05-23-2012, 10:40 PM
#1 |
Oddometer: 123
Gopro vs Contour question
Leaving in 2.5 weeks for Alaska and my wife surprises me with a Gopro Hero 2. Unknown to her is that I ordered a Contour today. So in 2 weeks I need to figure out which camera, best mount, and how to operate it.
Here are the facts: I have no video editing experience, shot the kids with VHS years ago. Either camera will have good enough quality for me. I want easy to operate, imagine mounting it to my helmet which will be Nolan N102 or full face depending on which bike. For woods riding, I don't see having the GP sticking out from the side or top of my helmet while ducking branches. For Alaska, I see using it intermittently as interesting things come up while riding, and fun around camp. If I open the GP, I can't return it so I won't be laying hands on it until it is decided. My impression of the GP is that it will be more difficult to operate while riding, and projects too much. I like the iPhone app for the Contour to set up alignment and such easier. On to the helmet, if I go with the Contour, where will it mount when using the Nolan? Any input appreciated! |
05-24-2012, 12:10 AM
#2 |
Oddometer: 23
I went for a V.I.O 1.5 about 18mths ago small easy to mount to the side of my helmet & it's handled a lot of hits that would have Munted a go pro or big bulky contour I've met quite a few people who have lost there go pros & contour's by having them ripped off somewhere down the track as well as snagging up on over hanging bush the V.I.O has a cable that connects to the hand held viewer inside my jacket so even if it gets ripped off it stays attached to me.Whatever model you get make sure you get a protective lens cover I didn't got in behind my mates 450 got sprayed with rocks & cracked the lens. Next model for me is the V.I.O HD version with a lens cover
05-24-2012, 05:41 AM
#3 | |
Oddometer: 123
05-24-2012, 06:12 AM
#4 |
Oddometer: 1,171
I can't speak to the GoPro other than I personally don't care for the teleitubbie look and I have heard it can be difficult to start recording and confirm that, I have two Contours one the GPS model the other a Roam. Both take great video and are super easy to start and stop recording they give a beep to let you know its on. ...both have AWFUL audio. I don't know what model Contour you bought, the newer ones allow for and external mic input...I would highly recommend using it if you want to hear anything other than deafening wind noise.
Here is a link to my YouTube channel...you can see what the contour video looks like
"I don't ride to be seen....I ride because I want to disappear...." Halfthrottle "The difference between genius and stupidity is -- genius has its limits." ~Albert Einstein Offcamber screwed with this post 05-24-2012 at 08:16 AM |
05-24-2012, 07:56 AM
#5 |
Oddometer: 333
Answered on the other forum, but will add here that I have the LCD BackPak so it's pretty easy for me to see that it is recording.
On the downside...The Hero cuts off after ~31 minutes (or hits the 2GB Filesystem limit?) Either way, I lost the best parts of my last ride because the camera shut itself off. Meh... |
05-24-2012, 08:44 AM
#6 |
Oddometer: 235
I've got both (well, 2 first gen gopros).
Here are my findings Video quality: hands down goes to gopro; the automatic color profile has blown away any of the custom profiles I've tried with the contour. The video is sharper and fewer blown highlights. Ease of use: contour - when I have my gopro helmet mounted, I just tilt my head to the side to see if the LED on the front is blinking. With a 170 degree FOV you don't have to be too careful with your aim. Survivability: gopro, easily. I've already replaced one contour from a drop onto concrete. The Gopro's housing is just a tough beast. It makes the camera chubby, but it's a suit of armor - what's more important to you. On my contour, the front lens cover is plastic and gets quickly blasted by sand - it's replaceable with a replacement lens kit, but at additional cost. The gopro case is an incredibly hard glass. Accessories: this is where I was surprised - before buying a camera, go price the accessories. Contour accessories are *much* more expensive! What I've learned: -The mounts that come with both are OK; the factory mounts for the GoPro feel more secure than the contour ones. That being said, I just ordered both cameras' respective 1/4" adapters and switched to RAM mounts and never looked back. -Dropping either can dislodge the battery and will *possibly* corrupt the current file. Only happened once; dropped my helmet while running to check on my buddy post-accident. (he was ok, but I didn't get any video of the crash). -Sound is mostly worthless on either; the new GoPro hero2 has a mic input, I think the contour+ does as well. If you really must have sound, that might be the way to go - toss the mic inside a tank bag or something to cut the wind noise. -Use a safety tether - I had a gopro get knocked off once; it was fine once I found it :) ----------- In summary, if video quality and durability is important to you, then get the GoPro - if ease of use and mounting close to your helmet is important to you, go Contour.
I buy all my stuff at motorcyclegear.com, formerly newenough. |
05-24-2012, 08:45 AM
#7 | |
Oddometer: 235
05-24-2012, 08:49 AM
#8 | |
Oddometer: 235
All Contour http://www.youtube.com/watch?v=cou90KWB6Vc (the footage makes the day look *really* overcast. I've found this to be fairly typical - I can do some color correction in post, but I use the contour largely as a safety camera due to the color quality, i.e. always running in case a cage does something stupid). It doesn't adjust well to going from bright to dark; you can set everything manually, but then you're set with that setting until you connect to a computer again.
05-24-2012, 11:14 AM
#9 |
Oddometer: 139
really great. go pro looks awesome. I also appreciate the info from others about the "brick-like" shape of the go pro... I was like why is it do clunky? (to protect it ya dork!), and will get safety strap too. I like your first one two... the windy road. I'm looking at go pro for up coming trip.. that quality sound is plenty good for what I'm needing it for, (not a dig, i just mean it looks as good as any video i see anywhere)
thanks! via Tapatalk
2012 GSA - xxx-black ________--- ____ -- .... .. . - . . . – Every man dies. Not every man really lives. – William Wallace – I'm working on that Bill... it's why I'm here. – hardpackrider
05-24-2012, 12:13 PM
#10 |
Oddometer: 235
no problem - note: my gopro video is from my first gen, the new hd hero 2 looks substantially better.
05-24-2012, 12:20 PM
#11 | |
Dumba$s Jarhead
Oddometer: 2,950
Other than that I agree 100% with what fierostetz said... gopro better video, tougher,,, contour easier to use. I have chosen the Contour to use more often now that I own both becuase of the ease of use, and the ease of editing latter on.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone. There is no diagnostic computer for the female mind... The Simpsons 2013 |
05-24-2012, 12:46 PM
#12 | |
Oddometer: 1,171
Were those two videos shot on the same day? If so there is something wrong with your Contour....I have not found the Contour color to be an issue I have two diffrent cameras and the exposure is very close.
"I don't ride to be seen....I ride because I want to disappear...." Halfthrottle "The difference between genius and stupidity is -- genius has its limits." ~Albert Einstein |
05-24-2012, 07:58 PM
#13 |
Oddometer: 123
Thanks for all your replies, the decision is made.
NO CAMERA!!! Riding 12k miles in 30 days, camping, GPS, sattelite phone, and enjoying the ride will be enough for me, don't need any more complications! |
05-25-2012, 04:03 AM
#14 | |
Oddometer: 1,171
I hope you at least bring a still camera....but I totally can relate to your decision. Enjoy the trip!!
05-25-2012, 06:59 AM
#15 |
Oddometer: 123
