Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 5.00 average. Display Modes
Old 07-05-2013, 10:53 PM   #136
Twigas
Oddometer: 6
Topo map
Originally Posted by Emoto View Post
Note that I am not arguing and have not tried your techniques, but am I correct in understanding that you are:
1. navigating a route that, since it was made from your track in the dirt(?) has no routable roads under it?
2. although lacking the routable roads, the route holds its correct shape and placement over the map?
Hi EMoto,
I'm using Garmin's Southern Africa Top map. It is super. It even has foot paths on it! So most , but not all of where we ride is actually on the map, although not 100% accurate.
There is one thing that cheeses me off is that the detail drops off when you zoom out both on the Zumo & BaseCamp.
Cheers,
Twigas is offline   Reply With Quote
Old 07-06-2013, 05:47 AM   #137
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,634
Originally Posted by Twigas View Post
Hi EMoto,
Cheers,
Thanks for the clarification!
What happens to you route-from-a-track if a section happens to go over an area where there is no routable road?
Old 07-06-2013, 06:25 AM   #138
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,994
I tried the BaseCamp filter. By filtering out the viapoints on BC your route ends up changing and you get straight lines between a few viapoints. Try it. Take one of your dirt bike trails that has over 1,000 viapoints and put 29 as the max viapoints. It will recalculate it, but look at the map you end up with...totally different animal.
Cheers,
Most of the time when you convert a Track to a Route you will have to do some "fixing" of the Route. To understand why, select one of your Tracks and zoom in on it so that you can see where the track points are compared to the road. If one of the points left after the filter is not exactly on the mapped road, BaseCamp has to decide if it is "close enough" or if it was intended to be off-of-the-road. Sometimes it can look like a point is on the road but if there is an intersection and the point is just a bit closer to the wrong road, when routing happens the route can be shaped the wrong way. Also, keep in mind that your digital map data is used to determine the routing and if there is bad or no route data in the map you will not get the route you expected.
Since you are using GARMAP Topo, it has routable and non-routable roads. Most likely your track(s) are using both so BaseCamp is looking for a routable path to route you.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK screwed with this post 07-06-2013 at 06:33 AM
DRTBYK is offline   Reply With Quote
Old 07-06-2013, 06:34 AM   #139
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,817
It will re-route around it following roads that are available on the map set.
Old 08-01-2013, 08:14 AM   #140
Ridin'nFishin
Oddometer: 508
Can you turn off auto re-route?
Ridin'nFishin is offline   Reply With Quote
Old 08-01-2013, 08:44 AM   #141
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,634
Yes.
Old 02-26-2014, 03:00 PM   #142
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,634
Just ran the map and software update on the 350LM that I sold to a friend, but have yet to deliver. Interestingly, part of it was adding the Tracks app.
I wonder what this means in actual use?
Old 02-26-2014, 04:21 PM   #143
DRTBYK
DRTBYK's Avatar
Oddometer: 5,994
I believe that Garmin updated the zumo3xx series to support the same Tracks App as is found on the NAV5 but I have not heard confirmation of the details for the zumo 3xx implementation. On the NAV5, you can Import up to 200 Tracks to the Tracks App and each of those tracks can have up to 15,000 points. You can have up to 15 of your tracks showing on the Map concurrently. And, if you want to actively navigate a Track you can convert it to a Trip without changing the original path.
If you are navigating a converted Track you will want to set Recalculation to Off. This will avoid you having to stop the route and restart it should the NAV5 recalculate it. Recalculating it will screw up the route for sure if the route travels overland (no road on map).
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 02-26-2014 at 04:29 PM
Old 02-27-2014, 04:05 AM   #144
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,634
So, in theory, does this mean that one can push a track to the unit and then cause it to display on the screen? If so, that is a huge improvement.
Old 02-27-2014, 07:00 AM   #145
DRTBYK
DRTBYK's Avatar
Oddometer: 5,994
If it doesn't do that they didn't port the main function of Tracks.
Cheers,
Dan
All Things GPS
Old 02-27-2014, 07:56 AM   #146
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,634
I just want to hear someone say they actually saw it work.
I bugged them about adding this to the 350 SO many times, but I want to be cautious about believing that they really did add it.
Old 02-27-2014, 07:59 AM   #147
DRTBYK
DRTBYK's Avatar
Oddometer: 5,994
Pretty easy to check if you still have the zumo. Just connect it and send a Track or two (hundred) to the device. When you reboot the zumo you go to the Tracks App and Import.
Here's a 15K point Track to play with...
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 02-27-2014 at 08:08 AM
Old 02-27-2014, 08:23 AM   #148
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,634
Thanks, but am in the office today, so can't really do much except post here.
After updating the unit, I packed it back up into the various bags and all into the original box with all the mounts, cords, etc., so it will be nice for the guy who bought it. I will probably just leave it alone unless I can't stand not knowing.
Old 02-27-2014, 08:50 AM   #149
DRTBYK
DRTBYK's Avatar
Oddometer: 5,994
Maybe some solace in that others will be checking it out for you...
I can't really imagine that the zumo team would port something less than is used on the NAV5. I think they [the zumo team] are on a path to raise the functional baseline for their brand.
Looking forward to seeing what comes next from them.
Cheers,
Dan
All Things GPS
Old 02-27-2014, 09:14 AM   #150
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,634
(if true)
Times are GMT -7.   It's 09:39 AM.
