Old 05-30-2012, 07:06 AM   #1
tominboise OP
Oddometer: 722
Bonding plastic with epoxy and fiberglass mesh question
I have a broken hinge pin fitting on my Silverado center console. I'd like to repair it and save the $$ for a replacement lid. I thought to use JBweld plastic epoxy for the repair, and then reinforce the joint by applying a patch of fiberglass mesh loaded with epoxy over the top. Has anyone done such a repair? Will the epoxy fill the mesh or does it need to be thinned? If so, what with?
tominboise
1995 DR350SE - mini adventure bike,,,,
1982 R65/80 G/S - bigger adventure bike,,,,
tominboise is offline   Reply With Quote
Old 05-30-2012, 07:21 AM   #2
ragtoplvr
Oddometer: 6,070
There will be a triangular recycle symbol on the part with a number in it and plastic abbreviation telling the type of plastic. Once that is known the correct glue can be recommended.
Rod
ragtoplvr is offline   Reply With Quote
Old 05-30-2012, 07:44 AM   #3
the_gr8t_waldo
Oddometer: 2,099
i've never tryed it but, i don't think that JB weld would "wetout" std fiberglass cloth very well. as ragtop suggested...find out what youre dealing with first
the_gr8t_waldo is offline   Reply With Quote
Old 05-30-2012, 07:46 AM   #4
BuddingGeezer
Oddometer: 233
I have repaired ABS and other plastics with epoxy many times with superb success. The key is to get the parts to be bonded really clean. denatured alcohol works well. the 2nd KEY is to rough up where the epoxy will be. 80 grit sandpaper works really well. easier to use than polyester cloth or mat is fiberglass dry wall tape. JB Weld works great , but so does regular epoxies. I would use 5 minute epoxy or JB Quick in your application.
BuddingGeezer is offline   Reply With Quote
Old 05-30-2012, 08:12 AM   #5
Fe Man
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,131
I have used multiple strips of fiberglass drywall tape and 2 part epoxy to repair plastic moto parts with great success! As in the next crash it broke somewhere else.
2006 Tiger
2008 KLR (hers)
Fe Man is offline   Reply With Quote
Old 05-30-2012, 10:33 AM   #6
tominboise OP
Oddometer: 722
This is what I will likely do. I have the JB weld 5 minute plastic epoxy and will get some fiberglass drywall tape.
tominboise
Old 05-31-2012, 07:16 PM   #7
74C5
74C5's Avatar
Oddometer: 948
The JB weld will squeegee into many woven fabrics. It won't necessarily wet it out like a resin though. You might need something more than 5 minutes to get the fabric saturated and then lined up. JB will start kicking over sooner than 5 minutes and might not be very workable.
R1200RT (R1100RT gone)
KLR650 - gone
Don't be the guy who needs to pee on the fence to figure out that it's electrified.
74C5 is offline   Reply With Quote
Old 06-01-2012, 09:40 AM   #8
Ramata
Wind
Oddometer: 75
Quick Steel for plastics is a great 2 part epoxy, I've used on many ABS (and pvc) plastics and they hold well to this day.
Ramata is offline   Reply With Quote
Old 06-01-2012, 10:18 AM   #9
John E
Oddometer: 807
If...
your console is made of ABS like many or most plastic bits on motorcycles are, I'd use some ABS cement instead of the JB Weld. It's wetter, will fill the mesh better and it bonds to the part better.
Available anywhere plumbing supplies are sold.
I used to own an SR500, big street thumper that shook like a paint shaker, had chronic issues with the retaining tabs breaking off of the tail piece and side covers, only stuff that ever worked was ABS cement. Tried various epoxies, mesh, glues, etc.
" ...that was the river, this is the sea..."
This is the Sea
The Waterboys/Mike Scott
John E is online now   Reply With Quote
Old 06-02-2012, 10:40 AM   #10
Motomedic
Motomedic's Avatar
Oddometer: 2,468
I've used ABS glue and fiberglass cloth with success on the ABS inner bags on my Buell. A bit "fume-y" for a day or so but works well.
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is online now   Reply With Quote
Old 06-03-2012, 12:16 AM   #11
squish
Out of the office.
Oddometer: 6,164
I've done ABS repairs using a hot air welder, Superglue, fiberglass mat, woven and dry wall tape.
with the FGlass I've used JB weld, 5 and 90min epoxy, resin and ABS glue. There's also something that can be done with superglue and like cornstarch to make a kind of filler paste.
The one I turn to to make quick solid repairs cheaply with stuff I have on hand
Fiberglass that's handy and 5 min epoxy. mostly as it's on hand, It's decently easy to work. The epoxy wets out decently but kicks quick enough for vertical work.
I just got a 3'x3' section of cloth from the autoparts store and use my supply of epoxy I have around. I cut the cloth to size
rough of the repair, lay down a base layer of glue, lay down the mat, pour some more epoxy over the mat.
Let it cure, surface stuff up if needed then I'm done.
This doesn't work on HDPE or other Thermoplastic polyolefins (like dirtbike and ATV fender and other real flexible plastics that are molded in color, which means they have the same color all through the part. These often feel a little slick to the touch.
On vacation for a spell
squish is offline   Reply With Quote
Old 06-03-2012, 09:42 PM   #12
Mr. Whipple
Mr. Whipple's Avatar
Oddometer: 21
JB weld "wets out" or sturates fiberglass very well. Shouldn't be an issue there. I have used it in conjunction with fiberglass cloth to repair cracks in the plastic tanks on the radiator of a car with great success.
Mr. Whipple is offline   Reply With Quote
Times are GMT -7.   It's 06:19 PM.
