Old 08-16-2012, 06:32 PM   #61
elgato gordo OP
KTMRFS
elgato gordo's Avatar
Oddometer: 510
cant't wait to see that!
elgato gordo is offline   Reply With Quote
Old 12-21-2012, 10:26 PM   #62
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,386
Originally Posted by EvanADV View Post
IMO a shorter "beak" would really set it off. Great build.
just at the first stage of adventurizing the SV650, thought i'd try a motard fender to reduce the beak. still doesn't look quite right to me but as long as it keeps mud out of my eyes....
free enduro training vids for gumbies here
B1 screwed with this post 01-03-2013 at 07:50 PM
B1 is online now   Reply With Quote
Old 12-22-2012, 05:17 AM   #63
jaydee1445
Footpeg Crash Tester
jaydee1445's Avatar
Oddometer: 4,057
jaydee1445 is offline   Reply With Quote
Old 12-23-2012, 11:10 AM   #64
elgato gordo OP
KTMRFS
Oddometer: 510
Nice
Hey nice looking fender, what is it off of? I've been looking into a WR250RR fender to help my big beak issue.
Are those DR forks?
My attempt at more travel for the rear is ongoing. Made a new link that gives over 8 inches but the SV1000 spring is too wimpy so I ordered a Hyabusa 1300 shock with a 700 lb/in spring. Hope that will give it enough to get the sag close.
I'll just work backward to reduce the travel until the spring works out and the swingarm angle is tolerable, maybe design a chain tensioner if I have to.
Happy Holidays
Old 12-23-2012, 02:15 PM   #65
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 759
Wink Dooooood !
Pictures ,please !!!!!!!
pennswoodsed is offline   Reply With Quote
Old 12-23-2012, 07:43 PM   #66
elgato gordo OP
KTMRFS
Oddometer: 510
Just waiting on Santa to deliver the new shock. Should be in this week sometime.
Old 01-03-2013, 07:46 PM   #67
B1
B1's Avatar
Oddometer: 3,386
Are those DR forks?
Happy Holidays
hey gordo
sorry for the late response, been busy on the bike. the front fender was just a generic motard one, can't even remember if it was polisports or ufo. but figure they'd all be pretty similar. a motard fender should suit given it's shaped for a 17 inch wheel.
the forks are just a cheap pair i got off an XT600 1988 model. i hear you on the rear shock... the front rides nicely now, but would be great to just slip in a stock shock from another bike with more travel and the correct spring on it already!
only been road riding so far but will get a decent 250 mile adventure ride in this sunday then report if there are any issues.
i did a write up on my build so far on this thread.
posted some pics too, here are a few. the prototype seat is ugly as sin but definitely comfy.
B1 screwed with this post 01-08-2013 at 07:12 PM
Old 01-04-2013, 09:15 PM   #68
elgato gordo OP
KTMRFS
Oddometer: 510
B1
Lookin good. I really like the tires what are they?
Let me know how your ride goes. You have to get on some sand and let me know what you think. I went down to Big Bend area last weekend and did a little more sand on mine. Still not too bad even with the Shinko tires. I'll be shopping for some knobs after I get the new suspension link done.
Here are some pics of the first linkage. It had too much travel and too much sag so I am reducing it a little for the next one. So far I think the Hyabusa shock should be able to handle what I have in mind, about 8 inches.
Old 01-08-2013, 07:11 PM   #69
B1
B1's Avatar
Oddometer: 3,386
B1
hey gordo
rear tire is a mitas E07 10/70-17. expensive but they last ages, and it feel pretty good on dirt and road.
the front is just a bridgestone trailwing rear tire from a DR650. it was given to me so just thought i'd give it a go.
rode through some very soft deep sand last weekend for a few hundred yards at a time. it was a series of corners so couldn't really get the speed up to ride on top of the sand... but the front is so wide there wasn't really a tendency to dig in. but there was still quite a bit of arse puckering as i went through with both legs stuck out like outriggers most of the time. she ain't a husaberg FE570 off road...
very interested to see how you go with the rear suspension, i reckon it is the lack of rear travel that is very limiting on anything other than easy dirt roads.
EDIT: you've probably already seen this, but just found a useful link comparing the shocks that fit the SV650 here. i was kinda hoping there was a shock with more travel than the SV650 one but looks like not much chance of that...
B1 screwed with this post 01-11-2013 at 10:13 PM Reason: added link
Old 01-25-2013, 06:07 PM   #70
elgato gordo OP
KTMRFS
Oddometer: 510
Suspension Update
OK got the latest knuckle done with less overall wheel travel and new 303 SS links and the Hayabusa shock. Getting about 8 inches of travel now. With the swingarm angle as it is there is no chain contact on the frame but can't go any more with out a chain guide or tension device.
Works pretty well for easy riding but still get the tire hitting the fender on bigger hits. The bottoming is not noticeable when riding but the marks are there. This setup is much improved from the GSX shock. This weekend I'll try to tear the shock apart and put some more shims in to increase the comp and rebound damping.
The stock 13 kg/mm spring is a little light and had to crank it up to the point where there is no static sag so after I see if I can increase the damping I'll shop for a bigger spring. The Hayabusa springs are available in stiffness up to 20Kg/mm I think.
Old 01-25-2013, 11:27 PM   #71
DaBit
Oddometer: 345
Wow, 8", that's great!
Would you mind to share the drawing of that linkage? I happen to have aquired a CNC mill recently...
DaBit is offline   Reply With Quote
Old 01-26-2013, 04:43 AM   #72
Ditch
Ditch's Avatar
Oddometer: 1,104
You are having way too much fun with that mill Gordon.
When are you ready to get a dirt bike out again?
Wendell
You will never find a more wretched hive of scum and villainy....we must be cautious.
Ditch is offline   Reply With Quote
Old 01-26-2013, 07:35 AM   #73
elgato gordo OP
KTMRFS
Oddometer: 510
DB ride
DaBit- PM sent
Ditch-Well we had a couple of days last weekend but looks like that's over. If you would stop buying bike the weather would get better. I'm up for Rainbow sometime.
Old 01-28-2013, 07:59 AM   #74
jaydee1445
jaydee1445's Avatar
Oddometer: 4,057
Originally Posted by dabit View Post
wow, 8", that's great!
+1
Old 02-01-2013, 04:31 PM   #75
pennswoodsed
lizards,bugs and me
Oddometer: 759
me too ism
Originally Posted by jaydee1445 View Post
+1
I hate to pig pile but , I would gladly pay for part or print .
Thanks,Ed
Times are GMT -7.   It's 02:20 PM.
