05-25-2012, 01:28 PM
#16 |
Oddometer: 841
I use motoroil in a handsoap-dispenser. Use it for my x-ring chain when commuting, try to not start a dirtride with a soaky greased chain.
2003 xt600e 118.000km on stock motor. 1986 xt350 94.000km |
05-25-2012, 01:43 PM
#17 |
Oddometer: 446
why not use real motorcycle chain oil it is cheap or even better the dupont teflon wax chain lube ($4.95) at walmart or lowes.
Used motor oil is a known carcinogen btw.
2012 Ninja 1000 SOLD:2008 Yamaha FZ615t front sprocket, Two Bros exhaust and juice box, gel seat, etc. 1993 Suzuki DR350S pvc rack, topcase, 13t/49t sprockets, shitty seat concepts seat foam/cover ![]() & a supercharged, meth/nitrous injected weekend car
05-25-2012, 02:16 PM
#18 | |
Oddometer: 3,966
works great especially on bicycle chains that spin slower... a combination of wax and oil melted to a perfect consistency that seeps into the rollers and pins(where you need the lube) and then airdried in any case to each their own p,s, yeah dirty oil is a known carcinogen, so wear gloves! do you smoke? have you ever had second hand smoke? are you imune to carbon soot from cars in traffic? have you ever walked on a street where something was being burned like a barbacue? have you ever burned popcorn in the microwave and said a screw it? if you answer no to any of these you are pure... cheers dudes |
05-25-2012, 03:47 PM
#19 |
Oddometer: 256
I like the DuPont Multi Use or whatever it's called. Cheap and lasts a long time. Sort of does double duty on cleaning and lubing if the chain isn't too nasty.
2011 KLR650 2008 VFR800 |
05-25-2012, 04:13 PM
#20 | |
Southern Ontario
Oddometer: 1,991
![]() and ![]() Multi also comes in a squeeze bottle, which is convenient for traveling. Reviews are good, and I have used for 5 years. Have no evidence that it is better than what anyone else uses, but it's cheap and convenient, and as far as I can tell, effective. Review: http://www.webbikeworld.com/t2/motor...n-chain-saver/ jon_l screwed with this post 05-25-2012 at 04:19 PM |
05-25-2012, 04:21 PM
#21 | |
Oddometer: 446
yeah it is good stuff but some people like to do things the wrong way and swear it is right lol ![]() Well I am off to eat my asbestos sandwich and wash it down with some used motor oil since all that scientific data is moot since some guy on the internet said so.
05-25-2012, 05:09 PM
#22 | |
Oddometer: 1,622
05-25-2012, 05:38 PM
#23 |
Ross
Oddometer: 266
lube the o-rings
My humble opinion.
There are two main areas of friction: 1: The chain links themselves. In an o-ring chain this is done by the grease that is kept in place by the o-rings. What does need lubrication here is the o-ring itself. On the outside it wears against the steel side of the link. A little oil means that the o-ring will not wear out as quickly. The o-ring will last longer and the grease will stay in place. 2: Chain links against sprockets: Not sure what is best here. As you guys say, to much sticky oil and you get grit sticking to the pins and war the sprockets quicker. I think the answer is light lube of o-rings only. I am currently using renthal chain lube (squeeze bottle). I have also used chain bar lube which has very similar properties and a fraction of the cost. For pure road riding a chain lube system is good. In that case use a light oil which keeps the o-rings wet and flings off carrying grime. i prefer a little of the renthal myself. Good luck. Rearding 0-rings wearing against link side: One of the chain lube manufacturers (Hawke Oiler I think) had a good article on their site regarding chain lube. They, of course, push for good o-ring lubrication. They suggested the following experiment to show the benefits of a wet o-ring: Stick back tyre of your bike on a steel plate. rev bike, drop clutch - result is smoke and tyre wear. Put some oil on the plate and repeat above - result is tyre slips. No smoke, no tyre wear. So... lubrcate o-rings. I ran an oiler for some years on various adventure bikes. I did not find it any better than manual lubrication. If I was really worried about chain wear i would have kept my R1200GS. |
05-25-2012, 11:52 PM
#24 |
Oddometer: 63
I've just been using a leftover bottle of Royal Purple diff fluid on my chains. Soak a clean shop rag with the oil, and run it over the chain. I figure it's an o-ring chain so it really is just to keep the exterior rust at bay, and it doesn't matter much what I use...
2010 KLX250S - FMF Q4, KDX 200 snorkle, Dynojet stage 2, Tubliss Tire System, Pro Taper Contour bars (Carmichael) with Pillow Top Lite grips, Burkhart 1.5" lowering links, Nomadic rack, IMS 3 gallon gas tank, Moose Racing handguards, MotoCentric Sport Tail bag and TCI windscreen. |
05-26-2012, 08:13 AM
#25 |
Is still learning
Oddometer: 254
I don't use O ring chains in my bike but for lubing my chain (428H) I use SAE 90 grade oil (Transmission oil), and for cleaning it before putting any oil in it I use a little piece of cloth with diesel fuel on it (Please, do not even try to do that with a gear on and the bike on its stand, many people have injured and had to have the last part of they fingers amputated just because of that)
I am fine with it because, as it is less fluid than regular used engine oil it doesn't goes away of the chain after 2 or 3 Km of riding. Greetings from Argentina!
2010 Honda XR 250 Tornado |
05-26-2012, 11:58 AM
#26 | |
Oddometer: 3,966
hago casi lo mismo THANKS LEO...other countries use this method a lot... cheers |
05-26-2012, 01:36 PM
#27 | ||
tierra de boobies
Oddometer: 540
In Ecuador I use diesel on a ragto wipe it down and whatever the guy has wherever I stop to get it lubed. Used motor oil, gear oil, used unidentifiable mixture of oils, etc... Mike
Team Mojados Spearfishing Quote:
05-26-2012, 05:34 PM
#28 |
ride the night
Pressure washer from sides followed by light penetrating oil with moly or sometimes dupont multi use. 10,500 mi X-Ring Regina on XR650L Flogged every minute.
05-26-2012, 05:42 PM
#29 | |
beat up ex flat tracker
Oddometer: 6,769
Ive used o-ring chains for many years,they wouldnt sell so well if they dried out.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. |
05-27-2012, 03:58 AM
#30 |
Booze Merchant
Oddometer: 545
Yeah, I wasn't taking any of those claims as fact. Although, depending on the quality of a chain to begin with, I'd say it's certainly possible if unlikely. 30k on his chain I kind of believe, as I don't think I know anybody so anal about cleaning and lubing every hour when riding. I have 10k on one chain and sprocket on my Honda. Chain is near done, sprockets seem OK. I got 100 hours out of the last chain and sprockets on my KTM RFS, prompting the thread.
CambodiaYeah! |
