05-30-2012, 03:54 AM
#31 |
Oddometer: 325
Get camber bolts for the rear suspension. The "acceptable" range for the rear camber on the focus was too great. Something like 0 to 2 degrees. At anything past 3/4 or 1 degrees will chew up the inside of the tires. However, the alignment tech will tell you everything is peachy when their machine tells them it is under 2 degrees. Thes bolts are available from a few places like Tire rack and perhaps Autozone. Sometimes called crash bolts.
TDC PS: I was going to try and sell you a set of snow wheels/tires until I spotted your location.
I wear a helmet in public! Yeah! GS850GLX DR350SE |
05-30-2012, 07:10 AM
#32 | |
Enabler....
Oddometer: 4,998
05-30-2012, 07:37 AM
#33 |
marginal adventurer
Oddometer: 25,025
My ZX5 doesn't see a lot of miles but it runs great and gets really good mileage. With the AC off it is reasonably quick.
I was in a similar position a couple years ago and all the imports were stupid expensive, high-mile, auto trans commuter beaters. My first 'merican car, and so far I like it. |
05-30-2012, 08:39 AM
#34 | |
Oddometer: 325
http://www.tirerack.com/suspension/s...08&autoModClar= http://www.fswerks.com/ford_focus_camber_kits.htm The bolt replaces the outer bolt on the upper control arm. It has a cammed head that when turned moves in a slotted (by you) hole alowing the camber change. You must also adjust the rear to when doing this but that adjustment is available already. Here is a how to: http://forums.focaljet.com/suspensio...ber-bolts.html TDC
05-30-2012, 08:44 AM
#35 |
速
2005? Buy it!
Seriously Ford had really ramped up their QC by '05 and had been building the Focus for 7 years so the kinks were ironed out. I drove a ZX-5 for a week and loved it. |
05-30-2012, 09:18 AM
#36 |
Leghumper Emeritus
Oddometer: 4,935
Brad Felmey-izing threads everywhere Brad Felmey screwed with this post 08-28-2012 at 01:24 PM |
05-30-2012, 09:30 AM
#37 |
NWGS's pwner!1!!1!
Oddometer: 18,679
Good move Sniper. Now black out ALL the windows. White car with black windows is perfect.
05-30-2012, 10:32 AM
#38 | |
Von Hochstaden's son
Oddometer: 44,978
2 litre ... lots to power to tap out of that. Small turbo should get you there. Sure as shit it is more planted! 189 foot pounds of torque in that little feller.
mikuni vm32-33 both sides :\ 5000 feet altitude/ 140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide 35 mpg around town riding like a asno |
05-30-2012, 01:16 PM
#39 |
De Oppresso Liber
Oddometer: 30,406
Got the limo tint appointment tomorrow at 1100hrs.
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it. RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT |
05-30-2012, 01:19 PM
#40 | |
De Oppresso Liber
Oddometer: 30,406
But I am putting the SVT focus wheels on it....
05-30-2012, 01:36 PM
#41 |
De Oppresso Liber
Oddometer: 30,406
Here she be.....
05-30-2012, 07:27 PM
#42 |
That Beastly Man
Oddometer: 1,113
SVT suspension kits can be had for a song. Made mine go-cart like. Yours might not have a stabilizer bar or mounts out back. I have mounts I'll give you if you want them.
"Someone else pays the real price for my cheap flight life" Belle and Sebastian |
05-30-2012, 09:26 PM
#43 |
That Beastly Man
Oddometer: 1,113
FWIW you can buy a rear suspension sub frame with camber adjusters and sway bar mounts (oem welded on).
One thing: watch the valve cover for oil leaks. The thermostat housing will crack (and leak) if oil soaks the seal beneath it. Another thing: the original ignition locks (pebbly surface) often fail. If key insertion/removal starts getting sticky get it to an automotive locksmith before it fails and has to be hacked out. If he knows what he's doing he'll replace it with an F-series unit (smooth surface). A triple-A Plus membership will get you a discount big enough to pay for itself.
"Someone else pays the real price for my cheap flight life" Belle and Sebastian taranaki screwed with this post 05-31-2012 at 12:43 AM |
05-31-2012, 07:30 AM
#44 |
De Oppresso Liber
Oddometer: 30,406
Has front and rear bars. I'll jump on a Focus board and seek a stock SVT suspension....good call. Have spring compressor and the skillz yo!
05-31-2012, 07:32 AM
#45 |
De Oppresso Liber
Oddometer: 30,406
So I filled it to the brim two days ago, waited till I had 106.5 miles on it and this morning it only took 2.4 gallons of go juice, what is that? Like 43MPG!!??
| Thread Tools | |
