is offline   Reply With Quote
Old 11-08-2012, 11:35 AM   #6
SnowMule
SnowMule's Avatar
Oddometer: 16,130
For backup/storage? 5400RPM laptop drive, size of your choosing. I picked up a couple 500GB WD Scorpio Blue drives for $70 a pop, USB enclosure for $6.
IMO, "external HD's" are a scam, you can get a same/better quality drive for less by buying the drive and an enclosure for it. (exceptions being network/LAN enclosures.)
I prefer to zero the drives before using them... that option's under "erase options" in disk utility. Let it run overnight, it'll take a couple of hours on a larger drive.
Spewer of the poignant non sequitur
SnowMule is online now   Reply With Quote
Old 11-10-2012, 07:27 PM   #7
rattlesnakejake
Oddometer: 252
I use a couple of different external drives/enclosures from Otherworld Computing. They've all been great. If you are trying to keep a small footprint with things and actually travel the drive with you I would suggest you get something that is 'bus powered' (drive powered from USB bus...no external AC adapter required). If you're going to just get something that sits on your desk at home then it's really not a big deal.
Without completely spamming you... http://eshop.macsales.com/item/Other...g/MSU35500GB8/
You can get cooler, cheaper, bigger, smaller, or more storage but that's a good starting point.
rattlesnakejake is offline   Reply With Quote
Old 11-10-2012, 09:01 PM   #8
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 4,649
I have a WD USB 2 160 GB drive that works fine for my MBA, my MacPro, my work Dell and anything else it hooks up to. Don't know why any other USB drive wouldn't work, regardless of format or type (Macs read NTFS/DOS format fine last time I checked - if my work Dell can read it, then it isn't an OSX format).
The only problems you might have is if you try to use it with Time Machine.
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee is offline   Reply With Quote
Old 11-10-2012, 09:09 PM   #9
barnyard
Verbal tactician
barnyard's Avatar
Oddometer: 9,292
Pretty sure I have a Syquest drive with a bunch of discs I would sell ya cheap.
all around good guy
barnyard is offline   Reply With Quote
Old 11-11-2012, 10:17 AM   #10
MrBob
Careening forward
MrBob's Avatar
Oddometer: 5,737
I use a WD Mac specific drive as a backup, which I needed after a recent crash. This is a refurbished unit I bought on Amazon.
2003 KLX 400R dual sport
MrBob is offline   Reply With Quote
Old 11-11-2012, 10:35 AM   #11
levain OP
STILL Jim Williams
levain's Avatar
Oddometer: 5,985
Thanks for all the answers. I ended up going with a Seagate 2TB drive. Now, I'm trying to use it and am confused
I hooked it up to my macbook air. It recognized it right away and after I told it to back up, it started doing its thing. So far so good.
My ultimate goal is to move all of my iTunes music onto the external from the old shared family macbook. I was under the impression that I could just plug in the external when I wanted to do iTunes stuff. I followed this link and was able to move the few albums that I have on my macbook air. I even bought a new one as a test from the iTunes store. It went straight onto the external which is great.
A couple issues I'm having;
-I subscribe to iTunes match. This particular album is not in the cloud. I bought it through the iTunes store, so I can't figure out why it isn't.
-My understanding was that I'd be able to transfer my music to the external, and I'd be able to open up iTunes and it would look like it does on my laptop. Does it not work that way?
-When I first purchased the album, it was in iTunes. After I unplugged the external and plugged it back in, its not there anymore (in itunes).
Anybody know what I'm doing wrong?
Click Here!
1971 Lambretta DL
Old 11-11-2012, 01:49 PM   #12
SnowMule
SnowMule's Avatar
Oddometer: 16,130
ITuens is pretty picky about where and how the music is organized, and it seems like it's only getting worse as versions roll on.
You'll need to point iTuens to your library... if you have a library built already, you'll need to do some work on COPIES OF the library files, to move the directories elsewhere so it can still find things.
I moved my music library to my server, mount that network volume on the local machine and work with it there. The share's set to read-only so Itunes can't fuck with it, I can set it read/write if I need to change something.
Thread Tools
Times are GMT -7.   It's 10:24 AM.
