Old 05-28-2012, 09:14 PM   #1
third eye OP
back road loon
Oddometer: 138
Early '90s WR250 Yamaha
OK, tell me about your two stroke version of this bike. I just bought a '93 version with low time on it. Bike rips. Have you changed anything? What do you recommend???
third eye is offline   Reply With Quote
Old 05-29-2012, 02:26 AM   #2
Reino
Reino's Avatar
Oddometer: 212
you should re-title your thread like, wr250 2t info or something like that. I am a noob on this form as well, i had to learn the hard way.
Unfortunately i cant help, i own a ktm 250sx and a 1983 tt600 and i have never seen a wr250 in person.
Best of luck from a fellow noob
Reino is offline   Reply With Quote
Old 05-29-2012, 08:38 AM   #3
GarageRat
GarageRat's Avatar
Oddometer: 159
I had a '92-great bike! To make the bike more tractable for eastern (NY, PA, NJ) enduros & scrambles, I swapped out the aluminum clutch plates for steel (Yamaha replacement parts), this added inertia was noticeable, though i also added a 12 OZ. flywheel, which made the power deliver just electric. It was nearly impossible to stall the bike and perfect for gnarly, tight root infested trails. Yamaha also had an intake spacer that broadened the power delivery. In all, my changes made the bike trialsy, though reliable and easy to ride in enduros. Other more personal changes included a seat foam (taller) kit and pro-taper bars.
With the mods removed, the bike was an able mx'er.
GarageRat is offline   Reply With Quote
Old 05-29-2012, 04:54 PM   #4
third eye OP
back road loon
Oddometer: 138
thanks for the info. I'm reading how changing the Mikuni carb out for a Keihin PWK carb transforms the bike. Low speed throttle is kinda iffy but the mid to upper range, the bike is a rocket. Having more fun on it than my YZ400F I used to have
Old 05-29-2012, 06:12 PM   #5
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,728
I had a 98 for awhile (the same as the US 97model), but only kept it for a few months.
Power was just a bit much and it was a bit loud for my liking.
We also had a road registrable version, but unfortunately mine wasn't one of them...
And considering I already had a KDX200 and a KTM200EXC (both road registrable here) I got rid of it.
Fun bike though.
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 05-30-2012, 07:26 AM   #6
PTRadam
Oddometer: 500
The 2 stroke WR 250's were basicaly the same bike as the YZ's of that era with a wide ratio transmission and a larger tank.
PTRadam is offline   Reply With Quote
Old 05-30-2012, 07:30 AM   #7
gloud
Oddometer: 158
The only problem I had with mine (It was an 89 YZ250wrw) Was the flat slide carb was a POS (made for very hard starting) Went to a VM mikuni and solved the issues I was having. otherwise it was a matter of setting up the suspension for me and I rode the heck out of it. (oh and check the linkage bearings. mine where bad when I got it used from a bike shop. Just put it up on a stand and lift the rear wheel. should be no play.)
gloud screwed with this post 06-05-2012 at 11:36 AM
gloud is offline   Reply With Quote
Old 06-04-2012, 06:17 PM   #8
third eye OP
back road loon
Oddometer: 138
Just had the shock rebuilt and the ugly spring replaced since it was one size too weak for my weight. Hoping the stock fork springs can handle it after getting rid of the 19 year old mud....I mean, oil
Old 06-05-2012, 11:38 AM   #9
gloud
Oddometer: 158
I think it had a power valve? (Been a long time) just make sure it is not carboned up if it does. My 89 was a good bike. Fast
Old 06-05-2012, 11:27 PM   #10
Rot Box
Oddometer: 210
A friend of mine has a collection of WR250Z's from 92-97 he even has a 93 WR500 2T which is a ton of fun. 89's were known as the YZ250WR while later years were just WR250Z. Imo they are one of the best 2 stroke dirtbikes of all time even by todays standards. Unlike the YZ they had XC suspension, heavier flywheel with lighting coil, 18" wheel, larger fuel tank, wider gearbox along with a few other changes to make them more trail/xc friendly its really a shame they quit selling them in the US in 97. Unlike a lot of the enduro/xc bikes during the 90's the WR's were NOT detuned in any way shape or form--they rip and are every bit as powerful as the motocross bikes of the time.
My biggest complaint with them is the stock fuel tank on the 94-97's... I don't know what Yamaha was thinking but its like riding with a beach ball between your legs A good solution (like the later 4T WR's) is upgrading to the YZ seat and aftermarket desert tank.
Imo the later round slide Mikuni carbs that came on the WR's were not too bad. If yours has one I'd try tuning it in first before you decide to bail on it. The earlier models had the flat slide TM which is a total POS. That said the PWK is an upgrade to anything Mikuni imo
94 ATK 605DSES - 84 Honda CR500R - 81 Honda XL500S
Rot Box is online now   Reply With Quote
Old 06-06-2012, 05:26 AM   #11
third eye OP
back road loon
Oddometer: 138
yes, this does have the power valve. I've richened up the float level and needle position since it was running on the lean side on the last ride. Going to test it out this friday. I had a problem back then on it stalling on long downhills with the clutch pulled in back then. Hope this helps
Old 06-06-2012, 05:29 AM   #12
third eye OP
back road loon
Oddometer: 138
I was trying to remember something about this earlier model and that was it, the YZ250WR. Can't imaging what its like riding a 500
Old 06-06-2012, 06:44 PM   #13
Fubars
What would Scoobydo?
Fubars's Avatar
Oddometer: 1,767
Fubars is offline   Reply With Quote
Old 06-09-2012, 07:56 PM   #14
third eye OP
back road loon
Oddometer: 138
I've tuned carbs before but this Mikuni VM38 is'nt cooperating, I can tell it's way too old school for this motor. I've got a Keihin PWK on order
Old 07-03-2012, 08:40 PM   #15
third eye OP
back road loon
Oddometer: 138
It's taking forever for JD Jetting to receive new carbs from japan, Got the stocker to work for now.
Times are GMT -7.   It's 04:12 PM.
