Old 05-25-2012, 07:02 PM   #1
firefighter*17 OP
Oddometer: 16
iPhone - how did you mount yours to your 950/990?
I'm curious to see how everyone is mounting/attaching their phone to their bike. What works and what doesn't work, charging setups etc... I would like to see pictures if you have them!
Thanks in advance!
firefighter*17 screwed with this post 05-27-2012 at 09:46 AM
firefighter*17 is offline   Reply With Quote
Old 05-25-2012, 07:24 PM   #2
PS-RagE
PS-RagE's Avatar
Oddometer: 642
I stuff it in my tankbag and stream wirelessly to my Scala G4
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
2014 KTM 1190 Adventure R
PS-RagE is offline   Reply With Quote
Old 05-25-2012, 08:21 PM   #3
firefighter*17 OP
Oddometer: 16
I'm considering...
I'm considering this system...
http://www.ebay.com/itm/120726738612...ht_3415wt_1042
Old 05-26-2012, 04:20 AM   #4
Yascher
Yascher's Avatar
Oddometer: 388
Originally Posted by firefighter*17 View Post
I've got this one, works perfect, only need to be careful with pressing on the front film, then there is no phone inside, as the attachment area around it is very tiny and it could be detached from glue and become less waterprooth
Yascher is offline   Reply With Quote
Old 05-26-2012, 07:24 AM   #5
firefighter*17 OP
Oddometer: 16
Good to know.... thanks!
Old 05-26-2012, 12:06 PM   #6
ADVMax
Sporting Foole
ADVMax's Avatar
Oddometer: 32,714
I've just gotten a 4S, I put a LifeProof case in this one and have the bike mount ordered for it. The LifeProof case is waterproof so I figured I would try the bar mount. I had a OtterBox on m 3GS, it's an awesome case but no mounting possibilities and it's not waterproof.
LifeProof also has a clip that fits a GoPro mount.
There is absolutely NO EXCUSE for what I'm about to do!
The Second Amendment - it ain't about duck hunting.
You heatherns needs some churchin up - http://www.landoverbaptist.org/
ADVMax is offline   Reply With Quote
Old 05-26-2012, 06:05 PM   #7
firefighter*17 OP
Oddometer: 16
The LifeProof setup looks like a great product... a little pricey but appears to be well built. I couldn't tell by their product description and pics if the charging cable can be used while in the handle bar mount??? Do you know?
Old 05-26-2012, 08:12 PM   #8
SF_Rider
Oddometer: 449
I use this
http://store.thinkbiologic.com/bike-...or-iphone.html
Have used it for the past year or so without any issues. Inexpensive, you can use it with leather gloves and mounts/unmounts easily. Also rotates to landscape view as needed.
I have used it for fire road riding, no jumps/big hits. Lots of city/urban commuting. If I lost it would buy another right away.
It is somewhat water resistant. Seals up well but the port for the headphone area has a little rubber gasket that was lost almost immediately. Have ridden in the rain and just put a zip lock over it and it's all good.
That sounds ghetto I realize but simple solution.
SF_Rider is offline   Reply With Quote
Old 05-27-2012, 05:36 PM   #9
Deviant666
Present
Deviant666's Avatar
Oddometer: 536
I also use this setup, the mounting could be a bit more secure (I always keep my phone plugged in, in one occasion the clip somehow detached from the mount and the fact that the charger cable was on saved the phone from falling off the bike, but that's once in 30k km). The case is waterproof and its charging setup directly from the battery is very convenient....recommended...
KTM 990 Adventure White 2009 R specced
ZZR1400 ABS 2008
Deviant666 is offline   Reply With Quote
Old 05-27-2012, 11:30 PM   #10
firefighter*17 OP
Oddometer: 16
Do you have any visual issues with it being mounted to the handle bars vs. the dash above speedo/tach???
Old 05-28-2012, 05:34 AM   #11
travelsomewhere
Oddometer: 155
case
Check this one out, it is something that is sold in the bicycle shops but it also comes with a handlebar clamp so it fits right in the middle of the stem perfectly on my 990 and my buddy put on on his 1200gsa. the top is held on by these elastic bands so even with gloves you just pull the top and grab your phone out. works great and a fraction of the cost of others.
https://deltacycle.com/smartphonecaddy
travelsomewhere is offline   Reply With Quote
Old 05-29-2012, 02:53 PM   #12
rwavaktm
rwavaktm's Avatar
Oddometer: 178
I Phone mount
The Lifeproof case is worth the money to me. The waterproof headphone jack works great on the bike.
I use it with the Ram mount X grip cradle. Great set up.
http://www.rammount.com/NewProducts/...Default.aspx#/
___________
06 KTM 950
02 KTM 300
00 KTM 640
09 HD RKING
rwavaktm is offline   Reply With Quote
Old 05-29-2012, 05:54 PM   #13
Deviant666
Present
Deviant666's Avatar
Oddometer: 536
Not at all, note also that I have RoxRisers and a Fatbar with a higher aggressive bend (iphone case and mount in the middle) and still got great visibility, but man I'm 6'10''....
ZZR1400 ABS 2008
Times are GMT -7.   It's 02:23 PM.
