Go Back   ADVrider > Riding > Mapping & Navigation
Old 03-24-2015, 06:53 PM   #1
Asatrur OP
Newbie KLR adv rider
Asatrur's Avatar
Oddometer: 1,298
Wiring question
I have a question on wiring. I have a garmin usb connector that has 2 bare wires on one end and I want to wire the opposite end to this http://www.batterytender.com/Accesso...l-Harness.html, so I can use my already installed adapter. Any ideas on now to do this?
00 KLR650
04 Connie - Sold, but looking again!
I wonder what is over that dirt thingamagig?
http://share.findmespot.com/shared/f...Op8LhphYfeBJ9I
Asatrur is offline   Reply With Quote
Old 03-25-2015, 10:33 AM   #2
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,366
OK, is you Garmin connector this one:
and I am not certain what you exactly want to do.
You have this connector already wired in:
Now do you want to piggyback the two together? The proper way to do that is to crimp terminals on your Garmin leads then piggyback them over where the battery tender leads go if you are lazy or cheap, just wrap the bare ends around the posts and use plenty of electrical tape..
However, it sounds like you want to order a "2 pole 2 pin flat connector" and wire it to your garmin leads?
You most certainly can do that too, just verify the polarity is correct as there can be either color on the connector wire, which doesn't matter as long as the red wire on your connector cord is 12V+.
However, I do have to say if it was my machine I'd just wire in a USB charger socket:
And just use a USB cable betweenn the two. That way you have a bit of flexibility, you don't have to carry an extra cable to upload/download from your computer, and if anything breaks you can repair it on the road at a walmart store.
GreaseMonkey is online now   Reply With Quote
Old 03-25-2015, 12:01 PM   #3
vintagespeed
fNg
Oddometer: 1,855
Originally Posted by GreaseMonkey View Post
...The proper way to do that is to crimp terminals on your Garmin leads...
the "proper" way to do that is to solder & heatshrink your connections so they last more than a few trips in the rain.
vintagespeed is offline   Reply With Quote
Old 03-26-2015, 07:22 AM   #4
wbbnm
wbbnm's Avatar
Oddometer: 2,339
+1 on solder/heatshrink. IMHO much more reliable unless you have a solder dimple pop thru the heatshrink tubing.
wbbnm is offline   Reply With Quote
Old 03-26-2015, 01:44 PM   #5
gundrted
Oddometer: 489
If you are not looking to hardwire everything. I use these off my battery tender dongle and they work great. I just run a USB cable to where I need it or run an SAE extention to where you need it.
The output is 5v and up to 2.1A.
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
Here's 12inch extension you could cut and/or lengthen its only 3 bucks
gundrted is offline   Reply With Quote
Old 03-26-2015, 04:25 PM   #6
OceanMtnSea
Pretty Dogged
OceanMtnSea's Avatar
Location: left middle Saskatchewan & entering middle BC
Oddometer: 626
I like this method too because it solves both the battery recharge issues and a electrical supply for the Garmin.
The ONLY ISSUE I have experienced with is setup is the connector I used for the +ve battery terminal..........................over time there was just enough vibration of the battery (rough roads) to break the connector at the the terminal. My second attempt was a better connector and placement to minimize the long-term vibration issue.
J
2007 BMW Dakar & 2009 Ducati Multistrada leaving the middle of the in-land sea called Saskatchewan for the Mountain Valleys of BC, Canada
http://s737.photobucket.com/user/Oce...?sort=3&page=0
OceanMtnSea is offline   Reply With Quote
Times are GMT -7.   It's 01:36 AM.
