Old 06-17-2012, 07:38 AM   #766
SkagitStan
SkagitStan's Avatar
Oddometer: 28
Originally Posted by FR700 View Post
I hear you .
In the immortal words of Bob Dylan , " the times they are a changing " .
Without seeing the part in the flesh everything at this point is speculation ... well apart from it broke
Notice two other points of interest in the picture ?
Why is the center stand leg on that side of the swingarm, with the tip almost perfectly aligned with the crack,and so close to the hack mount?
Is it possible that something whacked the stand tip into the weld really hard?
Here is a view of Sara the Hack's swing arm. Not the prettiest weld ever, but the stand is really pretty far away.
Stan and
'09 Gear Up Sahara, "Sara the Hack"
SkagitStan is offline   Reply With Quote
Old 06-17-2012, 07:51 AM   #767
FR700
Heckler™©®
FR700's Avatar
Oddometer: 8,476
Tell Sara she has nice studs
Now take a look at the bottom front side of the shock body , not the mount , the body .
I'm diagonally parked in a parallel universe.
FR700 is offline   Reply With Quote
Old 06-17-2012, 08:57 AM   #768
SkagitStan
SkagitStan's Avatar
Oddometer: 28
Sara has always preferred long studs.
I don't see much at the front of the shock body, maybe bent a bit on the flange. However, there are 2 marks on the FD side of the swing arm where it looks like the shock and flange both banged into the arm. Could have been a result of the break?
Stan and
Old 06-17-2012, 08:59 AM   #769
matman1972
Lost in the woods.
matman1972's Avatar
Oddometer: 711
Wow, that has to be a new welder at the factory that likes his morning vodka. As many times as I've bottomed out mine after catching a little air, the frame bent, but no cracked welds.
Matt
2005 vw trike
Estamos copados
Confusion to our enemies.Zaphod for president!!
matman1972 is offline   Reply With Quote
Old 06-17-2012, 10:13 AM   #770
bokad OP
Difficult Child
Oddometer: 396
The anticipation is killing me Fonzy! Out with it already! :)
bokad is offline   Reply With Quote
Old 06-17-2012, 11:01 AM   #771
windmill
windmill's Avatar
Oddometer: 4,084
If I were Ilya, I'd already be on the way to the factory to lop off some heads. A Ural will always have some inherent issues because of what it is, and how it is built. On the other hand, it's not like there hasn't been plenty of posts on this forum about failures involving much more expensive custom rigs, I experienced a catastrophic rear end failure on a 6 year old Harley FLT, but like Scott pointed out Urals had always enjoyed a reputation of being virtually indestructible as a basic platform.
I understand that the few isolated failures are being blown out of proportion by those trying to prove their opinion, but this is nothing more than piss poor workmanship of an individual, totally avoidable, and totally inexcusable.
I saw somewhere that they want to kep the factory in Irbit out of loyalty, but loyalty needs to be deserved, and folks actually spending their money rather then just venting their spleen don't seem to mind that many BMW's and Triumphs are being built in Taiwan................
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill screwed with this post 06-17-2012 at 11:07 AM
windmill is offline   Reply With Quote
Old 06-17-2012, 11:20 AM   #772
Abenteuerfahrer
Deaf on Wheels
Abenteuerfahrer's Avatar
Oddometer: 2,310
Aye....
cheers...
Abenteuerfahrer is offline   Reply With Quote
Old 06-17-2012, 02:49 PM   #773
Billtr96sn
Flange Furtler
Oddometer: 393
Imagine this with a chair on it!
If you see me coming, better step aside. A lot of men didn't, a lot of men died, all because of my shit brakes.
Billtr96sn is offline   Reply With Quote
Old 06-17-2012, 03:17 PM   #774
outfit
outfit's Avatar
Oddometer: 661
Look's good as is. They'll never get performance with them pushrod tube's atop.
outfit screwed with this post 06-17-2012 at 03:23 PM Reason: g
outfit is offline   Reply With Quote
Old 06-17-2012, 03:31 PM   #775
FR700
Heckler™©®
FR700's Avatar
Oddometer: 8,476
Fozzie
Blown shock seal ?.
Rough roads .
Loaded like a semi.
Driven like a D9 Cat.
Continual bottoming out .
Axel behind shock mount .
Weak/weakened/weekend weld .
*Crack*
FR700 screwed with this post 06-17-2012 at 03:40 PM
Old 06-17-2012, 04:52 PM   #776
MotoJ
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,186
Fozzie
Blown shock seal ?.
Rough roads .
Loaded like a semi.
*Crack*
Not seeing it. Is there another photo somewhere with oil all over the shock? In another thread or something?
The ladies used to check me out...now they just keep an eye on me.
MotoJ is offline   Reply With Quote
Old 06-17-2012, 05:44 PM   #777
oppozit
Oddometer: 341
Fozzie
Blown shock seal ?.
Rough roads .
Loaded like a semi.
*Crack*
Impossible. This is the improved Sach's shock that replaced the Plaza shock that replaced the rebuildable IMZ shock. You can't possibly mean that this QUALITY European product is not perfect? It cannot fail - it's listed as an improvement. Oh! Maybe its like the electronic ignitions, each failure replaced by another, or the alternator adaptors, or the airboxes, or even the Final Drive bolts?
oppozit is offline   Reply With Quote
Old 06-17-2012, 06:20 PM   #778
FR700
Heckler™©®
FR700's Avatar
Oddometer: 8,476
I might be off base .
The pic' shows the front bottom of the shock and swingarm with dust , dirt and road grime stuck to it. The rest is relatively clean and dry . Anyone that has spent any time riding on dirt will tell that even the smallest oil weep will show up . I did debate whether it was grease thrown off by the shaft .
Work with me here buddy , I'm going for my private detective license
Old 06-17-2012, 06:25 PM   #779
FR700
Heckler™©®
FR700's Avatar
Oddometer: 8,476
Oooohh , look Ma !!, a can of worms
Old 06-17-2012, 06:37 PM   #780
MotoJ
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,186
Aha Cato! We haff foundz a klew!
Times are GMT -7.   It's 10:00 PM.
