Old 05-30-2012, 10:04 AM   #1
malloy OP
Oddometer: 724
Question Help, please. Stray Circlip.
I washed the bike the other day. After moving the bike I found a Circlip on the ground on the rider's right side from the counter sprocket forward . I can't see where it goes. I'm not 100% sure it is a even part for the bike but have a feeling it is .
I searched the fiche and found just one such circlip, item 5: http://www.maxbmwmotorcycles.com/fic...6&rnd=03252011 (11_3997 - ENGINE HOUSING COVER, LEFT) but it is an internal piece and the release lever (item 8) has never been removed from the bike.
McMaster-Carr calls the circlip a "metric side-mount external retaining ring (E-Style)": http://www.mcmaster.com/#retaining-rings/=hre0t4 The one I have in hand measures 12mm outside diameter (A), 6mm inside ear to ear and is approximately .5mm thick. The clip is non-magnetic. A magnet won't pick it up so it is not made of steel. It is a dull grey color.
Any ideas out there?
Desperate and much obliged!
F650GS (Build Date 11/11)
malloy is offline   Reply With Quote
Old 05-30-2012, 12:50 PM   #2
sturgeon
sturgeon's Avatar
Oddometer: 932
The repair manual lists a few, but they're all internal as far as I can tell. If a magnet won't pick it up, it's probably stainless. Which doesn't help much, of course.
Dyslexics Untie!
sturgeon is offline   Reply With Quote
Old 05-30-2012, 01:24 PM   #3
Zeke Markham
Zeke Markham's Avatar
Oddometer: 124
Check your instrument cluster? There should be 3 of them on the posts holding it on. Wild guess but they look close to that, and I haven't had very much luck with mine staying on.
Zeke Markham is offline   Reply With Quote
Old 05-30-2012, 01:48 PM   #4
sturgeon
sturgeon's Avatar
Oddometer: 932
Yeah, that could very well be it. I didn't actually look at the McMaster Carr reference. I was thinkin' more like the "external retaining ring", not the U-shaped ones. Of course, it doesn't help (me) that BMW calls those "retaining clips", not circlips
Dyslexics Untie!
Old 05-31-2012, 06:57 AM   #5
malloy OP
Oddometer: 724
Sturgeon - I think it is stainless, actually. It is shinier then "dull grey".
I'm checking the instrument cluster, Zeke, but the one I have in hand looks a little different then the ones on my R1200GS instrument cluster.
Thanks for the replies - more are welcome.
Old 05-31-2012, 11:23 AM   #6
L.B.S.
Oddometer: 1,323
If it was an F800ST, I would have immediately said footpeg retaining pin e-clip, but I looked on the fiche and for an F650GS it shows a cotter pin style, so I guess it's not that. Sorry.
L.B.S. is offline   Reply With Quote
Old 06-01-2012, 05:45 AM   #7
malloy OP
Oddometer: 724
Zeke - No luck at the instrument cluster. All three at home. Those clips have a little lip on them to help pull them off their posts. This one is completely flat. Like Sturgeon said, all the ones I found on the Fiche were internal. So this might not be a part off the bike.
I've ridden it a little. So far so good - nothing has fallen off or exploded.
One of the first places I looked was the passenger pegs, LBS, based on prior bikes.
But, still trolling for ideas
Old 06-02-2012, 12:08 AM   #8
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,341
check the rear brake I think there is some kind of clip on the connection to the rear master.
Just checked mine and no circlip just a funky pin clip so it cant be that.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited screwed with this post 06-02-2012 at 12:22 AM
Indy Unlimited is offline   Reply With Quote
Old 06-05-2012, 06:22 AM   #9
malloy OP
Oddometer: 724
Thumb
Thanks one and all !
Spent quite a lot of time looking at the fiche and all over the bike following these suggestions and others. I Don't see any missing circlip anywhere. I've ridden a few times without falling apart so maybe this stray clip belongs on something else. Go figure.
Times are GMT -7.   It's 10:15 PM.
