Old 05-22-2012, 12:46 AM   #1
etingelefunts OP
retem-odo
etingelefunts's Avatar
Oddometer: 815
Building up Bike
etingelefunts is offline   Reply With Quote
Old 05-22-2012, 04:39 AM   #2
etingelefunts OP
retem-odo
Oddometer: 815
Paint, wet and dried
Less pondering. Simply march ahead, to the ends of this majestic planet.
Old 05-22-2012, 04:56 AM   #3
etingelefunts OP
retem-odo
Oddometer: 815
Passenger Mounts/Pegs Coated
Old 05-22-2012, 08:32 AM   #4
Hobbes950
Darth Kitten
Hobbes950's Avatar
Oddometer: 3,891
Looks great! Nice job.
When in doubt, take it as a compliment.
My Ride Reports
Hobbes950 screwed with this post 05-22-2012 at 09:12 AM
Hobbes950 is offline   Reply With Quote
Old 05-22-2012, 08:47 AM   #5
etingelefunts OP
retem-odo
Oddometer: 815
hobbes95821
Thanks!! Yer awesome
etingelefunts screwed with this post 05-22-2012 at 09:18 AM
Old 07-01-2012, 11:55 AM   #6
etingelefunts OP
retem-odo
Oddometer: 815
Coated Ti Remus Roxx
Sandblasted, sacrificial decal applied.
Heat cured, sacrificial decal removed.
Old 07-01-2012, 11:57 AM   #7
etingelefunts OP
retem-odo
Oddometer: 815
Prepped small parts
Old 07-01-2012, 11:59 AM   #8
etingelefunts OP
retem-odo
Oddometer: 815
Got new frame
Original was suspect. Did not want to wory about problematic rebuild.
Replacement straight from Austrian factory.
Old 07-01-2012, 12:01 PM   #9
etingelefunts OP
retem-odo
Oddometer: 815
New wiring harness
Decided to use a new loom to keep factory configuration intact.
New in box harness. Now we have plenty of donor connectors for accessories
etingelefunts screwed with this post 10-23-2012 at 02:20 AM
Old 07-01-2012, 12:04 PM   #10
etingelefunts OP
retem-odo
Oddometer: 815
Frame/harness prep
Old 07-01-2012, 12:08 PM   #11
etingelefunts OP
retem-odo
Oddometer: 815
Mounting motor/frame
Old 07-01-2012, 12:25 PM   #12
etingelefunts OP
retem-odo
Oddometer: 815
New front wheel, spokes, rubber
Stripped stock coating (tedious work)
Taped off and blasted
Close up of casting (magnifying glass)
New bits
In paint booth
In oven
Married to new bits
Wheel weld joint smoothed
Scuffed nipple channel to prep for Outex tape (going tubeless)
Laced and trued
Outex procedure completed
Balanced new Dunlop 606
On bike
Old 07-01-2012, 01:07 PM   #13
etingelefunts OP
retem-odo
Oddometer: 815
Building up chassis/frame
Better use these....
....here
....for this to move smoothly (new one on the right coated to match theme)
paired with billet upper for Scott's damper
Rider's view
With Fasst Flexx bars to cushion rehabbed wrist
Old 07-01-2012, 01:10 PM   #14
etingelefunts OP
retem-odo
Oddometer: 815
Superplush
"S" spec forks installed. 265mm travel, "64" springs. Upgrade performed by Superplush
Seal Saver socks and air bleeder valves
Old 07-01-2012, 01:13 PM   #15
etingelefunts OP
retem-odo
Oddometer: 815
Cockpit
Cockpit components ALL new. (speedo, tach, frame, w/s mount, etc)
Times are GMT -7.   It's 05:34 AM.
