Old 11-04-2012, 05:50 PM   #1621
cottonwood
cottonwood's Avatar
Oddometer: 27
Bought a Ural last year and it has been a blast for me, my boys who love the sidecar and my wife to learn how to ride a motorcycle and shift gears. Recently bought a new Harley and it has not made it out of the dealer for more than 2 days ever without breaking down. I do not ride the Ural gently and have ventured way off road with my kid along without worry.
cottonwood is offline   Reply With Quote
Old 11-04-2012, 07:07 PM   #1622
windmill
windmill's Avatar
Oddometer: 3,377
Originally Posted by gspell68 View Post
It's the whole gear driven alternator concept that sux.
74,000+ km, no replacement of gears or engines in that time, just a $3 gasket recently.
Simple, reliable, functional, and more than enough wattage for my needs without worry, It may not be inexpensive, but definitely a good value.
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill is offline   Reply With Quote
Old 11-10-2012, 07:19 PM   #1623
gspell68
Oddometer: 713
You must be deaf or use a full-face helmet, because you forgot loud, too...
Motorcycles! Why can't you just surf porn like everyone else?!?!? -My Wife.
1959 KMZ (Dnepr) K-750 (Happy now?!?!?)
1962 KMZ (Dnepr) K-750M
1959 IMZ (Ural) M-72M
gspell68 is offline   Reply With Quote
Old 11-11-2012, 07:03 AM   #1624
RobDek
Oddometer: 12
Another new Ural owner. I must be crazy!!!
RobDek is offline   Reply With Quote
Old 11-11-2012, 07:06 AM   #1625
BeemerChef
Wandering Homeless
BeemerChef's Avatar
Oddometer: 3,204
I don't find it loud at all. I do wear 32DB ear plugs [Hearos] and a Shoei Hornet DS helmet. I actually remove the ear plugs off road to hear the engine!
Ara and Spirit
BeemerChef is offline   Reply With Quote
Old 11-11-2012, 06:11 PM   #1626
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Oddometer: 3,351
I don't consider the Ural loud at all. I guess it is relative. I grew up working on old Triumphs, all of which were much louder than the Ural.
My '07 Bonnie with stock pipes is even louder than my '11 Gear Up.
Different in sound for sure, but the Ural is definitely quieter.
'67 Bonnie, '68 Tiger, (position vacant), '07 Bonnie/Cargo Hack, '11 Ural Gear-Up, '13 Husqvarna TR650 and a deep lust for more
RidingDonkeys is online now   Reply With Quote
Old 11-14-2012, 08:33 AM   #1627
montrealon3
Oddometer: 3
Agree with original post. Why you should not buy a Ural.
Black Stalin (2009 Patrol-T). In satin black and maroon pin stripe. 74,000km later it's a love hate thing. I got the bike end of season 09. Here is the list of parts and trouble Black Stalin has put me through. A small amount of the work was done by the dealer till he went out of business here in our neck of the woods (Montreal). Then it was up to me dealing with Ural Canada shipping parts or me driving to them. Over 1000km round trip.
: drive shaft seal. Weeping oil out between universal joint and final drive yoke.
: complete alternator and coupler system.
: alternator coupler system
: 2 rubber donut couplers till finally the 3rd was the new improved version. Still going. Good job Ural.
: rubber carb flange between carb and intake. Split.
: 2 starters
: all 4 wheels. Hub core play. Hubs not designed for SKF bearings.
: all wheel bearings. Changed along with the wheel change.
: 2WD shaft and drive assembly on sidecar.
: battery
: gas tank. Leaking along seem.
: found hole in sidecar frame tubing. Water getting in. Small. Filled with silicon. Poor welding.
: valve adjustment nut came off. Running only one cylinder. Tow to dealer. Bike was new at time. No chances.
: sidecar windshield vinyl replaced. Stretches around eyelets.
: major transmission failure. Main bearing and bearing housing. Design flaw. New transmission.
: at same time they (Ural Canada) said engine and final drive defective. Changed for new. It took 3 months.
: carbs not balanced when received bike.
: new engine defective. Compression too low. When hot no power on take off and won't maintain idle and misfires.
Received bike back after warranty was over. Stored over winter. Come spring found these problems mentioned above after all drive systems where changes.
Ural Canada and Ural USA. left me hanging. Thanks.
Sending bike to a very experienced mechanic in my area to fix at my cost.
It's a love hate thing.
My next purchase will be a Honda xr650l.
montrealon3 is offline   Reply With Quote
Old 11-14-2012, 01:35 PM   #1628
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Location: Bristol Hills in the Fingerlakes region of NY
Oddometer: 2,190
Welcome!
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
madeouttaglass is offline   Reply With Quote
Old 11-16-2012, 06:35 AM   #1629
UralBerger
UralBerger's Avatar
Oddometer: 200
: 2 starters
: battery
Yup, that sounds like Ural Canada for sure. The BS about the bearings in the hubs seems to be their new line. I have not had an issue with SKF bearings at all since 2007. The new engine should be covered for one year, Ural policy, but I guess that depends on when it was put in. Some of the issues you are experiencing with the new engine sound like improper setup, and depending on the mechanic at UC, almost guaranteed.. I am in Ottawa, so if you ever need assistance, I am not that far.
UralBerger is offline   Reply With Quote
Old 11-16-2012, 08:51 AM   #1630
FR700
Heckler™©®
FR700's Avatar
Oddometer: 3,459
Originally Posted by BeemerChef View Post
Ara and Spirit
Thank you for the ride
Have fun.
I'm diagonally parked in a parallel universe .
FR700 is offline   Reply With Quote
Old 11-26-2012, 02:57 PM   #1631
Northern Rob
Con Brio!
Northern Rob's Avatar
Oddometer: 605
Another good reason - Urals hurt cars.
Another reason not to buy a Ural. The steel is too thick. This is a hazard for cars. I got hit by an SUV today. I was stopped at a stop sign. Driver made a left turn into my street, but turned into my lane and hit the sidecar and the front tire. I'm sore but Ok. SUV has front fender damage. Ural has scratch on front sidecar armour paint. Front tire was hit too, but still rides true. Nothing on bike seems bent or otherwise damaged. I drove her home. That low tech thick steel is a real problem. Adventure bikes should be made out of plastic
Northern Rob is offline   Reply With Quote
Old 11-26-2012, 03:05 PM   #1632
GeezerStank
Oddometer: 155
Ha! didn't even scratch your ADV sticker....
GeezerStank is offline   Reply With Quote
Old 11-26-2012, 03:08 PM   #1633
BeemerChef
Wandering Homeless
BeemerChef's Avatar
Oddometer: 3,204
That is a lot of damage for a Ural!
Keep in mind it also does not do so well in deep sand and rocks...
Ara and Spirit
Old 11-26-2012, 07:51 PM   #1634
Barnone
Barnone's Avatar
Oddometer: 2,395
Keep in mind it also does not do so well in deep sand and rocks... t
Yep, JerryH researched it.
Vince @ SWFL or WNC
2001 Kawasaki W650
2012 Ural Yamal
Barnone is offline   Reply With Quote
Old 11-26-2012, 08:25 PM   #1635
Mr. Cob
Howling "Mad", Adventurer
Mr. Cob's Avatar
Oddometer: 8,780
Howdy All,
Well...........I think a Ural ridden properly goes quite well in deep sand, this video was taken a few years back and is of my stock rig with the low hanging mufflers. As you can see later inthe video when I drive down and over the large rocks the darn stock mufflers stop the rig by getting hung-up on the rocks.
I have some video of the "Predator" down at Moab but I haven't posted it to youtube yet, I'll get to work on that and see if I have some of it in deep sand and going over rocks. The pipes on the Predator are much higher then the stock ones and don't get hung-up on stuff like the stock exhaust systems do.
Dave, aka "Mr. Cob" Want a STEEL SKID PLATE for your Ural, contact me for details.
My photos, http://mr-cob.smugmug.com/ Help a CHEAP bastard keep his Smugmug, use this coupon ( geyYbNZwLLrl6 ) thank you.
Mr. Cob is offline   Reply With Quote
Times are GMT -7.   It's 11:47 AM.
